    Duet 3 6HC motor issues
    503
      jay_s_uk
      Only 1 of my 6 stepper motors on my duet 3 6HC are working any more.
      No issues being reported in M122.
      I have tried rolling back to 3.1.1 and back to the latest 3.2 beta 4.1 without avail.
      I have removed the board from the machine and inspected it but I can't see any areas where the magic smoke has escaped.
      I have also checked the fuses and they are both intact. If it was damaged, I would expect none of the drivers to work?
      Anyone have any thoughts?
        What does M122 actually report for the drivers, both before and after commanding movement?
        jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @Phaedrux
          @Phaedrux I'll reconnect and post a report.
          It's only driver 0 that actually moves.
          The thermocouple for the heated bed also reads the incorrect value.
            jay_s_uk @Phaedrux
            @Phaedrux
            before movement
            RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
            Board ID: 08DJM-956L2-G43S4-6J1DL-3SJ6N-186LG
            Used output buffers: 1 of 40 (24 max)
            Static ram: 123292
            Dynamic ram: 169632 of which 996 recycled
            Never used RAM 98272, free system stack 188 words
            Tasks: NETWORK(ready,165) ETHERNET(blocked,114) HEAT(blocked,303) CanReceiv(blocked,854) CanSender(blocked,371) CanClock(blocked,360) TMC(blocked,54) MAIN(running,1125) IDLE(ready,19)
            Owned mutexes:
            Last reset 00:00:29 ago, cause: power up
            Last software reset at 2020-12-13 21:08, reason: User, GCodes spinning, available RAM 98272, slot 1
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task MAIN
            Error status: 0x00
            MCU temperature: min 18.0, current 18.7, max 19.1
            Supply voltage: min 26.9, current 27.0, max 27.0, under voltage events: 0, over voltage events: 0, power good: yes
            12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
            Driver 0: position 0, ok, reads 55121, writes 0 timeouts 0, SG min/max 0/0
            Driver 1: position 0, ok, reads 55121, writes 0 timeouts 0, SG min/max 0/0
            Driver 2: position 0, ok, reads 55122, writes 0 timeouts 0, SG min/max 0/0
            Driver 3: position 0, ok, reads 55121, writes 0 timeouts 0, SG min/max 9/9
            Driver 4: position 0, ok, reads 55121, writes 0 timeouts 0, SG min/max 9/9
            Driver 5: position 0, ok, reads 55121, writes 0 timeouts 0, SG min/max 9/9
            Date/time: 2020-12-13 21:09:09
            Slowest loop: 22.35ms; fastest: 0.21ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected, interface speed: 25.0MBytes/sec
            SD card longest read time 14.0ms, write time 0.0ms, max retries 0
            FreeDm 375 (min 375), maxWait 0ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 22.60ms; fastest: 0.03ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
            HTTP sessions: 1 of 8
            - Ethernet -
            State: active
            Error counts: 0 0 0 0 0
            Socket states: 5 2 2 2 2 0 0 0
            === CAN ===
            Messages queued 46, send timeouts 0, received 138, lost 0, longest wait 0ms for reply type 0, free buffers 47
            After movement
            m122
            Static ram: 123292
            Dynamic ram: 169904 of which 724 recycled
            Never used RAM 98272, free system stack 126 words
            Tasks: NETWORK(ready,165) ETHERNET(blocked,114) HEAT(blocked,303) CanReceiv(blocked,854) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1125) IDLE(ready,19)
            Owned mutexes:
            Last reset 00:01:02 ago, cause: power up
            Error status: 0x00
            MCU temperature: min 18.6, current 19.8, max 19.9
            12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
            Driver 0: position 0, ok, reads 27234, writes 3 timeouts 0, SG min/max 0/0
            Driver 1: position 0, ok, reads 27234, writes 3 timeouts 0, SG min/max 0/0
            Driver 2: position 8000, ok, reads 27234, writes 3 timeouts 0, SG min/max 0/0
            Driver 3: position 460, ok, reads 27235, writes 3 timeouts 0, SG min/max 9/9
            Driver 4: position 0, ok, reads 27235, writes 3 timeouts 0, SG min/max 9/9
            Driver 5: position 0, ok, reads 27235, writes 3 timeouts 0, SG min/max 9/9
            Date/time: 2020-12-13 21:09:41
            Slowest loop: 5.73ms; fastest: 0.22ms
            === Storage ===
            Free file entries: 7
            SD card longest read time 0.8ms, write time 0.0ms, max retries 0
            FreeDm 373 (min 373), maxWait 49180ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 4, completed moves 3, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by HTTP
            HTTP is idle in state(s) 1 0 0 8, running macro
            === Network ===
            Slowest loop: 9.74ms; fastest: 0.03ms
            - Ethernet -
            State: active
            === CAN ===
            Messages queued 130, send timeouts 0, received 393, lost 0, longest wait 0ms for reply type 0, free buffers 47
            That was after a command to unlock my tool lock (driver 2) and home the machine in X and Y (driver 0 and 1).
