Duet 2 Wifi - Filament Sensor
  • Hello together!
    I am currently "rebuilding" my new damaged Sapphire Pro.
    I changed the Board to a Duet 2 Wifi, changed cables, Hotend, Fans and so on.
    Now i am thinking over to install the Filament Run Out Sensor.
    I have the orignal one from Sapphire... A Cheap simple Sensor.
    In the Duet Doku i found this here:
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
    Can somebody tell me or explain me, where i must connect this Sensor and how? (Which pin where..)
    I also read in the link above this:
    "* Note that filament monitoring in RRF is only active when printing from SD card."*
    So if i upload a gcode through the Webinterface and print this... will the Sensor be working or not?
    I hope everybody here can understand me, i am a German User and my English Skills are not very well 😉
    Kind Regards & a nice Evening
  • Moderator
    @xenon2008 said in Duet 2 Wifi - Filament Sensor:
    Yes, that would be using the internal SD card to store the gcode file and execute it. The alternative which would not work, would be using a USB sending program like octoprint.
    Well you'd need a free endstop pin, probably e0stop. And how you'd configure it would depend on your firmware version.
  • Okay thanks!
    I will have a look at this when i am back at home.
    Hope i understand this, how to configure 😃
    Kind Regards from Austria 😉
  • Hello, i am again,
    i have now crimped a cable like this:
    Sensor GND => Duet 2 Wifi E0 Stop GND
    Sensor Signal => Duet 2 Wifi E0 Stop Signal
    and added this to my config.g:
    M591 D0 P1 C"e0stop" S1
    Then i have restarted my Duet, but i only see 3 Endstops in the Webinterface (XYZ) and no E0 Stop??.
    Is this normal or did i make a mistake here?
    Would somebody help me please?
    Is this so right or wrong?
    And must i add something to my Start G-Code in the Slicer?
    Thanks & have a nice Evening!
  • Moderator
    What firmware version are you running?
    It won't show up as an endstop. It's a switch that is being monitored, but it's not an endstop in the normal sense.
    If you start a print and then remove the filament from the switch does it stop the print?
  • @Phaedrux said in Duet 2 Wifi - Filament Sensor:
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1
    I did not test this for this moment. because i must first build the printer finish...
    But you think thats "normal" and i had configured this right?
    I am not sure because i found this here:
    https://github.com/Duet3D/DuetWebControl/issues/189
  • Moderator
    Configuration looks ok.
