    Distribution & Toolboard connection Problems
    1.6k
    • Frederikundefined
      Frederik @dc42
      @dc42 i used a stright trough 4 pin can cable
        Even without the CAN cable, with VIN power applied to the tool board you should get 2 LEDs lit and another one flashing. Please post photos showing how 24V power is supplied to VIN on the tool board.
        Frederikundefined 2 Replies Last reply Reply Quote 0
        • Frederikundefined
          Frederik @dc42
          @dc42 as soon as i am back from Work, i will post pictures.
          • Frederikundefined
            Frederik @dc42
            @dc42 I supplied the Vin direct from my 24v power supply to the Vin of the tool distribution board. And from there with the first port to the toolboard lc1. I need 2 more hours at my office. I will send you the pictures as soon as I am at home. Could I test some other parts with my multimeter to check the correct function?
            Regards
            Frederik
            • Frederikundefined
              Frederik
              I checked the connections and fuses with the multimeter. Everything ok. 24.1v on the toolboard. But no led are on.!IMG_20201209_191716.jpg
              • Frederikundefined
                Frederik
                • Frederikundefined
                  Frederik
                  @dc42 Thank you, Problem Solved.
                  I rewired the distro and toolboard + making new crimps for my vin cables.
                  i was measuring the 24v on the bottom of the connector and checked the polarity.
                  But somehow the connection made no contact to the toolboard.when plugged in
                  I also updated my duet3 to RRF 3.2beta4.1
                  now the blue led is on and the red led is constantly on like the diag led on the duet 3, but not flashing. Is the firmware wrong?
                  What is the next thing to check?
                  Pressing the 2 buttons while starting the board doesn't change the led signals.
                  Is there another way to reset the toolboard and check the CAN connection?
                  Regards
                    A Former User
                    it might not matter, but the tool distribution board you showed is missing a bypass jumper on the 4th unused output and doesn't show the jumper for the 1st you're actually using.
                    Frederikundefined 1 Reply Last reply Reply Quote 1
                    • Frederikundefined
                      Frederik @A Former User
                      @bearer thanks for pointing that out. I uploaded the wrong photo. The jumpers are both removed from the first port with the cable and are set in every else slot.IMG_20201210_061343.jpg
                      I test both ways. With only one of the two jumpers removed and both jumpers removed. The same result in the console and no change in led behavior.
                      • Frederikundefined
                        Frederik
                        M122
                        RepRapFirmware for Duet 3 MB6HC version 3.2-beta4 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                        Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
                        Used output buffers: 1 of 40 (11 max)
                        Static ram: 123212
                        Dynamic ram: 138092 of which 24 recycled
                        Never used RAM 130864, free system stack 200 words
                        Tasks: Linux(ready,101) HEAT(blocked,298) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1189) IDLE(ready,19)
                        Owned mutexes: HTTP(MAIN)
                        Last reset 00:01:10 ago, cause: power up
                        Last software reset at 2020-12-10 01:00, reason: User, GCodes spinning, available RAM 130864, slot 2
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task Linu
                        Error status: 0x00
                        MCU temperature: min 26.1, current 35.2, max 35.3
                        Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                        12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                        Driver 0: position 0, standstill, reads 21528, writes 14 timeouts 0, SG min/max 0/0
                        Driver 1: position 0, standstill, reads 21529, writes 14 timeouts 0, SG min/max 0/0
                        Driver 2: position 0, standstill, reads 21530, writes 14 timeouts 0, SG min/max 0/0
                        Driver 3: position 0, standstill, reads 21533, writes 11 timeouts 0, SG min/max 0/0
                        Driver 4: position 0, standstill, reads 21534, writes 11 timeouts 0, SG min/max 0/0
                        Driver 5: position 0, standstill, reads 21532, writes 14 timeouts 0, SG min/max 0/0
                        Date/time: 2020-12-10 06:17:24
                        Slowest loop: 0.90ms; fastest: 0.12ms
                        === Storage ===
                        Free file entries: 10
                        === MainDDARing ===
                        Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === AuxDDARing ===
                        Segments left: 0
                        Movement lock held by null
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        Code queue is empty.
                        === CAN ===
                        Messages queued 158, send timeouts 510, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 47
                        === SBC interface ===
                        State: 0, failed transfers: 0
                        Last transfer: 19ms ago
                        RX/TX seq numbers: 1334/1335
                        SPI underruns 0, overruns 0
                        Number of disconnects: 0, IAP RAM available 0x20a28
                        Buffer RX/TX: 0/0-0
                        === Duet Control Server ===
                        Duet Control Server v3.2.0-beta4
                        Code buffer space: 4096
                        Full transfers per second: 0.11
                        • Frederikundefined
                          Frederik
                          M997 B121 S3
                          Error: M997: Response timeout: CAN addr 121, req type 6024, RID=14
                          everything I try only generates this timeouts. M115, M122, M997... Are there other parts to test with the multimeter to ensure that I got a working unit?
                          • Vetiundefined
                            Veti @Frederik
                            @Frederik said in Distribution & Toolboard connection Problems:
                            this would indicate that there is something wrong with your can wiring.
                            Frederikundefined 1 Reply Last reply Reply Quote 0
                            • Frederikundefined
                              Frederik @Veti
                              @Veti I use a straight through 4 pin can cable that I made with the lc1 connector pack
                              • Vetiundefined
                                Veti
                                have you done the simple setup and tested that?
                                https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/IgXsNbOKcEAWjeNO.huge
                                also check the continuity of your can wiring. a bad crimp here will also be a headache.
                                • Frederikundefined
                                  Frederik @Veti
                                  @Veti I would try if I'd had a 120ohm resistor and a spare rj11 cable at Hand. I can source a bunch of those resistors later at my local electro shop.
                                  • Frederikundefined
                                    Frederik
                                    @Veti i checked for continuity with the multimeter. Seems to be OK
                                    • Vetiundefined
                                      Veti @Frederik
                                      for the entire chain? with the distribution board?
                                      • Frederikundefined
                                        Frederik
                                        Could a short to the stepper motor metal case cause the board to behave like that?
                                        • Frederikundefined
                                          Frederik @Veti
                                          @Veti only the can cable.
                                          Main - > distro is the original cable that comes with the distro board
                                          • Vetiundefined
                                            Veti @Frederik
                                            @Frederik
                                            please check the entire chain.
                                            pull out the plug on the duet 3 and the 1lc and check the resistance for the L and H can cable with the toolboard beeing in place
