My duet wifi does not connect to the wifi.
My duet wifi does not connect to the wifi. While it was connected and printing an hour ago. Suddenly I cannot access it via the name/ip I had set. Checking the router connections it does not seem listed. I have restarted both the router and duet several times but it does not seem to work.
I removed the sd card and accessed it on PC and it seems ok, removed all the gcode files just in case, the wifi SSID and password are in my config.g file.
The green, red and blue leds are on like normal when turning on the psu.
Not sure what I should do after that. It had happened in the past but it was fixed after restarting the machine.
Any help is appreciated.
Kind regards,
George
@GPetropoulos said in My duet wifi does not connect to the wifi.:
That should not be. Must be an old config.
Is the blue LED on the wifi module lit?
Can you connect via USB and send M122 and report the results?
What firmware version on the Duet and on the wifi server?
@Phaedrux I have not connected with usb since I got it. What do I do? Just plug the usb while the PSU is ON? Use pronterface to send the M122?
Take precautions to prevent USB ground loops if you are going to leave VIN connected.
https://duet3d.dozuki.com/Wiki/USB_ground_loops
To be safe you can leave VIN disconnected/PSU unplugged and just have USB connected. Then yes you would use YAT or pronterface to connect via serial and you'd have access to terminal commands.
As described here: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s6
It would also be useful to send M587 to see what SSIDs get reported.
@Phaedrux This is what I get:
RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.05.1 dated 2020-02-09b1<LF><LF>Executing config.g...Error: M587: Failed to add SSID to remembered list<LF>HTTP is enabled on port 80<LF>FTP is disabled<LF>TELNET is disabled<LF>Error: G29: Height map file heightmap.csv not found<LF>Warning: Heater 0 appears to be over-powered. If left on at
M122
=== Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-917NK-F23T0-6JKD4-3S06T-9YANF<LF>Used output buffers: 1 of 24 (2 max)<LF>=== RTOS ===<LF>Static ram: 25712<LF>Dynamic ram: 93176 of which 380 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 11548<LF>Tasks: NETWORK(ready,1884) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:05:30 ago, cause: power up<LF>Last software reset at 2020-12-06 13:51, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 1)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 16.7, current 19.4, max 20.5<LF>Supply voltage: min 0.3, current 1.6, max 1.7, under voltage events: 0, over voltage events: 0, powe[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
Can you change the end of line setting so we can see the full report (with formatting).
m122
or later
Used output buffers: 1 of 24 (10 max)
Static ram: 25712
Dynamic ram: 93220 of which 336 recycled
Exception stack ram used: 304
Never used ram: 11500
Owned mutexes:
Last reset 00:25:45 ago, cause: power up
Error status: 0
MCU temperature: min 17.8, current 18.1, max 18.6
Supply voltage: min 1.6, current 1.6, max 1.7, under voltage events: 0, over vol
tage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 2472230280
Slowest loop: 200.74ms; fastest: 0.06ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets
0
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0
, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "m122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.17ms; fastest: 0.01ms
HTTP sessions: 0 of 8- WiFi -
Network state is starting
WiFi module is disabled
Failed messages: pending 0, notready 0, noresp 4
ok
- WiFi -
Also not sure if it is normal, but before the blue led was on. Now on usb only it is not.
@Phaedrux Also I checked the link for the remembered list/networks, as I still have the M587 in the config.g
I only access the printer from the web interface. I do not understand how it will work if the command to enable the wifi is not in the config.g
How can I send a macro to it if it does not connect first?
you enable the network with
m552 s1
m587 is for storing the network details, this only needs to be done once.@GPetropoulos said in My duet wifi does not connect to the wifi.:
blue light is to indicate Vin, so it will not light when using only usb
WiFi -
okCan you send M552 S0 and then M552 S1?
I fear that having that in the config has caused the module flash to burn out from constantly re-writing the SSID and password at every power up.
@Phaedrux M552 S0
ok
M552 S1
Turn off the current WiFi mode before selecting a new one
ok
M552
WiFi module is being started
Can you try setting up the wifi module in access point mode to see if the module is working at all?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
@Phaedrux m552 s2
ok
m552 s-1
WiFi module stopped
ok
m552 s2
ok
M589 S"DuetSSID" P"password" I"192.168.0.1" C1
M589: Bad or missing parameter
ok
@Phaedrux Does this mean it is bricked?
Unfortunately I had not seen that you should not use the M587 in the config.g and should be something added at a later time than last year we were talking.Is there any chance my firmware is old and this does not work due to that?
I have not updated the firmware for sometime.I had ordered directly from duet3d.com on 09/12/18
I"192.168.0.1"
Try without the quotes around the ip address. The example in the wiki may need to be updated.
@Phaedrux Yes it sent a different answer now.
m552 s-1
WiFi module stopped
ok
m552 s2
ok
M589 S"DuetSSID" P"password" I192.168.0.230 C1
M589: Failed to configure access point parameters
ok
If the access point mode doesn't work after removing the quotes from the ip address you can try reflashing the wifi server firmware by sending
M997 S1
@Phaedrux said in My duet wifi does not connect to the wifi.:
M997 S1
This is what I get
M997 S1
Trying to connect at 230400 baud: failed
Trying to connect at 115200 baud: failed
Trying to connect at 74880 baud: failed
Trying to connect at 9600 baud: failed
Error: Installation failed due to comm write error
ok
Will have to see what @dc42 thinks.
If the module has failed, it is replaceable with the right skills and tools.
@Phaedrux Well I don't have the skills or the tools for such an operation
If you have a maker space or hacker space nearby they might be able to help. Search the forum for "community repair" to see if any of the listed forum users are nearby and able to assist with repair. Alternatively you could try converting to using a Raspberry Pi like the Duet 3 (but the firmware for that is still beta, and it will require some custom wiring), there are a few threads here on using a Pi and DSF with Duet2Wifi as well if you search
@bearer Thank you for your feedback. Thus I do not have a makerspace near me. I am in a smaller town where 3D Printing is not so adopted.
I would not like to go for experiments. I like my duet and I wish to keep using that.
