MPCNC: Duet 3 + SBC + Dual Endstop for X and Y axes.
@Phaedrux said in MPCNC: Duet 3 + SBC + Dual Endstop for X and Y axes.:
The fact that M119 isn't showing a status change makes me think the wiring isn't making a connection.
Those white connectors that came with official duet 3 were not making contact with the endstop pins, i removed them and replaced them with black dupont pins.
Thank you, it works well now!
Ok good, glad we're not crazy.
Did the crimp get a bit too crushed maybe? Or maybe the 5 pin connector just needs most of the wire spots populated to get enough pressure on the connector?
I think i will attribute it to my user error. I have never crimped those white ones (JST? right?). But for some reason I could test continuity in them from the housing, they were not connecting to the pin when they were inserted in.
I am glad that we are not crazy, for sure for sure!
I had a similar problem. I just bent the little pins before I put them in the connector for the one that had that problem.
