    Issues with new Duet@
    • camposm7undefined
      camposm7
      I installed a new Duet2 Ethernet v1.04c with 3.11 firmware but now I am having several issues...
      Firstly, my PanelDue 5i is not functioning at all and it is enabled in the config.
      Secondly my z end stop seems to be the only functioning end stop. It is the only switch that lights up the LED.
      Next, when trying to move an axis I am given the following error "Warning: motor phase B may be disconnected reported by driver(s) 2"
      Last thing I am noticing is that the BL Touch is not deploying and retracting when I boot the machine up.
      Config
      ; generated by RepRapFirmware Configuration Tool v3.1.9 on Tue Dec 01 2020 12:40:10 GMT-0800 (Pacific Standard Time)
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      M550 P"S110 Tall"                                         ; set printer name
      M552 P0.0.0.0 S1                                          ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                                ; enable HTTP
      M586 P1 S0                                                ; disable FTP
      M586 P2 S0                                                ; disable Telnet
      M569 P0 S1                                                ; physical drive 0 goes forwards
      M569 P1 S1                                                ; physical drive 1 goes forwards
      M569 P2 S1                                                ; physical drive 2 goes forwards
      M569 P3 S1                                                ; physical drive 3 goes forwards
      M569 P4 S1                                                ; physical drive 4 goes forwards
      M584 X0 Y1 Z2 E3:4                                        ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1                                ; configure microstepping with interpolation
      M92 X400.00 Y400.00 Z400.00 E420.00:420.00                ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00           ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I50                          ; set motor currents (mA) and motor idle factor in per cent
      M84 S50                                                   ; Set idle timeout
      M208 X0 Y0 Z0 S1                                          ; set axis minima
      M208 X210 Y260 Z500 S0                                    ; set axis maxima
      M574 X1 S1 P"xstop"                                       ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                       ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                                       ; configure active-high endstop for low end on Z via pin zstop
      M950 S0 C"exp.heater3"                                    ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                       ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y20 Z2.5                                      ; set Z probe trigger value, offset and trigger height
      M557 X10:200 Y10:200 S80                                  ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138            ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                     ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S100                                              ; set temperature limit for heater 0 to 100C
      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                      ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
      M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                                      ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S280                                              ; set temperature limit for heater 2 to 280C
      M950 F0 C"fan0" Q500                                      ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                            ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                      ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1:2 T45                                       ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan1" Q500                                      ; create fan 2 on pin fan1 and set its frequency
      M106 P2 S1 H1:2 T45                                       ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                          ; define tool 0
      G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
      G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F0                                          ; define tool 1
      G10 P1 X0 Y0 Z0                                           ; set tool 1 axis offsets
      G10 P1 R0 S0                                              ; set initial tool 1 active and standby temperatures to 0C
      M575 P1 S1 B57600                                         ; enable support for PanelDue
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
      Board ID: 0JD0M-9P6M2-NW4SS-6J9D6-3SN6M-TVWBK
      Used output buffers: 1 of 24 (11 max)
      Static ram: 27980
      Dynamic ram: 93816 of which 48 recycled
      Exception stack ram used: 344
      Never used ram: 8884
      Tasks: NETWORK(ready,384) HEAT(blocked,464) MAIN(running,1816) IDLE(ready,80)
      Owned mutexes:
      Last reset 00:03:25 ago, cause: power up
      Last software reset details not available
      Error status: 0
      MCU temperature: min 21.6, current 25.1, max 25.3
      Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/248
      Date/time: 2020-12-01 12:45:33
      Cache data hit count 416902523
      Slowest loop: 5.92ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.8ms, write time 0.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 168, MaxWait: 42194ms
      === MainDDARing ===
      Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 7.84ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      M98 P"config.g"
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
      Error: Pin 'fan1' is not free
      Error: Fan number 2 not found
      Error: Heater 1 fault: heater monitor 0 was triggered
      Error: Heater 2 fault: heater monitor 0 was triggered
      (I still need to configure my thermistors, that's why I'm getting heater faults)
      What am I missing here?
      • Vetiundefined
        Veti
        @camposm7 said in Issues with new Duet@:
        i think the second one is meant to be fan2?
        check endstops with M119
        if they are not triggered check your wiring.
        is your current correct (75% of rated motor current)?
        otherwise its a cabling issue. check the crimp job.
        also most likely a wiring issue. check the crimp job here as well.
          Phaedrux Moderator @camposm7
          How do you have it wired up? 4-wire or ribbon cable? Double check your wiring.
          Does the screen power on at all? Can you get to the setup page and see the firmware version? It should be at version 1.24. Update it if it's not. If it doesn't power on at all, does it light up if you connect it to your PC via USB?
          Double check your wiring for continuity. A multimeter should show if the switch (and wiring) itself is actually working.
          Double check the wiring. https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
          Can you guess? Double check the wiring. Does it light up at all? It should light up and do a self test when power is applied.
          • Bluemaluundefined
            Bluemalu
            If the PanelDue powers up - ie displays something don't make the mistake I made and press the buttons on the panel and erase the firmware. If you do it's fairly easy to upload the firmware using Bossa and the USB connector.
            https://duet3d.dozuki.com/Wiki/Connecting_an_LCD_control_panel#Section_Connecting_a_PanelDue
            After I had the screen displaying information it sat on a screen saying connecting. I changed out the cable for a 2nd one, still had the same issue. Turned out a poor crimp on the connectors that failed only when plugged in. Very annoying fault.