            Only driver 0 moved.
            This is after a command to move the bed (drivers 3 to 5)
            Used output buffers: 1 of 40 (14 max)
            Static ram: 123292
            Never used RAM 98272, free system stack 164 words
            Tasks: NETWORK(ready,195) ETHERNET(blocked,110) HEAT(blocked,197) CanReceiv(blocked,854) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1105) IDLE(ready,19)
            Owned mutexes:
            Last reset 00:02:02 ago, cause: software
            Last software reset at 2020-12-13 21:09, reason: User, GCodes spinning, available RAM 98272, slot 2
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
            Error status: 0x00
            MCU temperature: min 19.4, current 21.3, max 21.4
            Driver 0: position 0, ok, reads 7290, writes 14 timeouts 0, SG min/max 0/0
            Driver 1: position 0, ok, reads 7291, writes 14 timeouts 0, SG min/max 0/0
            Driver 2: position 80000, ok, reads 7292, writes 14 timeouts 0, SG min/max 0/0
            Driver 3: position 0, ok, reads 7288, writes 19 timeouts 0, SG min/max 0/9
            Driver 4: position 0, ok, reads 7290, writes 19 timeouts 0, SG min/max 0/9
            Driver 5: position 0, ok, reads 7291, writes 19 timeouts 0, SG min/max 0/9
            Date/time: 2020-12-13 21:11:50
            Slowest loop: 6.19ms; fastest: 0.21ms
            === Storage ===
            SD card longest read time 0.7ms, write time 0.0ms, max retries 0
            FreeDm 375 (min 373), maxWait 78374ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 2, completed moves 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
            === AuxDDARing ===
            Segments left: 0
            === Network ===
            Slowest loop: 8.37ms; fastest: 0.03ms
            - Ethernet -
            State: active
            === CAN ===
            Messages queued 527, send timeouts 0, received 1509, lost 0, longest wait 1ms for reply type 6042, free buffers 47
            If I try and heat up the bed, the temperature goes down...
            edit: the reset in the last M122 was me hitting emergency stop so the motor that was actually moving wouldn't cause the carriage to come into contact with the frame
              jay_s_uk
              I've unplugged all the drivers and have connected only 1 to driver 1 and there in no movement. It appears as though only driver 0 is working any more
                1. Send M906 and M913 without parameters, to check that the drivers have been configured with the correct current. Also send M92 to check that a sensible steps/mm has been configured.
                2. When you try to move motors, do the motors become difficult to turn by hand, and do they become easier to turn again when you send M18 to disable the drivers? That would indicate that the motors are being energised by the drivers.
                  jay_s_uk @dc42
                  @dc42 here is the output of M906 and M913
                  m906
                  Motor current (mA) - X:1400, Y:1400, Z:2200, U:1400, E:800:1050:800, idle factor 30%
                  m913
                  Motor current % of normal - X:100, Y:100, Z:100, U:100, E:100:100:100
                  When commanding the z motors to move, they are still free to move, indicating they are not being energised.
