    Pause print on driver overheat?
    620
    • Gerrardundefined
      Gerrard
      SHORT STORY:
      Is there a way to take some action when an over temp shut down occurs? Can I pause the job or wait to cool down etc?
      BACK STORY:
      I've been troubleshooting a problem on my custom build corexy, which involved many failed prints due to skipped steps, so I've upgraded to larger motors (link), and I've set up stall detection. So that will (hopefully) help, but it's not the whole picture.
      This morning I made the mistake of rage killing (power off) the printer when I found it, because it takes too long to kill the print through the web interface (if I don't already have it up and running) - but doing so killed my chance of checking the console for other errors etc.
      When I did unlock my PC I found that I already had the console open and some errors on the screen.
      Drivers 5,6, 7 and 8 are my Z axis motors, driver 9 is not used, but not disabled.
      The short to ground on driver 6 is a concern, but everything seems to be working - wiring looks OK, I'm not sure what to do here. If it happens again I'll replace the motor.
      I noticed looking closely at the failed print that it seems to have stalled in the Z direction (probably due to the over temp shutdown), but continued to print in the X and Y.
      If you look closely at the images below you'll see that the last 2 layers are messy, and in place before the layers start shifting.
      I assume the order of events is something like this:
      • Z axis drivers start to over temp shut down (one at a time or simultaneously I don't know).
      • X and Y continue until print becomes too obstructed, then;
      • X and/or Y fail due to stalling.
      Now that stall detection is configured, I would expect that it would just get stuck in a stall/rehome/retry loop because there is a permanent obstruction.
      SO......
      Config.g below
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Mar 30 2020 11:14:18 GMT+1000 (Australian Eastern Standard Time)
      M550 P"Point Zero CoreXY" ; set printer name
      M667 S1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes backwards
      M569 P5 S0 ; physical drive 5 goes backwards
      M569 P6 S0
      M569 P7 S0
      M569 P8 S0
      M569 P4 S0 ; physical drive 3 goes backwards
      M584 X1 Y0 Z5:6:7:8 E4 ; set drive mapping
      M671 X200,400,200,400 Y-60,-60,875,875 ; Set location of z leadscrews for independant bed levelling.
      M92 X80.00 Y80.00 Z1600.00 E412.0 ; set steps per mm
      M566 X600.00 Y600.00 Z20.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) *** PREVIOUS VALUES X&Y:600 Z12 E900
      M203 X8000.00 Y8000.00 Z400.00 E1500 ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z100.00 E600.00 ; set accelerations (mm/s^2) *** PREVIOUS VALUES X400 Y400.00 Z10.00 E150.00
      M204 P1200 T4000 ; print and travel acceleration
      M906 X1600 Y1600 Z600 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M593 F80 ; Set Dynamic Acceleration Adjustment
      M572 D0 S0.05 ; Set extruder pressure advance
      M915 P0:1 S5 F1 H200 R1 ; Set up stall detection
      M208 X860 Y800 Z750 S0 ; set axis maxima
      M574 X1 Y1 S1
      M574 Z0 S0 ; set active high endstops
      M591 D0 P5 C3 R5:120 E20.0 S1 ; Configure Laser filament sensor for extruder drive 0.
      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-21.6 Y9.4 Z3.2 ; set Z probe trigger value, offset and trigger height - **PREVIOUS Z VALUE = Z1.35
      M557 X40:800 Y40:760 S78 ; define mesh grid - AS DESIGNED
      ;M557 X270:530 Y270:530 S52 ; define mesh grid - FOR TESTING ONLY
      M376 H5 ; Set bed compensation taper (layers to fade out bed compensation)
      G29 S1
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H2 S280 ; set temperature limit for heater 1 to 280C
      M305 P101 S"Duet 2" T100000 B4725 R4700 ; Duet 2 Drivers Over Temp Warning
      M305 P102 S"Duex 5" T100000 B4725 R4700 ; Duex 5 Drivers Over Temp Warning
      M106 P0 S0 I0 F25000 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P1 D0 H2 F0 ; define tool 1
      G10 P1 X0 Y20 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0
      • Vetiundefined
        Veti
        this to me suggest that you need to cool the stepper drivers regardless.
        a fan should blow across the underside of the duet board where the steppers are.
        Gerrardundefined 1 Reply Last reply Reply Quote 0
        • Gerrardundefined
          Gerrard @Veti
          @Veti perhaps... but is there nothing that I can do to pause the job should an overheat even occur?
          Also - should I have installed the heat sinks on the underside instead of the top side????
