Duet 2 Wifi rebooting/crashing during print
  • Hi!
    I've had my duet for several months without issue - recently it has been rebooting randomly during prints, roughly anywhere from 10 - 60 mins into the print. The only thing I changed recently was adding a berd-air max kit, which is wired directly onto a fan header.
    I'm on FW 3.1.1, but I've tried swapping to the 3.2 beta and the issue persists. Suspecting the SD Card, I did try swapping SD cards and that mitigated the issue for a little bit, but it started happening again not long after.
    Here's my M122 report for last night's crash:
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DJM-9178L-L2MSD-6J1FA-3S46N-KSFYP
    Used output buffers: 3 of 24 (21 max)
    Static ram: 27980
    Dynamic ram: 93236 of which 60 recycled
    Exception stack ram used: 312
    Never used ram: 9484
    Tasks: NETWORK(blocked,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 07:56:02 ago, cause: software
    Last software reset at 2020-11-05 03:02, reason: Hard fault, spinning module PrintMonitor, available RAM 8996 bytes (slot 3)
    Software reset code 0x4069 HFSR 0x40000000 CFSR 0x00010000 ICSR 0x0441f803 BFAR 0xe000ed38 SP 0x200053fc Task MAIN
    Stack: 0042ea7f 0042b6f2 a5038400 00000000 00000000 00000000 00000000 20005480 00000001 10000000 e000ed04
    Error status: 0
    MCU temperature: min 23.3, current 28.5, max 28.8
    Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-11-05 10:58:06
    Slowest loop: 5.47ms; fastest: 0.14ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 2.0ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 200.90ms; fastest: 0.09ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is active
    Failed messages: pending 0, notready 0, noresp 1
    WiFi firmware version 1.23
    WiFi MAC address dc:4f:22:6e:6c:ca
    WiFi Vcc 3.43, reset reason Unknown
    WiFi flash size 4194304, free heap 18416
    WiFi IP address 192.168.86.26
    WiFi signal strength -49dBm, reconnections 0, sleep mode modem
    Thanks!
  • Moderator
    How is the berd air wired in exactly? I seem to recall seeing that pumps and such might require a fly back diode or some such.
    Do the crashes persist with the berd air pump disconnected?
    Can you post your config.g as well?
  • @Phaedrux
    The berd air is wired without a flyback, directly to the fan0 header - as far as i could tell, a flyback diode isn't required for newer revisions of the duet, as each fan header has a flyback diode built in.
    I'll try a print without the berd air wired in and get back to you.
    config.g is here:
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 09 2020 23:24:59 GMT-0400 (Eastern Daylight Time)
    G90                                                 ; send absolute coordinates...
    M83                                                 ; ...but relative extruder moves
    M550 P"Casey"                                       ; set printer name
    M665 R140.3 L288 B120 H530                          ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0                                       ; put your endstop adjustments here, or let auto calibration find them
    M552 S1                                             ; enable network
    M586 P0 S1                                          ; enable HTTP
    M586 P1 S0                                          ; disable FTP
    M586 P2 S0                                          ; disable Telnet
    M569 P0 S1                                          ; physical drive 0 goes forwards
    M569 P1 S1                                          ; physical drive 1 goes forwards
    M569 P2 S1                                          ; physical drive 2 goes forwards
    M569 P3 S1                                          ; physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                                    ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                             ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z80.00 E397.50                    ; set steps per mm
    M566 X1200.00 Y1200.00 Z1200.00 E1200.00            ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E1200.00         ; set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z1000.00 E1000.00            ; set accelerations (mm/s^2)
    M906 X1200 Y1200 Z1200 E1000 I30                     ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                             ; Set idle timeout
    M208 Z0 S1                                          ; set minimum Z
    M574 X2 S1 P"xstop"                                 ; configure active-high endstop for high end on X via pin xstop
    M574 Y2 S1 P"ystop"                                 ; configure active-high endstop for high end on Y via pin ystop
    M574 Z2 S1 P"zstop"                                 ; configure active-high endstop for high end on Z via pin zstop
    M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
    G31 P100 X0 Y0 Z-0.24                               ; set Z probe trigger value, offset and trigger height
    M557 R90 S20                                        ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0                               ; create bed heater output on bedheat and map it to sensor 0
    M307 H0 B1 S1.00                                    ; enable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                             ; map heated bed to heater 0
    M143 H0 S120                                        ; set temperature limit for heater 0 to 120C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                                ; create nozzle heater output on e0heat and map it to sensor 1
    M307 H1 B0 S1.00                                    ; disable bang-bang mode for heater  and set PWM limit
    ;pressure advance
    M572 D0 S0.25
    ; PART FAN BerdAir
    M950 F0 C"fan0" Q25500                             ; create fan 1 on pin fan0 and set its frequency
    M106 P0 H-1 C"Print Fan" F25500                    ; set fan 1 value. Thermostatic control is turned off
    ; BOARD FAN
    M950 F1 C"fan1" Q50                                ; create fan 0 on pin fan1 and set its frequency
    M106 P1 S1 H0 T45 C"Board Fan"                     ; set fan 0 value. Thermostatic control is turned on
    ; HOTEND FAN
    M950 F2 C"fan2" Q25000                                ; create fan 2 on pin fan2 and set its frequency
    M106 P2 S0.5 H1 T45 C"Hotend Fan"                  ; set fan 2 value. Thermostatic control is turned on
    M563 P0 D0 H1 F0                                    ; define tool 0
    G10 P0 X0 Y0 Z0                                     ; set tool 0 axis offsets
    G10 P0 R0 S0                                        ; set initial tool 0 active and standby temperatures to 0C
    M575 P1 S1 B57600                                   ; enable support for PanelDue
    M501
  • I also just remembered that the other change I did around the time the crashes started was swapping to a mosquito hotend.
