    Duet2 Wifi connection dropping
    1.8k
    • uneumann36undefined
      uneumann36
      M122
      SENDING:M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P61A-J8PSJ-6JTDA-3SD6J-1BRQT
      Used output buffers: 3 of 24 (8 max)
      Static ram: 25680
      Dynamic ram: 93680 of which 0 recycled
      Exception stack ram used: 396
      Never used ram: 11316
      Tasks: NETWORK(ready,652) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:00:30 ago, cause: software
      Last software reset at 2020-12-02 18:38, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 2)
      Error status: 0
      [ERROR] Error status: 0
      Free file entries: 10
      MCU temperature: min 28.4, current 29.0, max 29.2
      Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/158
      Driver 1: standstill, SG min/max 0/82
      Date/time: 2020-12-02 18:39:24
      Cache data hit count 105715423
      Slowest loop: 6.79ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 167, MaxWait: 679ms
      === DDARing ===
      Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.52ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address 48:3f:da:78:53:61
        WiFi Vcc 3.32, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25864
        WiFi IP address 192.168.1.148
        WiFi signal strength -53dBm, reconnections 0, sleep mode modem
        ok T0:186.2 /0.0 B:57.8 /0.0
        uneumann36 @Phaedrux
        @Phaedrux
        do you find the result?
          Let's start by manually updating the firmware and DWC files.
          You'll need to remove the SD card from the Duet and put it in your PC.
          First make a backup copy of the SD card contents.
          Then replace the contents of the /www folder with the contents of this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
          Then download this zip file: https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2Firmware-2.05.1.zip
          extract it, and copy the .bin files in to the /sys folder.
          Duet2CombinedFirmware.bin
          DuetWifiServer.bin
          iap4e.bin
          iap4s.bin
          Then put the SD card back in the Duet and connect via USB and use pronterface to send the command M997 S0:1
          When it reboots, send M122 again to confirm that RRF 2.05.1 and wifi server 1.23 are installed.
          Then try to access the web interface again.
            uneumann36
            @Phaedrux said in Duet2 Wifi Firmware confusion:
            Yeah this works well !
            Please check if this is good :
            SENDING:M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
            Used output buffers: 3 of 24 (12 max)
            Static ram: 25712
            Dynamic ram: 93140 of which 0 recycled
            Exception stack ram used: 272
            Never used ram: 11948
            Tasks: NETWORK(ready,1280) HEAT(blocked,1232) MAIN(running,3728) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:00:29 ago, cause: power up
            Error status: 0
            MCU temperature: min 32.5, current 32.7, max 33.0
            Supply voltage: min 24.1, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
            Cache data hit count 75021852
            Slowest loop: 6.39ms; fastest: 0.07ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
            === DDARing ===
            Segments left: 0
            === Network ===
            Slowest loop: 201.15ms; fastest: 0.08ms
            HTTP sessions: 0 of 8
            • WiFi -
              Failed messages: pending 0, notready 0, noresp 1
              WiFi flash size 4194304, free heap 26024
              WiFi signal strength -54dBm, reconnections 0, sleep mode modem
              uneumann36
              it works approx 5 min .
              Then i got the message :
                uneumann36
                In this moment it is impossible to have access to Web console.
                Only when i switch printer off and on it is connected immediately
                  uneumann36
                  Is there anyone who can help me ?
                  • Exerqtorundefined
                    Exerqtor
                    My guess is that your problems might be that you haven't setup a static ip address for your printer, or that your printer is located somewhere with to low signal strength.
                    Have you read up on setting up static ip for your printer (on the duet wiki), and want to give it a try?
                    • piperswundefined
                      pipersw
                      Or power wire of psu or bed are near the wifi module, could you check if it's the case ?
                        uneumann36
                        Hi
                        Thank you for your reply.
                        Of course the Duet Board get a static IP from my Fritzbox 7590.
                        And the Powe wire is not in the near of the Wifi antena.
                        So i am frustrated .
                          uneumann36
                          Any idea´s?
                            Let me look into that error message you're getting from DWC now.
                            When you lose connection, does the blue LED on the module go out?
                              uneumann36
                              Hi
                              No , the blue Wifi LED on the Duet Board stay on !
                                uneumann36
                                  Usually that error message would indicate that the connection buffers are getting used up causing a disconnect.
                                  How many devices do you have running DWC?
                                  What browser are you using?
                                  When you are connected can you verify that your DWC files have been updated to 2.0.7?
                                    uneumann36
                                    I run only one Duet2 Board on the DWC.
                                    My Browser is Chrome.
                                    In The moment i can´t connect me
                                    So is there a other possibility to see if i have 2.07?
                                      @uneumann36 said in Duet2 Wifi connection dropping:
                                      Well if you extracted the zip file into the /www folder it's most likely that you are on 2.0.7.
                                      Did you notice that the web interface looked different after you updated?
                                        Phaedrux Moderator @uneumann36
                                        But do you have multiple tabs open to the web interface or something like that?
                                          uneumann36
                                          Oh yeah it looks absoluty different.
                                          ANd yes i have two tabs open, but i don´t think this is the reason.
                                            uneumann36
                                            Just a Question,
                                            i have noticed that for example i start a print via web console , print starts all good.
                                            But at no point i have any information about the print on my Panel!
                                            No temperatures etc.
                                            But Panel is working, i can stop the print from Panel and homing.
                                            I do not know if this also caused by my problem.