                  For completeness, here is my config.g
                  ; generated by RepRapFirmware Configuration Tool v2.1.4 on Mon Dec 09 2019 17:42:21 GMT+0000 (Greenwich Mean Time)
                  ;############## General Preferences ##################
                  M555 P2															; Marlin-style Outputs
                  G21                                     						; Set dimensions to millimetres
                  G90                                     						; send absolute coordinates...
                  M83                                     						; ...but relative extruder moves
                  M550 P"Toolchanger"                            					; set printer name
                  M552 S1
                  ;############## Axis Mapping #########################
                  M584 X0.0 Y0.1 Z0.3:0.4:0.5 E1.0:1.1:1.2 U0.2 P3          			; X and Y for CoreXY.  U for toolchanger lock. Z has three drivers for kinematic bed suspension.
                  ;############## Drive Direction ######################
                  M569 P0.0 S1                            						; Drive 0 direction | X stepper
                  M569 P0.1 S1                           							; Drive 1 direction | Y Stepper
                  M569 P0.2 S1                            						; Drive 2 direction | U Tool Changer Lock
                  M569 P0.3 S1                            						; Drive 3 direction | Front Left Z
                  M569 P0.4 S1													; Drive 4 direction | Front Right Z
                  M569 P0.5 S1													; Drive 5 direction | Back Z
                  M569 P1.0 S0													; Drive 6 direction | Tool 1
                  M569 P1.1 S1 D2													; Drive 6 direction | Tool 2
                  M569 P1.2 S1													; Drive 6 direction | Tool 3
                  ;############## Kinematics ###########################
                  M669 K1                                 						; CoreXY mode
                  ;############## Leadscrew Location ###################
                  ; Leadscrew locations (really, kinematic coupling locations) extracted from CAD model assuming back right build plate corner is (0, 0)
                  M671 X250:-250:0 Y270:270:-265 S20 								; Front Left: (484.5, 548.5) | Front Right: (-6, 548) | Back: (244.5, 17)
                  ;############## Microstepping ########################
                  M350 X16 Y16 U16 Z16 E16:16:16 I1             					; Configure microstepping with interpolation
                  ;############## Steps Per mm #########################
                  M92 X160 Y160 U46 Z1600 E415:397.5:394  						; Set steps per mm
                  ;############## Speeds and Feeds #####################
                  M566 X1000 Y1000 Z20 E120:8000:8000 U2     						; Set maximum instantaneous speed changes (mm/min). Values of X and Y were 1400
                  M203 X25000 Y25000 Z400 E1200:20000:20000 U5000 				; Set maximum speeds (mm/min)
                  M201 X1000 Y1000 Z200 E250:1300:1300 U1000    					; Set accelerations (mm/s^2) Values of X and Y were 6000
                  M204 P500
                  M906 X1400 Y1400 U1400 Z2200 E800:1050:800 I30    				; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                 						; Set idle timeout
                  ;############## Axis Limits ##########################
                  M208 X-246.5 Y-274 Z0 U0 S1                        				; Set axis minima
                  M208 X255 Y274 Z500 U180 S0                  					; Set axis maxima
                  ;############## Endstops #############################
                  M574 X1 S1 P"io1.in"                    						; Configure active-high endstop for low end on X via pin io1.in
                  M574 Y1 S1 P"io2.in"                    						; Configure active-high endstop for low end on Y via pin io2.in
                  ;############## Z-Probe ##############################
                  M558 P5 C"io4.in" H1 A5 F120 T20000 S0.02       				; Set Z probe type to switch and the dive height + speeds
                  G31 P500 X0 Y0 Z0												; Set Z probe trigger value, offset and trigger height
                  M557 X-225:225 Y-225:225 S30                					; Define mesh grid
                  ;############## Bed Heater ###########################
                  M308 S0 P"spi.cs3" Y"thermocouple-max31855" T"K"				; Configure sensor 0 as thermocouple via CS pin spi.cs1
