SOLVED Z Probe shows 1000
After installing the "Flex3Drive" extruder on the smart effector, when the "hot end" heats up above 90 Deg, the "Z Probe" starts to show "1000".
M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
M557 R90 S20 ; Define mesh gridPlease tell me how to fix this?
Duet 2 WiFi
Firmware: 2.05.1 (2020-02-09b1)
Sound like a wiring problem, or interference.
This post is deleted!
@Phaedrux At first I also thought it was a wiring problem and changed the tips on the wires. But nothing has changed...
In addition, I assembled the extruder according to the instructions from the official website without any improvisation...
After several experiments, I noticed that if you turn off the cooling fan "Z-Probe" returns to normal.
that means the vibration from the fan trigger the smart effector.
try reducing the sensitivity
https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
@Veti Thank you so much, now everything works! Five* )
