    migrate config.g
    1.5k
    • Tinchusundefined
      Tinchus @Phaedrux
      @Phaedrux Im super confused. I downloaded the new raspi image, I did the upgrades (they are launched in the we interface at the first boot, nice!)
      After reboot I uploaded my config files.
      1.- problem: I noticed there is no ssh connection available
      2.- I tried to do a homeing: HOME ALL
      I get this error:
      Error: G0/G1: insufficient axes homed
      My homeall.g was working ok before:
      ; homeall.g
      ; called to home all axes
      M280 P0 S92
      T0 P0
      ; Calibration of motor currents etc
      G91
      G1 H2 Z0.02 F500
      G4 P150
      G1 H2 X0.02 F2000
      G4 P150
      G1 H2 Y0.02 F2000
      G4 P150
      M400
      M913 X60 Y60 ; drop motor current to 60%
      M400
      ; HOME X/Y
      G1 H1 Y-400 X-400 F10000 ;
      G1 Y175 X175 F5000 ;
      M400
      G1 H1 Y-400 F10000
      G1 Y175
      G1 H1 X-400 F10000
      G1 X175
      M400
      G90 ; absolute positioning
      M400
      M913 X100 Y100 ; drop motor current to 100%
      M400
      ; Z HOMING
      ; G1 X175 Y175 F5000 go to first bed probe point and home Z for beta3
      G1 X135 Y100 F5000 ; for beta4
      G30
      Home X and Y reports the same error. The files were also working ok.
      the files:
      ; homex.g
      ; called to home the X axis
      M280 P0 S92
      T0 P0
      G91
      G1 H2 Z0.02 F500
      G4 P150
      G1 H2 X0.02 F2000
      G4 P150
      G1 H2 Y0.02 F2000
      G4 P150
      G1 X50 F5000
      M400
      M913 X60 Y60
      G1 H1 X-400 F10000
      G90
      M913 X100 Y100
      G1 X175 F4000
      M400
      M280 P0 S92
      T0 P0
      G91
      G1 H2 Z0.02 F500
      G4 P150
      G1 H2 X0.02 F2000
      G4 P150
      G1 H2 Y0.02 F2000
      G4 P150
      M400
      G1 Y50 F5000
      M400
      M913 X60 Y60
      G1 H1 Y-400 F10000
      G90
      M913 X100 Y100
      G1 Y175 F4000
      M400
      The M122 reports this:
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6JTD2-3SJ6J-1A6GG
      Used output buffers: 1 of 40 (10 max)
      Static ram: 154604
      Dynamic ram: 162568 of which 68 recycled
      Exception stack ram used: 412
      Never used ram: 75564
      Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1460) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:07:48 ago, cause: power up
      Last software reset at 2020-11-20 19:38, reason: User, spinning module LinuxInterface, available RAM 75160 bytes (slot 2)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 34.3, current 39.6, max 39.7
      Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Driver 0: standstill, reads 10286, writes 22 timeouts 0, SG min/max 0/92
      Driver 1: standstill, reads 10287, writes 22 timeouts 0, SG min/max 0/90
      Driver 2: standstill, reads 10289, writes 20 timeouts 0, SG min/max 0/1023
      Driver 3: standstill, reads 10290, writes 20 timeouts 0, SG min/max 0/1023
      Driver 4: standstill, reads 10295, writes 15 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 10296, writes 15 timeouts 0, SG min/max 0/0
      Date/time: 2020-11-21 00:31:26
      Slowest loop: 4.03ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 374, MaxWait: 98508ms
      === MainDDARing ===
      Scheduled moves: 13, completed moves: 13, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 0 -1 -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.82ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 0 of 8
      • Ethernet -
        State: disabled
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 1785, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 17ms ago
        RX/TX seq numbers: 14410/14411
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.1.1
        Code buffer space: 4096
        Configured SPI speed: 8000000 Hz
        Full transfers per second: 25.35
      Thanks in advance
        When connected to the DWC, the system tab on the left side is used to show you your config and homing files. Is that where you are editing your files?
        Your homing files isn't quite right for corexy.
        ; HOME X/Y
        This section will home both x and y but will stop both axis when either one hits. So the second move at least one of the axis will not yet be homed.
