    Duet3+SBC+Pi Cam
    • MaxGyverundefined
      MaxGyver
      I would like to monitor my prints over the duet web interface. Since I am already using a Duet3+SBC I was wondering if the SBC can be used to stream the video of an attached PI Cam.
      I have already tried this tutorial, but I was not able to get it running.
      If someone could point me in the right direction it would be much appreciated
      Cheers,
      Mac
        Check out motion
        https://motion-project.github.io/motion_config.html#top
        MaxGyverundefined 1 Reply Last reply Reply Quote 0
        • Frederikundefined
          Frederik
          i tried the same with my Raspberry Pi 3b+ and the new Pi Cam v2 with 8MP Sensor and the MakerHawk Wide Angle Lens 165°
          I used this WebInterface:
          https://github.com/silvanmelchior/RPi_Cam_Web_Interface
          it works realy well, because you dont have to go in the Linux Terminal to change Camera Settings. It all works over the Duet Webcam Field.
          I used port 8081 but that is up to your preferences.
          Regards
          Frederik
          • MaxGyverundefined
            MaxGyver @Phaedrux
            @Phaedrux Thank you!
            After trying about a dozen different tutorials on how to install and configure motion I found one that worked for me.
            Motion setup tutorial
            Cheers
            Max
