    Printing too high.
    1.6k
    • evilfknpotatoundefined
      evilfknpotato
      Hello, I am new to Duet and so far am really liking it and a much better experience/UI for a newbie.
      However I have almost successfully set up my printer but it prints way too high (~5mm) above bed. When I move the printer to Z0 it is at perfect height but when I start printing it doesn't want to comply.
      I am using an Ender 3 with BLTouch, Duet Maestro with firmware 2.01beta1(RTOS) (2018-06-23b1) and Cura
        evilfknpotato
        ; Configuration file for Duet Maestro (firmware version 2.03)
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Nov 02 2020 15:23:04 GMT+1000 (AEST)
        M550 P"MDAero Ender 3" ; set printer name
        M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P0 S1 ; physical drive 0 goes backwards
        M569 P1 S1 ; physical drive 1 goes backwards
        M569 P2 S0 ; physical drive 2 goes forwards
        M569 P3 S1 ; physical drive 3 goes backwards
        M350 X16 Y16 Z16 E128 I1 ; configure microstepping with interpolation
        M92 X80.00 Y80.00 Z400.00 E741.00 ; set steps per mm
        M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z120.00 E5000.00 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor (%)
        M84 S30 ; Set idle timeout
        M208 X235 Y235 Z260 S0 ; set axis maxima
        M574 Z0 S0 ; set active low and disabled endstops
        M574 X1 Y1 S1 ; set active high endstops
        ;M307 H3 A-1 C-1 D-1
        M558 P9 H5 F120 T6000 ; set Z probe type to bltouch & the dive height + speeds
        G31 P500 X-44 Y-16 Z3.2 ; set Z probe trigger value, offset and trigger height
        M557 X10:190 Y10:190 S20 ; define mesh grid
        ;M557 X10:190 Y10:190 S45 ; define mesh grid
        M305 P0 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 0
        M143 H0 S80 ; set temperature limit for heater 0 to 80C
        M305 P1 T98801 B4185 R2200 ; set thermistor + ADC parameters for heater 1
        M143 H1 S250 ; set temperature limit for heater 1 to 250C
        M106 P0 C"PCF" S0 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 C"HEF" S1 I0 F500 H1 T45 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 C"ECF" S1 I0 F500 H1:0 T45 ; set fan 2 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 S"Hotend" D0 H1 ; Define tool 0
        M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          evilfknpotato
          ; Ender 3 Custom Start G-code
          M140 S{material_bed_temperature_layer_0} ; start preheating the bed
          M104 S{material_print_temperature_layer_0} T0 ; start preheating hotend
          G28 ; Home all axes, BLTouch
          G29 S1; BLTouch do full bed level
          M190 S{material_bed_temperature_layer_0} ; heat to Cura Bed setting
          M109 S{material_print_temperature_layer_0} T0 ; heat to Cura Hotend
          G92 E0 ; Reset Extruder
          G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
          G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
          G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
          G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
          G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
          G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
          GCODE Flavour: RepRap
            Your firmware is quite old. It would be a good idea to update it.
            Download that zip file and then upload it to the system tab in the web interface. Don't extract it. Just upload the whole zip file. It should update the firmware and web interface for you.
            As for why it's printing 5mm too high, post your homeall.g file so we can see what you're homing routine looks like.
            If you tell the Z axis to move up a certain amount, does it actually move the correct amount if you measure it?
            It looks like you're loading a saved heightmap for mesh compensation. It might not hurt to redo the mesh in case the Z axis wasn't set correctly when it was originally created.
              evilfknpotato
              Thank you @Phaedrux! i just updated that firmware, so easy
              Yes i have tried to redo the mesh and comes out the same
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Nov 02 2020 15:23:05 GMT+1000 (AEST)
              G91 ; relative positioning
              G1 H1 X-240 Y-240 F3000 S1 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F6000 ; go back a few mm
              G1 H1 X-240 Y-240 F240 S1 ; move slowly to X and Y axis endstops once more (second pass)
              ;G1 H1 Z-265 F240 ; move Z down stopping at the endstop
              G90 ; absolute positioning
              G1 X161.5 Y133.5 F3000
              M558 F400
              G30
              M558 F100
              G30
              G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
              G29 S1 ; Load heightmap and enable mesh grid compensation
              G28 XY
              G1 X10 Y10 Z10 F6000 ; return head to park position
              ;G91 ; relative positioning
              ;G1 Z5 F100 ; lift Z relative to current position
              ;G90 ; absolute positioning
                evilfknpotato
                also; after updating the motors are making a terrible noise when moving
                  Phaedrux Moderator @evilfknpotato
                  @evilfknpotato said in Printing too high.:
                  G30
                  Remove the G92 Z0 since you're using the probe with G30 to set the Z height, you don't want to over ride it with that G92 command.
                  The trigger height of the probe needs to be calibrated and put in G31.
                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                  When that is set correctly, G30 should set the Z height correctly and you won't need any G92 Z to force a height. (that's more common when using an endstop switch instead of a probe).
                  This could explain why it's not printing at the right height.
                  Please send M115 to confirm your firmware version.
                  Send M98 P"config.g" and report the results.
                  Did anything else change?
                    evilfknpotato
                    g31 trigger height is 8mm where does this go?
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-02-09b1
                    M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                    Warning: Macro file config-override.g not found
                      evilfknpotato
                      nothing else changed so far except the beautiful new UI, but the motor noise doesn't sound healthy
                        8mm? Are you sure about that? When mounted correctly as suggested by Antclabs the BLTouch body should be 8mm above the nozzle which leads to a trigger height of about 2mm.
                        evilfknpotatoundefined 1 Reply Last reply Reply Quote 0
                          Which motor? All of them? What moves are you doing?
                          Can you record a video to show it?
                            evilfknpotato @Phaedrux
                            @Phaedrux yes that seems correct its a stock creality metal mount and re measured and the trigger height is correct at 3.2mm
                              @Phaedrux all of them on homing and g1 moves
                              How do I upload a video?
                                Alright, so with that G92 Z0 removed from the homeall.g file does the nozzle touch the bed when you tell it to move to the Z0?
                                On a desktop you can drag and drop a file onto the post text box to upload it, or you can put it on dropbox or google drive if it's too big and share a link.
                                  evilfknpotato
                                  yes it always did move to Z0 before printing and now it prints at correct height thank you so much!
                                  Now its just the strange motor problems, if it were my wiring it would have done this before updating firmware. uploading video
                                    evilfknpotato
                                    IMG_9326.MOV.mp4
                                      Maybe if have to compare to how it sounded before but that doesn't sound too bad to me.
                                      You can try reducing the motor current a bit. Try 600 or 700 instead of 800.
                                        @Phaedrux it was silent before this sounds like back emf or something
                                          evilfknpotato @evilfknpotato
                                          @evilfknpotato reduced current to 600 and still the same
                                            evilfknpotato
                                            is it worth upgrading to v3.0?