    I should also probably post what my machine is:
    Custom Delta
    Duet 2 Wifi
    duet smart effector
    24v 350w meanwell PSU
    berd air max
    mosquito mounted with the 713maker smart effector adapter
    24v heated bed, wired directly into the duet
    e3d hemera, mounted as a flying extruder
    paneldue 7i
  • Moderator
    Neither the bird air nor the osquito seem likely to cause the fault.
    Will have to wait to see what @dc42 thinks of the error message.
    In the meantime, please continue to gather M122 reports if it crashes.
    Perhaps share a gcode file that produces the crash.
  • @Phaedrux
    Another crash from this morning (berd air still connected)
    The gcode file is too large to attach here -- is there a preferred hosting site for me to upload the file?
    M122
    Used output buffers: 3 of 24 (11 max)
    Static ram: 27980
    Exception stack ram used: 480
    Never used ram: 9316
    Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1848) IDLE(ready,80)
    Last reset 00:12:58 ago, cause: software
    Last software reset at 2020-11-05 11:55, reason: Hard fault, spinning module PrintMonitor, available RAM 8996 bytes (slot 1)
    Software reset code 0x4069 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x0441f803 BFAR 0xe000ed38 SP 0x20005414 Task MAIN
    Stack: 0042eaf1 20003d50 60030000 00000001 00000009 00000014 0044eaab 0044eaae 21030000 3f000000 41492f1a
    Error status: 0
    MCU temperature: min 24.1, current 28.4, max 28.7
    Driver 0: standstill, SG min/max 0/158
    Driver 1: standstill, SG min/max 5/150
    Driver 2: standstill, SG min/max 0/166
    Date/time: 2020-11-05 12:08:02
    Cache data hit count 1269324432
    Slowest loop: 5.60ms; fastest: 0.14ms
    === Storage ===
    SD card longest read time 1.2ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 19944ms
    === MainDDARing ===
    Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
    === AuxDDARing ===
    Segments left: 0
    === Network ===
    Slowest loop: 15.91ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
    - WiFi -
    WiFi flash size 4194304, free heap 21840
    WiFi signal strength -53dBm, reconnections 0, sleep mode modem
    Socket states: 4 0 0 0 0 0 0 0
  • Moderator
    @bwnance said in Duet 2 Wifi rebooting/crashing during print:
    You may be able to zip it and change the file extension to .txt and upload it here if it's within 4Mb (i think) otherwise dropbox or google drive.
  • @Phaedrux
    Good call! Attached is the zipped gcode file, renamed to .txt:
    vibrationDampener2.gcode.txt
  • Moderator
    What's in the macro here:
    M98 P"0:/macros/start.g"
  • @Phaedrux
    I've got a little bit of a macro tree:
    start.g:
    G28
    M98 P"0:/macros/brushclean.g"
    M98 P"0:/macros/bottomhome.g"
    G29 S1 ; load height map
    brushclean.g:
    G0 Z25 F12000
    M564 S0 ; disable limits
    G0 X0 Y0 Z12 F3000 ; middle of bed, z=5
    G0 X0 Y-130 ; middle of brush
    G0 Z8 ; drop nozzle slightly
    G0 X15 ;
    G0 Y-128 X-15
    G0 Y-125 X15
    G0 Y-125 X0
    G0 Z12
    G0 X0 Y0
    M564 S1 ; enable limits again
    bottomhome.g:
    M106 P0 S0
    G0 Z25 F12000
    G30
    G0 Z15 F12000