                  M950 H0 C"out1" T0 Q10                     						; Create bed heater output on out0 and map it to sensor 0
                  M143 H0 S180                            						; Set temperature limit for heater 0 to 180C
                  M307 H0 B0 S1.00                        						; Disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                 						; Map heated bed to heater 0
                  ;############## Tool 0 Heaters #######################
                  M308 S1 P"1.temp0" Y"thermistor" T100000 B4725 C7.06e-8 		; Configure sensor 1 as thermistor on pin 1.temp0
                  M950 H1 C"1.out0" T1                                    		; Create nozzle heater output on 1.out0 and map it to sensor 1
                  M143 H1 S280                                            		; Set temperature limit for heater 1 to 280C
                  M307 H1 B0 S1.00                                        		; Disable bang-bang mode for the nozzle heater and set PWM limit
                  ;############## Tool 0 Fans ##########################
                  M950 F0 C"1.out3" Q500                    						; Create fan 0 on pin out3 and set its frequency
                  M106 P0 S0 H-1                          						; Set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"1.out6" Q500                    						; Create fan 1 on pin out4 and set its frequency
                  M106 P1 S1 H1 T45                       						; Set fan 1 value. Thermostatic control is turned on
                  ;############## Tool 0 Switch ########################
                  M950 J0 C"1.io0.in"												; Tool 0 detector switch
                  ;############## Tool 1 Heaters #######################
                  M308 S2 P"1.temp1" Y"thermistor" T100000 B4725 C7.06e-8 		; Configure sensor 1 as thermistor on pin 1.temp0
                  M950 H2 C"1.out1" T2                                    		; Create nozzle heater output on 1.out0 and map it to sensor 1
                  M143 H2 S300                                            		; Set temperature limit for heater 1 to 280C
                  M307 H2 B0 S1.00                                        		; Disable bang-bang mode for the nozzle heater and set PWM limit
                  ;############## Tool 1 Fans ##########################
                  M950 F2 C"1.out7" Q500                    						; Create fan 0 on pin out3 and set its frequency
                  M106 P2 S0 H-1                          						; Set fan 0 value. Thermostatic control is turned off
                  M950 F3 C"1.out4" Q500                    						; Create fan 1 on pin out4 and set its frequency
                  M106 P3 S1 H2 T45                       						; Set fan 1 value. Thermostatic control is turned on
                  ;############## Tool 1 Switch ########################
                  M950 J1 C"1.io1.in"												; Tool 1 detector switch
                  ;############## Tool 2 Heaters #######################
                  M308 S3 P"0.temp0" Y"thermistor" T100000 B4725 C7.06e-8 		; Configure sensor 1 as thermistor on pin 1.temp0
                  M950 H3 C"out2" T3                                    			; Create nozzle heater output on 1.out0 and map it to sensor 1
                  M143 H3 S300                                            		; Set temperature limit for heater 1 to 280C
                  M307 H3 B0 S1.00                                        		; Disable bang-bang mode for the nozzle heater and set PWM limit
                  ;############## Tool 2 Fans ##########################
                  M950 F4 C"0.out7" Q500                    						; Create fan 0 on pin out3 and set its frequency
                  M106 P4 S0 H-1                          						; Set fan 0 value. Thermostatic control is turned off
                  M950 F5 C"0.out4" Q500                    						; Create fan 1 on pin out4 and set its frequency
                  M106 P5 S1 H3 T45                       						; Set fan 1 value. Thermostatic control is turned on
                  ;############## Tool 2 Switch ########################
                  M950 J1 C"1.io3.in"												; Tool 1 detector switch
                  ;############## Tools ################################
