    Duet 3 6HC Rev. 1.01 Faulty
    65
    2.6k
    • A Former User?
      A Former User
      you could try reducing the SPI frequency while waiting for new ribbon cable; /opt/dsf/conf/config.json (or something like that)
      NeueKlasseundefined 1 Reply Last reply Reply Quote 2
      • NeueKlasseundefined
        NeueKlasse @A Former User
        @bearer i used 50% of the value (100000)
        interesting thing: if i do the Heater Tuning M303 the Connection loss
        failures getting worse than before, but the Tuning are correctly till the end (seen from the Paneldue)
        MCU Temperature after 2 hours Continious running about 42°C
          NeueKlasse @chrishamm
          @chrishamm sorry, no i have no additional spi device running on the pi
            NeueKlasse
            Update: with the New Pi 4 it's still the same Problem... keep all my hopes to the
            Ribboncable...
            another Question, i'm using 2 Filamentsensors, although when i want to start a Gcode
            the Problem is i need all 2 Filamentsensors to be OK, but i just want to use 1 Hotend...
            how can i manage that without disabling?
              Phaedrux Moderator @NeueKlasse
              @NeueKlasse said in Duet 3 6HC Rev. 1.01 Faulty:
              How to disable without disabling? hmm..
              Since you can configure on the fly, disabling is probably the best way to go.
              Perhaps have it disabled by default and add the enable code to the second extruder start code?
                NeueKlasse
                I thought when i just use one extruder i don't need the other one for that specific Print.
                You Think about M591 D0/D1 P0 C"in5/in6" ?, maybe it would be handy in a future DWC to
                have Buttons to enable/disable configured Filament Sensors.
                  Well if you create a macro with that commands it basically shows up as a button.
                  NeueKlasseundefined 1 Reply Last reply Reply Quote 0
                    NeueKlasse @Phaedrux
                    @Phaedrux hm, ok i thought about that... so last time i tested everything it don't lets me start any gcode file because it needs both fil. sensors to be OK...
                    maybe i delete everything from the config file and set it separately over the Slicer/S3D Post processing....
                      NeueKlasse
                      Today i've got the New Ribboncable,
                      attached Everything. first it was working fine, Homing, Mesh Bed Leveling,
                      Speed and Acceleration Tests with 300mm/s...
                      a few minutes without anything...
                      after i turned on the Heaters (Bed Heater to 60degree) (Powered direct from Supply
                      over original Mosfets) Control via Heater 0 connector....
                      and 2 Nozzleheaters from the Board (50W each)
                      after Turning on the Heaters => Board lost connection, no header... timeouts, DCS not started... etc... when the heaters are off i have no problems at all (not like before the cable swap)
                      After Some tests i can confirm that the Board Lost Connection faults only occure when i set the Bed Temperature higher than +10degree (when i heat up from 30 to 40 it's not a problem... but when i heat up to 60 degree i get errors instantaniously..
                      I can Heat up both nozzles (together or alone to 180 degree without error)....
                      What's the problem?
                        NeueKlasse
                        Update... it doesn't matter what i try i also cant update the Firmware to another
                        than 3.1.1... with all others DWC says: DCS not started...
                        While Updating over DWC the PanelDue says: ERROR: Operation 3 failed after 5 retries....
                        i don't know either...
                        i bought the Duet Board to have a reliable Printer... now i'm disappointed from it....
                          Can you post some photos of your setup so we can see what your wiring looks like?
                          Can you be more specific about what exactly you've tried to do?
                          Did you ever get the board working in standalone mode?
                          NeueKlasseundefined 3 Replies Last reply Reply Quote 0
                            This post is deleted!
                              @Phaedrux
                              @Phaedrux
                              What i tried to do:
                              • Update Firmware via SBC sudo apt update / upgrade ... with "no Header" Errors while updating.
                              • Directly over DWC (file Upload, Version 3.2beta 1 to beta 4), Problem is that after i
                                acknowledge that i want to update the Firmware the Paneldue says ERROR: Operation 3 failed after 5 retries
                                and DWC shows me that it is updating... still after 1 hour.... when i reset the printer the
                                Firmware is corrupt and i need to erase it and update it via USB Cable and Bossa!
                                and when i don't Use Firmware 3.1.1 it doesn't connect to the PI SBC and DWC says... DCS not started.
                              After i installed V3.1.1 it seems to be OK... but while heating up the bed i get
                              connection losses (no header etc.)
                              Oh not to mention... if the sudo apt get upgrade runs till the error it wont reconnect to the Board till i set up the DuetPi with a new Image....!!!!!
                              Wiring:
                              Driver 0 = X
                              Driver 1 = Y
                              Driver 2 = Z1
                              Driver 3 = Z2
                              Driver 4 = E1
                              Driver 5 = E2
                              Out1 = (Heater 0) to Bed Mosfet
                              Out2 = Heater 1
                              Out3 = Heater 2
                              Out7 = Extruder Fans
                              Out8 = Part Cooling Fans
                              Power IN = 25V
                              Only 1 Jumper on Int 5V En
                              IO0 = PanelDue 5i
                              IO3 = X Endstop
                              IO4 = Y Endstop
                              IO7 = BlTouch V3.1
                              IO6 = 5V Cabinet Fan
                              Temp0 = Bed Thermistor
                              Temp1 = E1 Temp
                              Temp2 = E2 Temp
                              physically Wiring itself should not be the Problem
                                @Phaedrux
                                Yes the Board works in Standalone mode.. see above
                                  When in standalone are you able to update to 3.2 Beta 4.1?
                                  Then once updated are you able to start with a fresh pi image and update to the unstable branch to match?
                                    @Phaedrux
                                    update to the unstable branch to match.. you mean via apt update/upgrade?
                                    i could try..
                                      Yes, once the board itself has the 3.2 beta 4.1 firmware flashed on it via USB/Bossa.
                                      Then a fresh Pi image install. https://pkg.duet3d.com/DuetPi.zip
                                      And then update to the unstable branch to match the firmware on the duet.
                                      https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
                                        @Phaedrux
                                        The DuetPi Update with or without connection to the board via ribbon cable?
                                          @NeueKlasse I think you can update without the board being connected.
                                            @Phaedrux
                                            I've done everything that was mentioned.
                                            • Board Updated to 3.2 Beta 4.1 (Tested in Standalone Mode, no Problems)
                                            • DuetPi freshly installed (+added ssh.txt, +added wpa_supplicant)
                                              and Updated via unstable branch to 3.2 Beta 4.1 => OK!
                                            • DuetPi Connected to Duet3 Board => Again, no Problems while Hotends heating (M303) or Movenments, Homing etc.
                                            • BUT when i start M303 for the Hotbed => it's exactly like the Picture from 1.Dec.2020 above. Many Many Connection Losses.....
                                            When i Turn on the Hotbed i get Errors like DCS Stopped, Connection Lost and Connection established again...
                                            as soon as i set the Bed Temp to 0 (off) the Problems STOP! Immediately!
                                            i don't understand!...
