Unsolved Duet 3 6HC Rev. 1.01 Faulty
@NeueKlasse said in Duet 3 6HC Rev. 1.01 Faulty:
I remembered that i had connected the Duet and Pi4 in that way that the Duet supplies the Pi 5V before i put everything in the printer...
Then i wanted a extra Powersupply to not overload the Duet...Today i disconnected the Pi Powersupply and added the needed Jumper... et voila... problems seem gone.
I don’t understand why? I tried the original Pi power supply and even with this i had communication losses ....
I hope the board is tough enough...
Somehow there was differential noise between the ground of the Pi and the Duet ground when the bed heater was operating. However, from your wiring photos, I can't see the source of that, because you have connected the power wires to the bed heater mosfet directly to the PSU.
I have a few other suggestions to try, with the 5V_INT jumper removed and the Pi powered from the buck converter:
Temporarily disconnect both power input wires to mosfet switch. Then check with a multimeter that there is no connection between the bed heater output wires and the negative output terminals of the PSU. Assuming there is none, reconnect those wires and proceed to #2.
Currently you have the red and black input wires to the buck regulator connected directly to the middle pair of output terminals of the PSU. Try removing those two spade terminals from those PSU outputs and connect them instead to the same outputs as the Duet, leaving the middle output terminals free. It's possible to fit two spade terminals under one screw, but you may have to bend one of the spade terminals a little.
If #2 doesn't help, connect those two buck regulator input wires directly to the VIN terminals of the Duet instead, along with the two power wires.
i'll test these Variations asap! Thank you!
I tested everything, the 3 Output terminals V+ are bridged and the 3 Terminal V- are Bridged on the PSU. it had no Impact when i Wire the 24V lines from the Vin Terminals to the Powersupply or from the PSU Terminals.
also no change when the Mosfets are disconnected from the PSU
(5V->SBC not jumpered)While the Printer was Upsidedown the Opportunity was there to Change the noisy
PSU Fan to an Noctua 60mm PWM fan (Wired to out4 of the Board and jumper changed to 12V)after Reassembly and Disconnection from the PI Powersupply i reapplied the
5V->SBC Jumper. First all seems ok, last time the Print ran 10hours!!!! without any problem....
but now after Start of an Print i get connection losses every... 10-20seconds! again.Interesting thing... after 30min Printing and several Connection losses the Hotend cooled down due to the Connection losses but the Printer was still on its path! Gcode was Driven without an problem!...
Why does the printer don't stop in that case?is the Pi4 tested while Board development? or only with the Pi3?
i have no Pi3 here to verify..i am about to setup a TP-Link Nano and get rid of the Pi4...
This post is deleted! -
Short Update, maybe helpful for somebody.
I had still Communication Problems, doesn't matter what i tried,
now my Configuration looks a bit different and i'm running very happyDuet 3 MB6HC in Standalone Mode to TP Link Nano, and a
Raspberry Pi 4 with Octoprint to Provide a Camera URL, Octoprint doesn't need to Control anything... so the Stream isn't laggy by any meansAll Together in the Original Chiron Sheet Metal Cabinet/Box, + 1 PWM 60mm Noctua Fan, no flimsy extra space needed....
since that i've run 3-4 over 22Hour Prints without any Issue.