                  M563 P0 S"BMG Tool" D0 H1 F0          							; Px = Tool number, Dx = Drive Number (start at 0, after movement drives), H1 = Heater Number, Fx = Fan number print cooling fan
                  G10  P0 S0 R0                       							; Set tool 0 operating and standby temperatures(-273 = "off")
                  M563 P1 S"Hemera" D1 H2 F2          							; Px = Tool number, Dx = Drive Number (start at 0, after movement drives), H1 = Heater Number, Fx = Fan number print cooling fan
                  G10  P1 S0 R0                       							; Set tool 1 operating and standby temperatures(-273 = "off")
                  M563 P2 S"Hemera 2" D2 H3 F4          							; Px = Tool number, Dx = Drive Number (start at 0, after movement drives), H1 = Heater Number, Fx = Fan number print cooling fan
                  G10  P2 S0 R0                       							; Set tool 1 operating and standby temperatures(-273 = "off")
                  ;############## Pressure Advance #####################
                  M572 D1 S0.03 													; Pressure advance T1 - Taken from E3D tool changer
                  ;############## Custom settings ######################
                  M98 P"/sys/Toffsets.g"                  						; Set tool offsets from the bed. In separate file so test macro can invoke.
                  M98 P"/sys/FilamentRetraction.g"								; Set Filament Retraction
                  M593 F36.36														; Dynamic Acceleration Adjustment
                  ;############## Miscellaneous ########################
                  M501                                    						; Load saved parameters from non-volatile memory
                    I forgot to say: also send M584 without parameters, to check that the drive mappings are as expected; and send M569 P0, M569 P1, M569 P2 etc. to check that the drivers have not been disabled.
                    I think something is wrong with your configuration, because the reported driver position is not changing when you move Z.
                    To test five drivers at once, I normally send the following commands:
                    M584 X0:1:2:3:4
                    M906 X1000
                    M913 X100
                    G91
                    G1 H2 X10
                    and see which motors move.
                      jay_s_uk @dc42
                      @dc42 M584 driver mappings
                      m584
                      Driver assignments: X0.0 Y0.1 Z0.3:0.4:0.5 U0.2 E1.0:1.1:1.2, 3 axes visible
                      I modified my config to replace the M584 with the following line
                      M584 X0.0:0.1:0.2:0.3:0.4:0.5 Y1.0 Z1.1 E1.2
                      Here is the output from M584 with the modified driver assignment
                      m584
                      Driver assignments: X0.0:0.1:0.2:0.3:0.4:0.5 Y1.0 Z1.1 E1.2, 3 axes visible
                      m122 before sending your suggest command
                      Used output buffers: 1 of 40 (12 max)
                      Static ram: 123292
                      Dynamic ram: 169052 of which 568 recycled
                      Never used RAM 99280, free system stack 200 words
                      Tasks: NETWORK(ready,167) ETHERNET(blocked,111) HEAT(blocked,301) CanReceiv(blocked,868) CanSender(blocked,371) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1125) IDLE(ready,19)
                      Owned mutexes:
                      Last reset 00:00:47 ago, cause: software
                      Last software reset at 2020-12-14 08:25, reason: User, GCodes spinning, available RAM 99280, slot 0
                      Error status: 0x00
                      MCU temperature: min 22.7, current 23.2, max 23.3
                      Driver 0: position 0, ok, reads 33670, writes 14 timeouts 0, SG min/max 0/0
                      Driver 1: position 0, ok, reads 33672, writes 14 timeouts 0, SG min/max 0/0
                      Driver 2: position 0, ok, reads 33673, writes 14 timeouts 0, SG min/max 0/0
                      Driver 3: position 0, ok, reads 33674, writes 14 timeouts 0, SG min/max 0/9
                      Driver 4: position 0, ok, reads 33675, writes 14 timeouts 0, SG min/max 0/9
                      Driver 5: position 0, ok, reads 33676, writes 14 timeouts 0, SG min/max 0/9
                      Date/time: 2020-12-14 08:26:02
                      Slowest loop: 6.08ms; fastest: 0.21ms
                      === Storage ===
