    Duet 2 Wifi rebooting/crashing during print
    Beta Firmware
    crash firmware hardware
    2.2k
    • bwnanceundefined
      bwnance
      I also just remembered that the other change I did around the time the crashes started was swapping to a mosquito hotend.
      I should also probably post what my machine is:
      Custom Delta
      Duet 2 Wifi
      duet smart effector
      24v 350w meanwell PSU
      berd air max
      mosquito mounted with the 713maker smart effector adapter
      24v heated bed, wired directly into the duet
      e3d hemera, mounted as a flying extruder
      paneldue 7i
        Neither the bird air nor the osquito seem likely to cause the fault.
        Will have to wait to see what @dc42 thinks of the error message.
        In the meantime, please continue to gather M122 reports if it crashes.
        Perhaps share a gcode file that produces the crash.
        bwnanceundefined 1 Reply Last reply Reply Quote 0
        • bwnanceundefined
          bwnance @Phaedrux
          @Phaedrux
          Another crash from this morning (berd air still connected)
          The gcode file is too large to attach here -- is there a preferred hosting site for me to upload the file?
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 08DJM-9178L-L2MSD-6J1FA-3S46N-KSFYP
          Used output buffers: 3 of 24 (11 max)
          Static ram: 27980
          Dynamic ram: 93236 of which 60 recycled
          Exception stack ram used: 480
          Never used ram: 9316
          Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1848) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:12:58 ago, cause: software
          Last software reset at 2020-11-05 11:55, reason: Hard fault, spinning module PrintMonitor, available RAM 8996 bytes (slot 1)
          Software reset code 0x4069 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x0441f803 BFAR 0xe000ed38 SP 0x20005414 Task MAIN
          Stack: 0042eaf1 20003d50 60030000 00000001 00000009 00000014 0044eaab 0044eaae 21030000 3f000000 41492f1a
          Error status: 0
          MCU temperature: min 24.1, current 28.4, max 28.7
          Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/158
          Driver 1: standstill, SG min/max 5/150
          Driver 2: standstill, SG min/max 0/166
          Date/time: 2020-11-05 12:08:02
          Cache data hit count 1269324432
          Slowest loop: 5.60ms; fastest: 0.14ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.2ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 19944ms
          === MainDDARing ===
          Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.91ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address dc:4f:22:6e:6c:ca
          WiFi Vcc 3.43, reset reason Unknown
          WiFi flash size 4194304, free heap 21840
          WiFi IP address 192.168.86.26
          WiFi signal strength -53dBm, reconnections 0, sleep mode modem
          Socket states: 4 0 0 0 0 0 0 0
            Phaedrux Moderator @bwnance
            @bwnance said in Duet 2 Wifi rebooting/crashing during print:
            You may be able to zip it and change the file extension to .txt and upload it here if it's within 4Mb (i think) otherwise dropbox or google drive.
            • bwnanceundefined
              bwnance @Phaedrux
              @Phaedrux
              Good call! Attached is the zipped gcode file, renamed to .txt:
              vibrationDampener2.gcode.txt
                What's in the macro here:
                M98 P"0:/macros/start.g"
                • bwnanceundefined
                  bwnance @Phaedrux
                  @Phaedrux
                  I've got a little bit of a macro tree:
                  start.g:
                  G28
                  M98 P"0:/macros/brushclean.g"
                  M98 P"0:/macros/bottomhome.g"
                  G29 S1 ; load height map
                  brushclean.g:
                  G0 Z25 F12000
                  M564 S0 ; disable limits
                  G0 X0 Y0 Z12 F3000 ; middle of bed, z=5
                  G0 X0 Y-130 ; middle of brush
                  G0 Z8 ; drop nozzle slightly
                  G0 X15 ;
                  G0 Y-128 X-15
                  G0 Y-125 X15
                  G0 Y-125 X0
                  G0 Z12
                  G0 X0 Y0
                  M564 S1 ; enable limits again
                  bottomhome.g:
                  M106 P0 S0
                  G0 Z25 F12000
                  G30
                  G0 Z15 F12000
                  • bwnanceundefined
                    bwnance
                    @Phaedrux @dc42 Hey y'all, just bumping this again -- here's another crash report from today, along with the offending gcode:
                    tree_new.txt
                    Static ram: 27980
                    Exception stack ram used: 304
                    Never used ram: 9492
                    Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                    Last reset 00:29:46 ago, cause: software
                    Last software reset at 2020-12-14 23:54, reason: Hard fault, spinning module GCodes, available RAM 8940 bytes (slot 2)
                    Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x04427003 BFAR 0xa5a5a5a5 SP 0x2001ffbc Task MAIN
                    Stack: 0040f451 0040f452 0100001f 200052f0 200052ef 20008c2c 20003d50 a5a5a5a5 ffffffed 00000000 00f00000
                    Error status: 0
