    Forum Check
    5.5k
    • T3P3Tonyundefined
      T3P3Tony administrators
      Hi This is Tony, one of the Duet Wifi designers. Just a quick post to check the forums are up and running.
      www.duet3d.com
      • Aussiephilundefined
        Aussiephil
        Hi Tony,
        Phil in Oz, just confirming registration worked 🙂
        Cheers
        Phil
        • botundefined
          bot
          Nathan from Vancouver here, not actually a robot. Forum seems to work.
          *not actually a robot
          • deckingmanundefined
            deckingman
            Ian from the UK (deckingman) just joined.
            • Toddimusundefined
              Toddimus
              I've noticed the color scheme and backgrounds changing in the forums over the last couple of days. If my vote counts, I like how it is right now, with a white/light grey background and the blue borders.
              • T3P3Tonyundefined
                this white/light grey with blue is the forum default, you can change how it appears to you in your settings.
                www.duet3d.com
                • Toddimusundefined
                  Toddimus
                  The appearance seemed to change without me doing anything. The background was dark for a while, which was harder to read.
                  I thought something about the forum software had been changing.
                  Good now though. Thanks!
                  • Toddimusundefined
                    Toddimus
                    Quick update…
                    It went back to a dark grey background. No action on my part.
                    EDIT: I investigated further and the background color changes were due to "night mode" in the forum settings. Disabled that and it's back to how I like it.
                      deckingman
                      That's not bad - 5 months before the first spammer arrived.
                      • T3P3Tonyundefined
                        @deckingman:
                        And post deleted
                        www.duet3d.com
