    Duet 2 Wifi rebooting/crashing during print
    Beta Firmware
    crash firmware hardware
    2.2k
      What's in the macro here:
      M98 P"0:/macros/start.g"
      bwnanceundefined 1 Reply Last reply Reply Quote 0
      • bwnanceundefined
        bwnance @Phaedrux
        @Phaedrux
        I've got a little bit of a macro tree:
        start.g:
        G28
        M98 P"0:/macros/brushclean.g"
        M98 P"0:/macros/bottomhome.g"
        G29 S1 ; load height map
        brushclean.g:
        G0 Z25 F12000
        M564 S0 ; disable limits
        G0 X0 Y0 Z12 F3000 ; middle of bed, z=5
        G0 X0 Y-130 ; middle of brush
        G0 Z8 ; drop nozzle slightly
        G0 X15 ;
        G0 Y-128 X-15
        G0 Y-125 X15
        G0 Y-125 X0
        G0 Z12
        G0 X0 Y0
        M564 S1 ; enable limits again
        bottomhome.g:
        M106 P0 S0
        G0 Z25 F12000
        G30
        G0 Z15 F12000
        • bwnanceundefined
          bwnance
          @Phaedrux @dc42 Hey y'all, just bumping this again -- here's another crash report from today, along with the offending gcode:
          tree_new.txt
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 08DJM-9178L-L2MSD-6J1FA-3S46N-KSFYP
          Used output buffers: 3 of 24 (11 max)
          Static ram: 27980
          Dynamic ram: 93236 of which 60 recycled
          Exception stack ram used: 304
          Never used ram: 9492
          Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:29:46 ago, cause: software
          Last software reset at 2020-12-14 23:54, reason: Hard fault, spinning module GCodes, available RAM 8940 bytes (slot 2)
          Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x04427003 BFAR 0xa5a5a5a5 SP 0x2001ffbc Task MAIN
          Stack: 0040f451 0040f452 0100001f 200052f0 200052ef 20008c2c 20003d50 a5a5a5a5 ffffffed 00000000 00f00000
          Error status: 0
          MCU temperature: min 23.4, current 28.8, max 29.5
          Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2020-12-15 00:24:45
          Cache data hit count 2932587391
          Slowest loop: 3.44ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 0.9ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.73ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address dc:4f:22:6e:6c:ca
          WiFi Vcc 3.43, reset reason Unknown
          WiFi flash size 4194304, free heap 21056
          WiFi IP address 192.168.86.34
          WiFi signal strength -57dBm, reconnections 0, sleep mode modem
          • bwnanceundefined
            bwnance
            and another one just now, the more the merrier, i guess
            Static ram: 27980
            Exception stack ram used: 472
            Never used ram: 9324
            Tasks: NETWORK(ready,408) HEAT(blocked,1224) MAIN(running,1840) IDLE(ready,80)
            Last reset 00:00:37 ago, cause: software
            Last software reset at 2020-12-15 02:33, reason: Hard fault, spinning module none, available RAM 8892 bytes (slot 3)
            Software reset code 0x4071 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0441f003 BFAR 0x91200200 SP 0x2001ff8c Task NETW
            Stack: 00454e15 00454e20 6100000e 40090000 0041d011 00000000 20002860 10000000 2000b98c 00000000 200034f0
            Error status: 0
            MCU temperature: min 24.2, current 24.8, max 25.0
            Driver 0: ok, SG min/max not available
            Driver 1: ok, SG min/max not available
            Date/time: 2020-12-15 02:34:35
            Cache data hit count 58687792
            Slowest loop: 3.66ms; fastest: 0.14ms
            === Storage ===
            Free file entries: 8
            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
            Hiccups: 0(0), FreeDm: 166, MinFreeDm: 166, MaxWait: 18624ms
            === MainDDARing ===
            Scheduled moves: 1, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by HTTP
            HTTP is idle in state(s) 1 0 8, running macro
            === Network ===
            Slowest loop: 15.75ms; fastest: 0.00ms
            Responder states: HTTP(2) HTTP(4) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
            - WiFi -
            WiFi flash size 4194304, free heap 21408
            WiFi signal strength -55dBm, reconnections 0, sleep mode modem
            Socket states: 4 2 0 0 0 0 0 0
            • markzundefined
              markz
              Since no one has jumped in here, my usual opinion when I see something like this is that (assuming the board is ok) it's either a power supply issue or a voltage noise issue.
              How much power does your heated bed use? Is it enough to impact the power supply?
              How is the 24V to the pump connected? Could noise on the 24V line be caused by the pump pwm?
              • bwnanceundefined
                bwnance @markz
                @markz
                Resistance on my heated bed (measured at connector on board) is 3.3ohms, it's a 24v bed, so that would be a ~175watt bed, correct? I'm using a Mean Well 24v 350w PSU and my hotend is 50w, so i should have plenty of extra room, wattage wise, right?