        Use something like this instead for corexy
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_homeall_g_file
        G91 ; relative mode
        G1 H1 X-240 Y-240 F3000 ; coarse home X or Y
        G1 H1 X-240 ; coarse home X
        G1 H1 Y-240 ; coarse home Y
        G1 X4 Y4 F600 ; move away from the endstops
        G1 H1 X-10 ; fine home X
        G1 H1 Y-10 ; fine home Y
        ''' Z homing section follows'''
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @Phaedrux
          @Phaedrux
          I did foloowed those instructions:
          "On a CoreXY printer, the whole move will be terminated when the first homing switch is triggered. Therefore, to do simultaneous XY homing, your homeall.g file needs to first home X and Y together, then home them separately. " My homeall.g is the same, I just changed the number:
          ; HOME X/Y
          G1 H1 Y-400 X-400 F10000 ; Home at the same time as the instructions says
          G1 Y175 X175 F5000 ; Dont remember why but I added this just to move the carriage to the "center"
          M400; this is not necessary I guess
          G1 H1 Y-400 F10000 ; and from here it is as instructed
          G1 Y175
          G1 H1 X-400 F10000
          G1 X175
          M400
          But this is not the problem, question and problems remains: this config works OK when I use it on the duet as stand alone or with octiprint. What Im doing wrong that nothing is working ok with the DWC? All my tool change routines also don't work at all. The servo is not being activated, or it actives and moves to a position and immediately returns to the old position all by itself while the printer is doing nothing.A faulty board can be the reason for this? (I guess no, because as I said, in stand alone or with octoprint it is working ok)
          Z motors don't work for example. I tried switching back to the duet+octoprint just to discard hardware issues, and the Z motors work ok
          More info: if I do a manual tool change, To > T1 the head should move to a position, activate servo to position 47 (lowers the tool).
          When I try to do that, the servo moves, then by itself goes back to original position and then the board resets. These are the messages I see in console when that happens:
          11/21/2020, 7:46:08 AM Warning: Controller has been reset
          11/21/2020, 7:46:08 AM Connection to Duet established
          11/21/2020, 7:46:08 AM Warning: Lost connection to Duet (Board is not available (no header))
          • Tinchusundefined
            Tinchus
            I found many solutions to my problems, I post my findings, it might be useful for somebody:
            .- The ribbon cable used for the SPI connection, it handles high frequency signals, and it is a source os strong "noise". My servo motor is passing just on top of the ribbon cable, and the noise was getting into this cable and making my servo to have this "ghost" movements. I shielded the cable and the problem is gone. This was not happening with the USB connection so the source of the noise comes from the ribbon cable. I will test and watched more closely this flat cable, probably I will shield it too just in caso in order to not get noise in other cables.
            .- The Z motors not working: the same exact config I was using with DUET3 connected by USB to raspberry is not working with duet3 connected through SPI to raspberry and using DWC. I guess the problem is with DWC, because I changed my original config to this:
            350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation. Changed Z to 16 from 32
            ; M92 X160.32 Y160.32 Z3200 E827.22 set steps per mm
            M92 X80.16 Y80.16 Z1600 E428.25:428.25 ; set steps per mm changed Z from 3200 to 1600
            M566 X900.00 Y900.00 Z300.00 E450:450 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z340.00 E2400.00 ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z20 E500.00 ; set accelerations (mm/s^2)
            M906 X1500 Y1500 Z900 E1000:1000 I30
            Notice that I removed the Z configuration. Correct or not, the original configuration was working, on the same duet board, so the problem must bu DWC?
            I hope it helps somebody. I will keep solving issues
              Phaedrux Moderator @Tinchus
              @Tinchus said in migrate config.g:
              ; HOME X/Y
              The first move will only ever home one of the axis, therefore, the following move will provoke the error message because at least one of those axis are not yet homed.
              That's why in the example the following two moves home the axis individually again to ensure that whichever one was missed gets homed.
              It really sounds like the config you're looking at isn't the same as what the duet is executing.
              How are you viewing and editing these files? When you make a change does it actually take effect?
              • Tinchusundefined
                Tinchus @Phaedrux
                @Phaedrux Just to be sure Im ONLY using the duet web interface for editing. And believe it or not... the conf I posted above is working now perfectly.
                I have one not related question: I'm trying to create my own combination of colors for the interface (since I have some color distinctions problems jajaja.... where do I find the CSS file, the ones located at boot/www seems not to be the ones being used
                • A Former User?
                  A Former User @Tinchus
                  boot/www
                  /opt/dsf/sd/www but they should be minimized and less than usefull?
                  https://github.com/Duet3D/DuetWebControl might be more apropriate
                  Tinchusundefined 1 Reply Last reply Reply Quote 1
                  • Tinchusundefined
                    Tinchus @A Former User
                    @bearer You I should rebuild the DWC from scratch? Im a little afraid of doing that after having to do such a work to have my config running.
                    The sd card that came with the board seems to have a 3.2 version of the DWC because I can see that have plugins wich in theory are not suppose to be in 3.1.1 version. After I did a sudo apt updete/upgrade, the DWC seems to be downgraded, but plugins were still working, but everything was very unstable (for example after doing a homing the status remained in "busy" for ever": Installing a fresh duetpi image and doing the upgrade seems to work much better)
                    So in your opinion I can upgrade manually the DWC ? I can see wich version ti is the one available in that github
                      What version of DWC does it report in the interface itself?
                      • Tinchusundefined
                        Tinchus @Phaedrux
                        @Phaedrux Duet Web Control 3.1.1
                          For the time being stick with 3.1.1. The next release 3.2 is around the corner and should improve the Pi experience.
                          There is a dark theme in DWC. I'm kind of hoping for a return of multiple themes in future updates.
