    CAN bus Tool Distribution Board to ToolBoard ?
    • Pseud3mysundefined
      Pseud3mys
      These are no info on how to connect the CAN bus from Tool Distribution Board to the Toolboard. Can someone help me please ?
        Pseud3mys
        I do this, but it is writen "without tool distribution board" in the doc for this connection... And it don't work with a second toolboard.
        • Alex.crundefined
          Alex.cr
          You need to wire all 4 wires to the Tool boards if you plan on using more than one. By placing the resistor in connection you terminated communication to any more boards.
          Then instead of using the resistor in the connection of the last tool board, simply keep the jumpers on the distribution board to terminate the last tool board.
          Some more information can be found here: CAN connection basics (https://duet3d.dozuki.com/Wiki/CAN_connection).
          Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
            Pseud3mys
            okay thank you ! The 4 wire are in same order ?
              dc42 administrators @Pseud3mys
              @Pseud3mys said in CAN bus Tool Distribution Board to ToolBoard ?:
              Yes, pin 1 to pin 1 and so on.
              See also https://duet3d.dozuki.com/Wiki/CAN_connection.
                Pseud3mys
                It work, thank you !