                24v to the pump is over a fan header on the board (AFAIK newer duets have the flyback diode on all fan inputs internally), I'm not sure how to diagnose if i have noise on the 24v line.
                markzundefined 1 Reply Last reply Reply Quote 0
                • markzundefined
                  markz @bwnance
                  @bwnance thanks.
                  The pump has two inputs (kind of) power and control. I know the control line goes to the fan pins but where do you pull off the 24V supply for the pump - is that from the power supply or the duet board somewhere? Are you getting the 24v from the fan header?
                  • bwnanceundefined
                    bwnance @markz
                    @markz I'm not using "EZ-Switch" board that was packaged with the berd-air, so both lines are hooked up to the fan header -- as best as i could tell before installing, this was fine, since the fan headers have flybacks wired into them
                      Can you try 3.2 Beta 4? It's believed that a fix for this crash may already be present there.
                      https://github.com/Duet3D/RepRapFirmware/releases
                      • bwnanceundefined
                        bwnance @Phaedrux
                        @Phaedrux just upgraded, will do a few test prints! We shall see...
                          Phaedrux Moderator @bwnance
                          @bwnance Just realized there is an odd ordering problem on that page that doesn't list the most recent at the top.
                          https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2beta4.1
                          Beta 4.1 can be found here.
                          • bwnanceundefined
                            bwnance @Phaedrux
                            @Phaedrux ah, ty! gonna let this print finish on beta 4, then will update to 4.1
                            • bwnanceundefined
                              bwnance
                              @Phaedrux was out of town for the holidays, just started a 4 hour print and the printer rebooted ~40mins in
                              m122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta4 running on Duet WiFi 1.02 or later
                              Used output buffers: 3 of 24 (12 max)
                              Static ram: 24108
                              Dynamic ram: 99836 of which 60 recycled
                              Never used RAM 6044, free system stack 106 words
                              Tasks: NETWORK(ready,183) HEAT(blocked,308) MAIN(running,451) IDLE(ready,20)
                              Last reset 00:01:49 ago, cause: software
                              Last software reset at 2021-01-07 01:30, reason: AssertionFailed, GCodes spinning, available RAM 5836, slot 1
                              Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x200044ac Task MAIN
                              Stack: 00000c55 00472af0 00452a9d 2000ae20 00000000 200094c8 00000000 00000000 00451edb 00000000 ffffffff 2000ae20 200034cc 200094c8 ffffffff 00000000 20004524 a5a5a5a5 00451f1b 20004514 200094b8 20008380 0044f543 20008380 0042ee47 2001e448 200094bc
                              Error status: 0x00
                              MCU temperature: min 25.0, current 25.2, max 26.1
                              Driver 0: position 63150, standstill, SG min/max 0/138
                              Driver 1: position 63150, standstill, SG min/max 0/133
                              Driver 2: position 63150, standstill, SG min/max 0/156
                              Driver 3: position 0, standstill, SG min/max not available
                              Driver 4: position 0, standstill, SG min/max not available
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Date/time: 2021-01-07 01:32:29
                              Cache data hit count 170332161
                              Slowest loop: 3.51ms; fastest: 0.17ms
                              === Storage ===
                              SD card longest read time 1.1ms, write time 0.0ms, max retries 0
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 22002ms
                              === MainDDARing ===
                              Scheduled moves 5, completed moves 5, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                              === AuxDDARing ===
                              Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                              Segments left: 0
                              LCD is idle in state(s) 0
                              === Network ===
                              Slowest loop: 15.70ms; fastest: 0.00ms
                              - WiFi -
                              WiFi firmware version 1.25beta0
                              WiFi Vcc 3.43, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 19552
                              WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              I see that 4.2 was just released so i'll update to that and try again.
                              • bwnanceundefined
                                bwnance
                                @Phaedrux no dice, another crash. @dc42 any ideas?
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                                Static ram: 23460
                                Dynamic ram: 72744 of which 60 recycled
                                Never used RAM 15816, free system stack 99 words
                                Tasks: NETWORK(ready,157) HEAT(blocked,307) MAIN(running,450) IDLE(ready,19)
                                Owned mutexes:
                                Last reset 00:01:12 ago, cause: software
                                Last software reset at 2021-01-07 19:24, reason: HardFault invState, GCodes spinning, available RAM 15608, slot 1
                                Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x0041f003 BFAR 0xe000ed38 SP 0x2001fe90 Task MAIN Freestk 29308 ok
                                Stack: 00000000 00000001 400e1400 00001000 3ed0bedf 0044adf3 2001ff28 400f0227 00000160 00000100 2001db10 fffffff1 000001ab 00000000 00a69e38 0000012b 2001c8b8 38000000 005a0073 00000001 28bb5437 fffffffb 29767437 2000770e 2001ff28 01000001 2001ff28
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                MCU temperature: min 24.9, current 25.4, max 26.0
                                Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: position 63150, standstill, SG min/max 0/147
                                Driver 1: position 63150, standstill, SG min/max 0/131
                                Driver 2: position 63150, standstill, SG min/max 0/157
                                Date/time: 2021-01-07 19:25:21
                                Cache data hit count 87576278
                                Slowest loop: 4.81ms; fastest: 0.20ms
                                === Storage ===
                                DMs created 83, maxWait 11729ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                Scheduled moves 5, completed moves 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                === AuxDDARing ===
                                Segments left: 0
                                === Network ===
                                Slowest loop: 15.95ms; fastest: 0.00ms
                                - WiFi -
                                WiFi flash size 4194304, free heap 19568
                                WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                                • Vetiundefined
                                  Veti
                                  can you post a picture of your wiring on the duet?
