No Connection to DCS After Update to 3.2beta4
@Frederikfor information purposes:
The cable that did NOT work: brand new Ugreen with 3Meters in lenght.
The cable THAT worked: 10 Year old usb2.0 with dual USB-A Plug on one side.
Like the on the external dvd or harddrives. Lenght ~ 40cm -
So, the cable worked. The firmware flash over bossa worked. Also verifying. I did 2 times exact what's mentioned in the getti g startet wiki. I loaded the additional files, flashed a new copy of duet pi desktop on the 16gb card. After that I copied my .g files in the /sys folder on the boot partition together with the 3.1.1 firmware .bin.
After that, I Did all the steps like network, keyboard layout etc. Without any errors.
Even the update at the end + restart showed no errors. Only in the dcs log is constantly starting and stoping with the meassage:
No connection to duet3
Should I do a standalone firmware reset and after that reconnecting the pi?
It seems that the reset button did not reset the board, even if I hold it like 10 seconds
I do all the actual test without Vin.
Only connection over usb and wlan -
@Frederik said in No Connection to DCS After Update to 3.2beta4:
Yes I would set it up in standalone to confirm that the Duet is working correctly otherwise and see what firmware version is flashed.
@Phaedrux Thanks. I will test that later.
@chrishammyes, i have the unstable all the time.
After i changed to the standalone mode, made the specific sd card + filestrukture, the board accepted the firmware and the diag led is now out . after that i startet a complete new installation with the pi.
this time everything works fine..
The new Visualizer is amazing
Tomorrow i will install and test the new DuetLapse .But that way did not work at first with the sbc attached.
Thanks for all your help
Regards
Frederik
