Unsolved Duet2 Wifi connection dropping
Is there anyone who can help me ?
My guess is that your problems might be that you haven't setup a static ip address for your printer, or that your printer is located somewhere with to low signal strength.
Have you read up on setting up static ip for your printer (on the duet wiki), and want to give it a try?
Or power wire of psu or bed are near the wifi module, could you check if it's the case ?
Hi
Thank you for your reply.Of course the Duet Board get a static IP from my Fritzbox 7590.
And the Powe wire is not in the near of the Wifi antena.
So i am frustrated . -
Any idea´s?
Let me look into that error message you're getting from DWC now.
When you lose connection, does the blue LED on the module go out?
Hi
No , the blue Wifi LED on the Duet Board stay on ! -
Usually that error message would indicate that the connection buffers are getting used up causing a disconnect.
How many devices do you have running DWC?
What browser are you using?
When you are connected can you verify that your DWC files have been updated to 2.0.7?
I run only one Duet2 Board on the DWC.
My Browser is Chrome.
In The moment i can´t connect me
So is there a other possibility to see if i have 2.07? -
@uneumann36 said in Duet2 Wifi connection dropping:
Well if you extracted the zip file into the /www folder it's most likely that you are on 2.0.7.
Did you notice that the web interface looked different after you updated?
My Browser is Chrome.But do you have multiple tabs open to the web interface or something like that?
Oh yeah it looks absoluty different.
ANd yes i have two tabs open, but i don´t think this is the reason.
Just a Question,
i have noticed that for example i start a print via web console , print starts all good.
But at no point i have any information about the print on my Panel!
No temperatures etc.
But Panel is working, i can stop the print from Panel and homing.
I do not know if this also caused by my problem. -
@uneumann36 what firmware is on the paneldue? Check on the setup page.
Having multiple tabs or devices open on dwc certainly can cause problems.
The Firmware is 3.2.0
Then I suggest you either upgrade RRF or downgrade the firmware running on the PanelDue. See the note from the PanelDueFirmware release:
This release is compatible with RepRapFirmware 3.2-beta1 or later. It will partially work with RepRapFirmware 3.1.1 but not with any older version.
Different devices may use DWC at the same time but it's generally a bad idea to keep two DWC instances open on the same machine.
Thank you.
So as i told in the beginning, i am not a Software expert!
And in the moment i don´t know what you mean !
I have to downgrade what? -
Since this is a new build it's probably a good idea to upgrade your duet firmware to RRF3 to start with.
As for the PanelDue it might be best to run 1.24 for now.
That way everything will work nicely together and you'll be ready to update to 3.2 when it becomes final.
Did you update the PanelDue yourself already?
Yes i update it myself!
But it takes a whole Day! Smile
Before i find out how.