                                    @bwnance, your M122 software reset data doesn't make any sense, so I think it must have been caused by a transient or possible power brownout. Can you run a few more prints to see if any future crashes are similar? You can do air prints to avoid wasting filament.
                                    The assertion failure you had with 3.2beta4 is different, that's a known bug that was fixed in 3.2beta4.1.
                                    • bwnanceundefined
                                      bwnance @dc42
                                      @dc42 Will do dry-runs throughout today. It's weird, sometimes it completes a print just fine, sometimes it fails -- but all with the same file.
                                      @Veti
                                      • hackinistratorundefined
                                        hackinistrator
                                        motors very close to the board .
                                        maybe try to add some shielding , or relocate the board just for a test .
                                        • bwnanceundefined
                                          bwnance
                                          @dc42 crash on a no-filament run:
                                          m122
                                          Static ram: 23460
                                          Dynamic ram: 72744 of which 24 recycled
                                          Never used RAM 15852, free system stack 191 words
                                          Tasks: NETWORK(ready,182) HEAT(blocked,309) MAIN(running,452) IDLE(ready,19)
                                          Last reset 00:01:26 ago, cause: software
                                          Last software reset at 2021-01-08 15:42, reason: HardFault imprec, GCodes spinning, available RAM 15608, slot 0
                                          Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00400003 BFAR 0xe000ed38 SP 0x2001ffa8 Task MAIN Freestk 29378 ok
                                          Stack: 20008e54 20008e50 1cc5b538 00000004 0000000a ffffffed 0040f1f8 010f001f 20008e54 20003440 20008110 20004494 a5a5a5a5 ffffffed 00000000 00f00000 e000ef34 c0000000 20004690 004548f5 0045465c 61000000 ffffffff ffffffff ffffffff ffffffff ffffffff
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          MCU temperature: min 24.0, current 24.4, max 25.2
                                          Driver 0: position 62528, standstill, SG min/max not available
                                          Driver 1: position 62528, standstill, SG min/max not available
                                          Driver 2: position 62528, standstill, SG min/max not available
                                          Date/time: 2021-01-08 15:43:37
                                          Cache data hit count 105466486
                                          Slowest loop: 4.99ms; fastest: 0.20ms
                                          === Storage ===
                                          === MainDDARing ===
                                          === AuxDDARing ===
                                          Segments left: 0
                                          === Network ===
                                          Slowest loop: 16.01ms; fastest: 0.00ms
                                          - WiFi -
                                          WiFi flash size 4194304, free heap 22320
                                          WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
                                          • bwnanceundefined
                                            bwnance
                                            Anotha one.
                                            M122
                                            Static ram: 23460
                                            Never used RAM 15852, free system stack 193 words
                                            Tasks: NETWORK(ready,194) HEAT(blocked,307) MAIN(running,456) IDLE(ready,19)
                                            Owned mutexes:
                                            Last reset 00:00:21 ago, cause: software
                                            Last software reset at 2021-01-08 16:41, reason: HardFault invState, GCodes spinning, available RAM 15608, slot 1
                                            Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x0041f803 BFAR 0xe000ed38 SP 0x200043e0 Task MAIN Freestk 976 ok
                                            Stack: 00000002 200099c0 00000100 00000000 200178b8 0042d68f 00000000 600f0000 0042d75a 610f0000 ffffffff 0000000a 010095c8 20008e54 00000000 00000000 00000000 00454a15 20008e54 00000000 20008e54 00454daf 200099c4 00454f3b 00000000 ffffffff 200099c0
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            MCU temperature: min 24.0, current 24.6, max 25.0
                                            Supply voltage: min 24.0, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                            Date/time: 2021-01-08 16:42:20
                                            Cache data hit count 25138224
                                            Slowest loop: 4.94ms; fastest: 0.20ms
                                            === Storage ===
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            === Network ===
                                            Slowest loop: 15.68ms; fastest: 0.00ms
                                            - WiFi -
                                            WiFi flash size 4194304, free heap 22400
