    Switching from 4 Pin to 2 Pin Fan won´t work
    702
    • Frederikundefined
      Frederik
      My Part Cooling Fan Dyed Yesterday and I tried to switch to a 2 Pin Sunon Blower. I can not get this thing to work properly. Only 100 or Off.
      Is there a way so that I can use the Slider in DWC to change the Fan Speed?
      Regards
      Frederik
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @Frederik
        @Frederik
        some fans do not work with pwm at all.
        for sunon fans example see the note here about the capacitor
        https://de.aliexpress.com/item/4000355235931.html
        Frederikundefined 2 Replies Last reply Reply Quote 0
        • Frederikundefined
          Frederik @Veti
          @Veti #oh, thanks. I didn´t know that. Mine is a 24V Version. But i think that makes no difference.
          What value should i use ?
          • Frederikundefined
            Frederik @Veti
            @Veti 25V 100uf ?
            • Vetiundefined
              Veti
              i do not have such a fan, so i never had to do it.
              i just came across it when shopping for a fan.
              Frederikundefined 1 Reply Last reply Reply Quote 0
              • Frederikundefined
                Frederik @Veti
                @Veti i was shopping for fans a lot in the last week. But i never saw an Information like that 🙂
                • A Former User?
                  A Former User
                  You'd probably want to use a 35V or 50V rating, the picture does show 100uF- You may get some degree of control, but I wouldn't expect magic.
                    DO NOT connect a capacitor in parallel with the fan outputs to smooth the PWM! Doing so subjects the fan mosfet to peak currents likely to exceed its rating.
                    The safe way to smooth PWM is to use a flyback diode (which is already included in the Duet fan outputs, but not heater outputs) and inductor, optionally followed by a capacitor.
                    It's also possible to use a 10 ohm resistor followed by a capacitor, although that will reduce the maximum fan speed a little.
                    • Frederikundefined
                      Frederik @dc42
                      @dc42 Ok, good to know.
                      What would the correct way ?
                      Connecting to a 2pin connector like out 7-9 ?
                      What do i have to change in my configt.g ?
                      Regards
                      Frederik
                      • Vetiundefined
                        Veti
                        you could try different pwm frequencies
                          dc42 administrators @Frederik
                          @Frederik said in Switching from 4 Pin to 2 Pin Fan won´t work:
                          Regards
                          Frederik
                          You can connect 2-pin fans to 4-pin connectors, between the VFAN pin and the FAN- pin. Connected in this way, they behave just like the 2-pin outputs.
                          Some 2-pin fans only work with PWM if you reduce the PWM frequency.
                          • Frederikundefined
                            Frederik @dc42
                            @dc42 do you mean with the oins nr 2 and 4 when i am looking at the online wiring guide ?
                            • Frederikundefined
                              Frederik
                              i mean for example: out 6: voutlc1 and the out6 ?
                              • Frederikundefined
                                Frederik @dc42
                                @dc42 i have tried both out 9 and out 6. Now Function.
                                Hotend Fan on out8 working on or off. but the other fan wont start with the same values
                                M950 F0 C"out8" Q500                                  ; create fan 0 on pin out8 and set its frequency
                                M106 P0 C"Hotend" S1 H1 T45                           ; set fan 0 name and value. Thermostatic control is turned on
                                M950 F1 C"out9" Q500                                 ; create fan 1 on pin !out4 and set its frequency
                                M106 P1 C"Bauteildüse" S1 H-1                         ; set fan 1 name and value. Thermostatic control is turned off
                                • Vetiundefined
                                  Veti
                                  Q500
                                  try Q10
                                  • Vetiundefined
                                    Veti @Veti
                                    @Frederik
                                    I bought some 2 pin sunon fans.
                                    at 500 i had the same result as you.
                                    at 25000 they are somewhat adjustable.
                                    Frederikundefined 1 Reply Last reply Reply Quote 1
                                    • Frederikundefined
                                      Frederik @Veti
                                      @Veti what model are you using? Meanwhile I got it working. I connected them on the toolboard to out 2 and out1, used pwm 255 and connected to pwm out and 12v.
                                      The control is for me good enough at the moment, I would guess that I'm getting ~10% steps.
                                      What range did you get with 25000?
                                      Thats the one I'm using:
                                      • Vetiundefined
                                        Veti @Frederik
                                        i was able to go down to 10% with the fan still spinning.
                                        • Frederikundefined
                                          Frederik @Veti
                                          @Veti I tested with 25000 as value.
                                          My Fans don't even start to spin.
                                          Only at 100%, they start running
                                          but at 99 it's standing still... why these big differences from similar Fans?
                                          • Vetiundefined
                                            Veti
                                            some fans do no like the pwm signal.