                    MCU temperature: min 23.4, current 28.8, max 29.5
                    Date/time: 2020-12-15 00:24:45
                    Cache data hit count 2932587391
                    Slowest loop: 3.44ms; fastest: 0.14ms
                    === Storage ===
                    SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 15.73ms; fastest: 0.00ms
                    - WiFi -
                    WiFi flash size 4194304, free heap 21056
                    WiFi IP address 192.168.86.34
                    WiFi signal strength -57dBm, reconnections 0, sleep mode modem
                    • bwnanceundefined
                      bwnance
                      and another one just now, the more the merrier, i guess
                      Static ram: 27980
                      Exception stack ram used: 472
                      Never used ram: 9324
                      Tasks: NETWORK(ready,408) HEAT(blocked,1224) MAIN(running,1840) IDLE(ready,80)
                      Last reset 00:00:37 ago, cause: software
                      Last software reset at 2020-12-15 02:33, reason: Hard fault, spinning module none, available RAM 8892 bytes (slot 3)
                      Software reset code 0x4071 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0441f003 BFAR 0x91200200 SP 0x2001ff8c Task NETW
                      Stack: 00454e15 00454e20 6100000e 40090000 0041d011 00000000 20002860 10000000 2000b98c 00000000 200034f0
                      Error status: 0
                      MCU temperature: min 24.2, current 24.8, max 25.0
                      Driver 0: ok, SG min/max not available
                      Driver 1: ok, SG min/max not available
                      Date/time: 2020-12-15 02:34:35
                      Cache data hit count 58687792
                      Slowest loop: 3.66ms; fastest: 0.14ms
                      === Storage ===
                      Free file entries: 8
                      SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                      Hiccups: 0(0), FreeDm: 166, MinFreeDm: 166, MaxWait: 18624ms
                      === MainDDARing ===
                      Scheduled moves: 1, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by HTTP
                      HTTP is idle in state(s) 1 0 8, running macro
                      === Network ===
                      Slowest loop: 15.75ms; fastest: 0.00ms
                      Responder states: HTTP(2) HTTP(4) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                      - WiFi -
                      WiFi flash size 4194304, free heap 21408
                      WiFi signal strength -55dBm, reconnections 0, sleep mode modem
                      Socket states: 4 2 0 0 0 0 0 0
                      • markzundefined
                        markz
                        Since no one has jumped in here, my usual opinion when I see something like this is that (assuming the board is ok) it's either a power supply issue or a voltage noise issue.
                        How much power does your heated bed use? Is it enough to impact the power supply?
                        How is the 24V to the pump connected? Could noise on the 24V line be caused by the pump pwm?
                        • bwnanceundefined
                          bwnance @markz
                          @markz
                          Resistance on my heated bed (measured at connector on board) is 3.3ohms, it's a 24v bed, so that would be a ~175watt bed, correct? I'm using a Mean Well 24v 350w PSU and my hotend is 50w, so i should have plenty of extra room, wattage wise, right?
                          24v to the pump is over a fan header on the board (AFAIK newer duets have the flyback diode on all fan inputs internally), I'm not sure how to diagnose if i have noise on the 24v line.
                          markzundefined 1 Reply Last reply Reply Quote 0
                          • markzundefined
                            markz @bwnance
                            @bwnance thanks.
                            The pump has two inputs (kind of) power and control. I know the control line goes to the fan pins but where do you pull off the 24V supply for the pump - is that from the power supply or the duet board somewhere? Are you getting the 24v from the fan header?
                            • bwnanceundefined
                              bwnance @markz
                              @markz I'm not using "EZ-Switch" board that was packaged with the berd-air, so both lines are hooked up to the fan header -- as best as i could tell before installing, this was fine, since the fan headers have flybacks wired into them
                                Can you try 3.2 Beta 4? It's believed that a fix for this crash may already be present there.
                                https://github.com/Duet3D/RepRapFirmware/releases
                                • bwnanceundefined
                                  bwnance @Phaedrux
                                  @Phaedrux just upgraded, will do a few test prints! We shall see...
                                    @bwnance Just realized there is an odd ordering problem on that page that doesn't list the most recent at the top.
                                    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2beta4.1
                                    Beta 4.1 can be found here.
