Duet 3 Enclosure for PI + 7" Touchscreen Display
Hi All,
Before I go and spend a lot of time on something that someone much more skilled than I already solved, I thought it smart to check.
Has anyone already designed an enclosure for the Duet 3 + Raspberry PI + 7" touch screen display.
Thanks!
Sylvain
Do you mean all in one? I've never seen one like that.
Screen and controller in the same enclosure? Sounds unpractical or at least like an untraditional placement of the controller?
Afaik you can get step files for both the duet and the pi to help with the design. Can probably find something for the screen depending on the type as well.
I use a duet 3 and 5" touch screen. It works perfectly fine
@Phaedrux , @bearer I thought something like this would look cool https://www.thingiverse.com/thing:3206822.. But I guess you guys are right and having a separate box for the PI + Duet is preferable over an all in one solution.
@dhusolo , do you use an enclosure, if so, can you point me to it?
@sylvaindc said in Duet 3 Enclosure for PI + 7" Touchscreen Display:
not necessarily, it depends on how you'd want to lay out the machine, where its placed etc. I prefer to have to display higher up than the prusa/ender type front display so moving the controller along with it makes little sense to me.
