Having problems with the bltouch, duet 2 wifi
can anyone see what the problem is with my system.g folder, and tell what to do too get the bltouch too work propperly. it seems like everything works fine when i control the probe manually. but if i try too home it, it won't deploy
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y50 Z0 S1 ; set axis minima
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
M574 Z1 S1 P"null" ; configure active-high endstop for low end on Z via pin null; Z-Probe
M558 P5 C"^e1temp" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X10 Y50 Z3 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y65:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
@remixbot said in Having problems with the bltouch, duet 2 wifi:
This looks weird (at least for me). I would use Z probe input, not thermistor input. Also I do not see M950 for servo pin controlling bltouch defined.
How do You control it manually? Do You have deploy.g and retract.g files?
There is an example also how to set this up:
M558 P9 C"^zprobe.in" H5 F120 T3000 ; BLTouch connected to Z probe IN pin M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector ... M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
i used probe.in for the black and white wires here earlier, so i just had to try something else. but no im not currently using the deploy\retractprobe.g at the moment.
@remixbot So connect it back to z probe input, and servo pin to the right pin in expansion header.
Add to config:M558 P9 C"^zprobe.in" H5 F120 T3000 ; BLTouch connected to Z probe IN pin M950 S0 C"exp.heater3" ; create servo/gpio 0 on heater 3 pin on expansion connector
or exp.heaterx if other pin is used, create files:
deployprobe.g
M280 P0 S10
retractprobe.g
M280 P0 S90
@BoA here is the setup now.
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop; Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
but im getting
G28 Z
Error: Failed to enable endstopsG28 Z
Error: Failed to enable endstops -
@remixbot Did You create deplyprobe.g and retractprobe.g ?
@BoA yes
Seems You have not defined endstop for Z axis.
AddM574 Z1 S2
the wierd thing is that i can use m401 and 402 and m280 p0 s10\90 without any problem. but it will not trigger when i issue g30 or g31 s-1
it won't deploy when issuing g29 either
@remixbot Will it home Z with G28 ? Deploy and retract probe for homing?
@BoA i tried to issue g28 now, but it wouldn't deploy now either
@remixbot OK. Post result of M122 and M98 P"config.g". Also what do you have in homez.g/homeall.g file?
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N85S4-7J9FD-3SD6S-TVAZP
Used output buffers: 3 of 24 (11 max)
Static ram: 27980
Dynamic ram: 93672 of which 44 recycled
Exception stack ram used: 284
Never used ram: 9092
Tasks: NETWORK(blocked,368) HEAT(blocked,1224) MAIN(running,1848) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:58 ago, cause: software
Last software reset at 2020-11-22 12:07, reason: User, spinning module GCodes, available RAM 8864 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 33.7, current 34.2, max 34.7
Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-11-22 12:09:33
Cache data hit count 204540357
Slowest loop: 8.06ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.9ms, write time 2.1ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 22.87ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address f4:cf:a2:66:49:60
WiFi Vcc 3.38, reset reason Unknown
WiFi flash size 4194304, free heap 24176
WiFi IP address 192.168.10.178
WiFi signal strength -61dBm, reconnections 0, sleep mode modem
Socket states: 0 4 0 0 0 0 0 0
- WiFi -
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C -
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.1.8 on Sun Nov 22 2020 11:42:47 GMT+0100 (sentraleuropeisk normaltid)
G91 ; relative positioning
G1 H1 X-235 Y-165 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-165 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-205 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 H1 Z-205 F1800 ; move Z down until the endstop is triggered
;G90 ; absolute positioning -
@remixbot Ok, that seems to be wrong.
homez.g
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.8 on Sun Nov 22 2020 11:42:47 GMT+0100 (sentraleuropeisk normaltid) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X5 Y5 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
homeall.g:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.8 on Sun Nov 22 2020 11:42:47 GMT+0100 (sentraleuropeisk normaltid) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-235 Y-165 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-235 Y-165 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X5 Y5 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
You might want to adjust position of homing point changing line with:
G1 X5 Y5 F6000 ;go to first probe point
BTW - did You use configtool, and set bltouch there? it generates proper config files.
yes i did use config tool
but can't seem to wrap mye head arround the pin assignment i config tool.
Pin Assignment
Input Pin
zprobe.in
Modulation Pin
zprobe.mod
PWM Control Channel (BLTouch only)
exp.heater3 -
still crashing into the bed
Is BL Touch deployed, but bed not detected? Or not deployed at all?
Describe what and where You connected (from BLtouch). -
bed is not detected
the bltouch is connencted to gnd and signal on probe in. and pin 1, 2 and 8 on the expansion
post a picture of your wiring