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @Gerrard
            @Gerrard said in Pause print on driver overheat?:
            do you by chance have a cloned board? they cheap out on the copper in the pcb which means the heatsink design does not work as intended.
            • Gerrardundefined
              Gerrard @Veti
              @Veti I do...
              I'm assuming there's nothing I can do about pausing...
              • Vetiundefined
                Veti @Gerrard
                @Gerrard
                you could potentially write a macro and execute that on layer change, but that is more of a bandaid.
                you need to address the real problem and cool the board.
                using an case like this for example
                https://www.thingiverse.com/thing:3721923
                • Gerrardundefined
                  Gerrard @Veti
                  @Veti So the board is setup on a bench, with heat sinks and a fan blowing across - it's not ducted, but there's plenty of air flow.
                  What would this macro look like?
                    Your motor current on Z is set to 600ma but your link for the motors indicate they are rated at 2100ma. So your Z motors are very likely stalling, hence the warnings.
                    Target ~80% of rated, so 1600ma
                    Those errors may have been from after the reboot due to the hard power off during a stall. Before worrying about how to pause during an overheat situation try giving the motors the right current and see if they still stall. It's likely a non-issue.
                    Cooling is good idea either way, but I don't think it's actually an overheating issue in normal operation here.
                    By the way in your other thread about stall detection I did ask
                    "Motor currents should be around 80% off rated max. Did you change the config for the new motors?"
                    • Gerrardundefined
                      Gerrard @Phaedrux
                      @Phaedrux Sorry for the confusion... those 2100mA motors were for the X and Y.
                      These are the motors for the Z axis.
                      I take your point on motor current for these too - I've now set that to 1200mA (80% of 1500mA).
                      Still doesn't give me a lot of confidence - if the Z motors fail again (and they could), then I have a guaranteed crash. But if there's nothing I can do about it, then so be it.
                      Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        Phaedrux Moderator @Gerrard
                        Well running them at half the ideal current is likely the biggest issue. Once given enough current they should be more reliable. However if the bed is large and heavy those motors may be a bit anemic.
                        Before trying a long test print again I would suggest running a dry print with no filament loaded. (turn off the heaters and enable cold extrusion (M302 P1) to prevent it from halting on error).
                          Well the thing to do about it is try to make it reliable in the first place. As I said, I don't think the errors you saw were indicative of what was actually happening during the print.
                          Give the motors the current they need, cool the board, and there should be no more stalls to detect or pauses on overheat needed. Besides, if there were an actual overheat or driver error I am pretty sure the print would halt anyway.
                          It's actually really hard to trigger overheat warnings on the drivers. We're talking over 100c.
                          • Gerrardundefined
                            Gerrard
                            I'm referring to an insurance policy, but i've made the suggested changes, so we'll see how it goes.
                            Vetiundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
                              @dc42 what exactly happens if a driver overheat happens during a print? Or short to ground for that matter?
                                Reports of all 5 drivers on the DueX being over temperature suggest either that the drivers are actually cool and it is the SPI communication or power feed to the DueX5 that has broken down, or the drivers really are hot because a transient has killed all the drivers.
                                  dc42 administrators @Phaedrux
                                  @Phaedrux said in Pause print on driver overheat?:
                                  An overheat warning just produces a message. An overheat error or short to ground shuts down the driver until VIN power is removed.
                                  • Vetiundefined
                                    Veti @Gerrard
                                    @Gerrard
                                    post a picture of your wiring
                                    • engikeneerundefined
                                      engikeneer @Gerrard
                                      @Gerrard I think its already been answered by dc42, but I quite often get those over temp and short to ground errors on my Duet WiFi when I hit the Estop. I have a separate 5v power to the Duet so the processor and web control stay on and I can see them. In my case there definitely isn't a short to ground and the temperatures are all low/stable.
                                      The Duet is designed so that the driver chips conduct heat to the back surface of board (hence you cool the board) not the drivers directly. See https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Mounting_1
                                      One other benefit of this is you can get a reasonable idea of how hot things get over time (transients less so) by looking at the CPU temperature. If doing this though, I would recommend calibrating the CPU temp (follow this guide https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature)
                                      Side note on the cloned boards. The blue heatsinks they ship with probably make the cooling situation worse. Most people stick them on top of the drivers (plastic surface so doesn't conduct heat very well) and they tend to block any good cooling airflow over the board.
                                      Also, I recommend double checking all the soldering joints on the bottom of the board. I have a clone board and found it had a couple of bad/dry joints on the heater pins
                                      i3 clone with a bunch of mods
