Connecting a Duet WiFi to a network that requires an ID and Password
  • I ran into a problem trying to add the 3D printer to the network of a University, they require everyone to have an individualized ID and Password. Going through the set up processes I dont see an option for this all I can do is select the WiFi and insert a password but it wont let it though unless it recieves an ID with it. Is there another way around this?
    As it stands you cannot connect the wifi to a network that needs a user name and password. In general this is not a good idea anyway as the DuetWifi is more secure if you keep it on a local network, rather than a large university network. Your best best is to use it in access point mode (you will need to use firmware version 1.19 for this.