                                    • bwnanceundefined
                                      bwnance @Phaedrux
                                      @Phaedrux ah, ty! gonna let this print finish on beta 4, then will update to 4.1
                                      • bwnanceundefined
                                        bwnance
                                        @Phaedrux was out of town for the holidays, just started a 4 hour print and the printer rebooted ~40mins in
                                        m122
                                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta4 running on Duet WiFi 1.02 or later
                                        Used output buffers: 3 of 24 (12 max)
                                        Static ram: 24108
                                        Dynamic ram: 99836 of which 60 recycled
                                        Never used RAM 6044, free system stack 106 words
                                        Tasks: NETWORK(ready,183) HEAT(blocked,308) MAIN(running,451) IDLE(ready,20)
                                        Last reset 00:01:49 ago, cause: software
                                        Last software reset at 2021-01-07 01:30, reason: AssertionFailed, GCodes spinning, available RAM 5836, slot 1
                                        Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x200044ac Task MAIN
                                        Stack: 00000c55 00472af0 00452a9d 2000ae20 00000000 200094c8 00000000 00000000 00451edb 00000000 ffffffff 2000ae20 200034cc 200094c8 ffffffff 00000000 20004524 a5a5a5a5 00451f1b 20004514 200094b8 20008380 0044f543 20008380 0042ee47 2001e448 200094bc
                                        Error status: 0x00
                                        MCU temperature: min 25.0, current 25.2, max 26.1
                                        Driver 0: position 63150, standstill, SG min/max 0/138
                                        Driver 1: position 63150, standstill, SG min/max 0/133
                                        Driver 2: position 63150, standstill, SG min/max 0/156
                                        Driver 3: position 0, standstill, SG min/max not available
                                        Driver 4: position 0, standstill, SG min/max not available
                                        Driver 5: position 0
                                        Driver 6: position 0
                                        Driver 7: position 0
                                        Driver 8: position 0
                                        Driver 9: position 0
                                        Driver 10: position 0
                                        Driver 11: position 0
                                        Date/time: 2021-01-07 01:32:29
                                        Cache data hit count 170332161
                                        Slowest loop: 3.51ms; fastest: 0.17ms
                                        === Storage ===
                                        SD card longest read time 1.1ms, write time 0.0ms, max retries 0
                                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 22002ms
                                        === MainDDARing ===
                                        Scheduled moves 5, completed moves 5, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                        === AuxDDARing ===
                                        Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                        Segments left: 0
                                        LCD is idle in state(s) 0
                                        === Network ===
                                        Slowest loop: 15.70ms; fastest: 0.00ms
                                        - WiFi -
                                        WiFi firmware version 1.25beta0
                                        WiFi Vcc 3.43, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 19552
                                        WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
                                        Clock register 00002002
                                        I see that 4.2 was just released so i'll update to that and try again.
                                        • bwnanceundefined
                                          bwnance
                                          @Phaedrux no dice, another crash. @dc42 any ideas?
                                          M122
                                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
                                          Static ram: 23460
                                          Dynamic ram: 72744 of which 60 recycled
                                          Never used RAM 15816, free system stack 99 words
                                          Tasks: NETWORK(ready,157) HEAT(blocked,307) MAIN(running,450) IDLE(ready,19)
                                          Owned mutexes:
                                          Last reset 00:01:12 ago, cause: software
                                          Last software reset at 2021-01-07 19:24, reason: HardFault invState, GCodes spinning, available RAM 15608, slot 1
                                          Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x0041f003 BFAR 0xe000ed38 SP 0x2001fe90 Task MAIN Freestk 29308 ok
                                          Stack: 00000000 00000001 400e1400 00001000 3ed0bedf 0044adf3 2001ff28 400f0227 00000160 00000100 2001db10 fffffff1 000001ab 00000000 00a69e38 0000012b 2001c8b8 38000000 005a0073 00000001 28bb5437 fffffffb 29767437 2000770e 2001ff28 01000001 2001ff28
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          MCU temperature: min 24.9, current 25.4, max 26.0
                                          Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                          Driver 0: position 63150, standstill, SG min/max 0/147
                                          Driver 1: position 63150, standstill, SG min/max 0/131
                                          Driver 2: position 63150, standstill, SG min/max 0/157
                                          Date/time: 2021-01-07 19:25:21
                                          Cache data hit count 87576278
                                          Slowest loop: 4.81ms; fastest: 0.20ms
                                          === Storage ===
                                          DMs created 83, maxWait 11729ms, bed compensation in use: none, comp offset 0.000
                                          === MainDDARing ===
                                          Scheduled moves 5, completed moves 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                          === AuxDDARing ===
                                          Segments left: 0
                                          === Network ===
                                          Slowest loop: 15.95ms; fastest: 0.00ms
                                          - WiFi -
                                          WiFi flash size 4194304, free heap 19568
                                          WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
                                          • Vetiundefined
                                            Veti
                                            can you post a picture of your wiring on the duet?