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      === Network ===
                      Slowest loop: 6.83ms; fastest: 0.03ms
                      - Ethernet -
                      State: active
                      === CAN ===
                      Messages queued 218, send timeouts 0, received 217, lost 0, longest wait 185ms for reply type 6027, free buffers 47
                      M122 after sending the movement command for the X axis (comprising of 0.0:0.1:0.2:0.3:0.4:0.5)
                      Used output buffers: 1 of 40 (23 max)
                      Static ram: 123292
                      Never used RAM 99280, free system stack 164 words
                      Tasks: NETWORK(ready,167) ETHERNET(blocked,111) HEAT(blocked,301) CanReceiv(blocked,868) CanSender(blocked,352) CanClock(blocked,356) TMC(blocked,54) MAIN(running,1125) IDLE(ready,19)
                      Owned mutexes: LwipCore(NETWORK)
                      Last reset 00:01:13 ago, cause: software
                      Error status: 0x00
                      MCU temperature: min 23.0, current 23.2, max 23.3
                      Driver 0: position 4800, ok, reads 61292, writes 15 timeouts 0, SG min/max 0/0
                      Driver 1: position 0, ok, reads 61291, writes 15 timeouts 0, SG min/max 0/0
                      Driver 2: position 0, ok, reads 61291, writes 15 timeouts 0, SG min/max 0/0
                      Driver 3: position 0, ok, reads 61291, writes 15 timeouts 0, SG min/max 9/9
                      Driver 4: position 0, ok, reads 61291, writes 15 timeouts 0, SG min/max 9/9
                      Driver 5: position 0, ok, reads 61291, writes 15 timeouts 0, SG min/max 9/9
                      Date/time: 2020-12-14 08:26:28
                      Slowest loop: 5.07ms; fastest: 0.22ms
                      === Storage ===
                      SD card longest read time 0.6ms, write time 0.0ms, max retries 0
                      FreeDm 375 (min 374), maxWait 70331ms, bed compensation in use: none, comp offset 0.000
                      === MainDDARing ===
                      Scheduled moves 3, completed moves 3, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                      === AuxDDARing ===
                      Segments left: 0
                      === Network ===
                      Slowest loop: 7.59ms; fastest: 0.03ms
                      - Ethernet -
                      State: active
                      === CAN ===
                      Messages queued 108, send timeouts 0, received 105, lost 0, longest wait 0ms for reply type 0, free buffers 47
                        jay_s_uk
                        I've ran a cut down config with no change.
                        When turning the heated bed on (SSR controlled 240v), the temperature decreases from 22 degrees c to 11 degrees c before faulting
                          dc42 administrators @jay_s_uk
                          @jay_s_uk said in Duet 3 6HC motor issues:
                          You need to swap the 2 wires from the thermocouple where they connect to the daughter board.
                            jay_s_uk
                            that'll be after i disconnected everything and reconnected it all one by one to make sure there were no connection errors.
                            I am still unable to use drivers 1 to 5 on the 6HC.
                            I have generated a new config from the config tool without change
                              jay_s_uk
                              Same config on another duet 3 works, so I don't think its a configuration issue.
                              @dc42 any other thoughts?
                                jay_s_uk
                                @dc42 any more thoughts on this?
                                I still can't use drivers 1 to 5 which means this board is a very expensive but useless paperweight
                                  Sorry for the delay. We'd like that board back for testing. So please contact your vendor and initiate a warranty exchange. Include a link to this thread as authorization.
                                    Phaedrux Moderator @jay_s_uk
                                    @jay_s_uk When you send it back can you include a note to "test with ATE and send to David for examination"?
                                      jay_s_uk @Phaedrux
                                      @Phaedrux will do!
