    Distribution & Toolboard connection Problems
    1.5k
    • Frederikundefined
      Frederik
      I´ve tried to connect 1x Toolboard LC1 over the tool Distribution Board.
      I connected the distribution board over the rj11 cable and the LC1 with a straight thru 4pin JST cable and 24V to VIN from the Power Supply.
      But the Toolboard is like dead, no LED´s are flashing or lighting up. 24V is ok.
      at the moment I use RRF 3.1.1 + SBC
      should I try with the beta4 first?
      i have the two jumpers on the distro board removed.
      i used the left can port and the first JST connector from the right side of the distro board.
      I can´t get it to work or get it recognised by my duet 3 board.
      Please Help 🙂
      Regards Frederik
        Is the fuse on the tool board for that output intact?
        Frederikundefined 1 Reply Last reply Reply Quote 0
        • Frederikundefined
          Frederik @dc42
          @dc42 Do you mean the Fuse on the Tool Distribution Board ?
          It is ok. I also tried another Port, but the same. No LEDs or other signs of life 😞
          Regards Frederik
            I suggest you use a multimeter to check that you have +24V on the +VIN pin of the VIN connector on the tool board with respect to the ground pin.
            Frederikundefined 2 Replies Last reply Reply Quote 0
            • Frederikundefined
              Frederik @dc42
              @dc42 I checked it, 24V is ok on the tool and distribution board. Polarity is correct
              • Frederikundefined
                Frederik @dc42
                @dc42 i used a stright trough 4 pin can cable
                  Even without the CAN cable, with VIN power applied to the tool board you should get 2 LEDs lit and another one flashing. Please post photos showing how 24V power is supplied to VIN on the tool board.
                  • Frederikundefined
                    Frederik @dc42
                    @dc42 as soon as i am back from Work, i will post pictures.
                    • Frederikundefined
                      Frederik @dc42
                      @dc42 I supplied the Vin direct from my 24v power supply to the Vin of the tool distribution board. And from there with the first port to the toolboard lc1. I need 2 more hours at my office. I will send you the pictures as soon as I am at home. Could I test some other parts with my multimeter to check the correct function?
                      Regards
                      Frederik
                      • Frederikundefined
                        Frederik
                        I checked the connections and fuses with the multimeter. Everything ok. 24.1v on the toolboard. But no led are on.!IMG_20201209_191716.jpg
                        • Frederikundefined
                          Frederik
                          • Frederikundefined
                            Frederik
                            @dc42 Thank you, Problem Solved.
                            I rewired the distro and toolboard + making new crimps for my vin cables.
                            i was measuring the 24v on the bottom of the connector and checked the polarity.
                            But somehow the connection made no contact to the toolboard.when plugged in
                            I also updated my duet3 to RRF 3.2beta4.1
                            now the blue led is on and the red led is constantly on like the diag led on the duet 3, but not flashing. Is the firmware wrong?
                            What is the next thing to check?
                            Pressing the 2 buttons while starting the board doesn't change the led signals.
                            Is there another way to reset the toolboard and check the CAN connection?
                            Regards
                            • A Former User?
                              A Former User
                              it might not matter, but the tool distribution board you showed is missing a bypass jumper on the 4th unused output and doesn't show the jumper for the 1st you're actually using.
                              Frederikundefined 1 Reply Last reply Reply Quote 1
                              • Frederikundefined
                                Frederik @A Former User
                                @bearer thanks for pointing that out. I uploaded the wrong photo. The jumpers are both removed from the first port with the cable and are set in every else slot.IMG_20201210_061343.jpg
                                I test both ways. With only one of the two jumpers removed and both jumpers removed. The same result in the console and no change in led behavior.
                                • Frederikundefined
                                  Frederik
                                  M122
                                  RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                  Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
                                  Used output buffers: 1 of 40 (11 max)
                                  Static ram: 123212
                                  Dynamic ram: 138092 of which 24 recycled
                                  Never used RAM 130864, free system stack 200 words
                                  Tasks: Linux(ready,101) HEAT(blocked,298) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1189) IDLE(ready,19)
                                  Owned mutexes: HTTP(MAIN)
                                  Last reset 00:01:10 ago, cause: power up
                                  Last software reset at 2020-12-10 01:00, reason: User, GCodes spinning, available RAM 130864, slot 2
                                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task Linu
                                  Error status: 0x00
                                  MCU temperature: min 26.1, current 35.2, max 35.3
                                  Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                  12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                  Driver 0: position 0, standstill, reads 21528, writes 14 timeouts 0, SG min/max 0/0
                                  Driver 1: position 0, standstill, reads 21529, writes 14 timeouts 0, SG min/max 0/0
                                  Driver 2: position 0, standstill, reads 21530, writes 14 timeouts 0, SG min/max 0/0
                                  Driver 3: position 0, standstill, reads 21533, writes 11 timeouts 0, SG min/max 0/0
                                  Driver 4: position 0, standstill, reads 21534, writes 11 timeouts 0, SG min/max 0/0
                                  Driver 5: position 0, standstill, reads 21532, writes 14 timeouts 0, SG min/max 0/0
                                  Date/time: 2020-12-10 06:17:24
                                  Slowest loop: 0.90ms; fastest: 0.12ms
                                  === Storage ===
                                  Free file entries: 10
                                  Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
                                  === MainDDARing ===
                                  Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Movement lock held by null
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  SBC is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Aux2 is idle in state(s) 0
                                  Code queue is empty.
                                  === CAN ===
                                  Messages queued 158, send timeouts 510, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
                                  === SBC interface ===
                                  State: 0, failed transfers: 0
                                  Last transfer: 19ms ago
                                  RX/TX seq numbers: 1334/1335
                                  SPI underruns 0, overruns 0
                                  Number of disconnects: 0, IAP RAM available 0x20a28
                                  Buffer RX/TX: 0/0-0
                                  === Duet Control Server ===
                                  Duet Control Server v3.2.0-beta4
                                  Code buffer space: 4096
                                  Configured SPI speed: 8000000 Hz
                                  Full transfers per second: 0.11
                                  Vetiundefined 1 Reply Last reply Reply Quote 0
                                  • Frederikundefined
                                    Frederik
                                    M997 B121 S3
                                    Error: M997: Response timeout: CAN addr 121, req type 6024, RID=14
                                    everything I try only generates this timeouts. M115, M122, M997... Are there other parts to test with the multimeter to ensure that I got a working unit?
                                    • Vetiundefined
                                      Veti @Frederik
                                      @Frederik said in Distribution & Toolboard connection Problems:
                                      this would indicate that there is something wrong with your can wiring.
                                      • Frederikundefined
                                        Frederik @Veti
                                        @Veti I use a straight through 4 pin can cable that I made with the lc1 connector pack
                                        • Vetiundefined
                                          Veti
                                          have you done the simple setup and tested that?
                                          https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/IgXsNbOKcEAWjeNO.huge
                                          also check the continuity of your can wiring. a bad crimp here will also be a headache.
                                          • Frederikundefined
                                            Frederik @Veti
                                            @Veti I would try if I'd had a 120ohm resistor and a spare rj11 cable at Hand. I can source a bunch of those resistors later at my local electro shop.
