IDEX Toolchange Fan Control
I have a fan control problem on my IDEX Printer. In tfree0 and tfree1 I have add the command M106 S0 so that the Fans are switched off when the Tool is not used.
In tpost0 and tpost1 there is M106 R2 to switch the Fan on again when the Tool is active.
If the respective Tool is active, the Fan do not switch on.
In Simplify3D I have set the Fans should run from the 3rd Layer.
Why don't the fans Start?Thanks for your help
Please post your config.g file. Which firmware version are you using?
I‘m using 3.1.1
Thais my config.g :; General preferences
M550 P"Der Duale" ; set printer name;-------------------------------- Network ----------------------------------------------------------
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet;--------------------------------- Display PanelDue 7i ----------------------------------------------
M575 P1 S1 B57600
;----------------------------------------- Drives ----------------------------------------------------
M569 P0 S1 ; physical drive 0 goes backwards x
M569 P1 S0 ; physical drive 1 goes backwards y
M569 P3 S1 ; physical drive 3 goes forwards u
M569 P2 S1 ; physical drive 2 goes forwards z links
M569 P9 S0 ; physical drive 9 goes forwards z hinten rechts
M569 P4 S1 ; physical drive 4 goes forwards z rechts
M569 P5 S1 ; physical drive 5 goes backwards extruder links
M569 P6 S1 ; physical drive 6 goes forwards extruder rechtsM584 X0 Y1 Z2:9:4 U3 E5:6 ; set drive mapping
M671 X-132:148:428 Y-25:385:-55 S5 ; Positionen der Trapezgewindespindel für das Bed Leveling
M350 X16 U16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
M92 X80.00 U80.0 Y80.00 Z2133.33 E415.00:415.00 ; set steps per mm
M566 X900.00 U900.00 Y900.00 Z12.00 E600.00:600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 U12000.00 Y12000.00 Z600.00 E36000.00:36000.00 ; set maximum speeds (mm/min)
M201 X1000.00 U1000.00 Y1000.00 Z250.00 E800.00:800.00 ; set accelerations (mm/s^2)
M906 X1000 U1000 Y1000 Z1000 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S120 ; Set idle timeout;------------------------------------------------- Axis Limits -------------------------------------------------
;M208 X-88 U0 Y-40 Z0 S1 ; set axis minima
;M208 X278 U368 Y295 Z280 S0 ; set axis maxima
M208 X-88: 290 U0: 380 Y-25: 325 Z0: 270;------------------------------------------------- Endstops -------------------------------------------------------
M574 U2 S1 P"e0stop" ; configure active-high endstop for low end on U via pin e0stop
M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
;M574 Z2:4 S1 P"zstop + e1stop" ; configure active-high endstop for low end on 2 Z Motoren via pin zstop + e1stop
M574 Z0 S2 ; Z-Home mit Sonde;-------------------------------------------------- Z-Probe --------------------------------------------------------------
M558 P5 C"zprobe.in" H5 F150 T10000 ; disable Z probe but set dive height, probe speed and travel speed
G31 P500 X0 Y25 Z0.8404
M557 X0:280 Y20:290 S20 ; define mesh grid;-------------------------------------------------- Heaters -----------------------------------------------------------------
;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M307 H0 A214.2 C887.4 D1.5 S1.00 V24.0 B0 ; PID Tuning
M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
M950 H1 C"duex.e2heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M307 H1 A606.0 C166.7 D3.6 S1.00 V24.1 B0 ; PID Tuning
M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"duex.e3heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
;M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M307 H2 A581.7 C168.9 D3.2 S1.00 V24.1 B0 ; PID Tuning;---------------------------------------------------- Fans -------------------------------------------------------------------
M950 F0 C"duex.fan4" Q500 ; create fan 0 on pin duex.fan3 and set its frequency
M950 F1 C"duex.fan3" Q500 ; create fan 1 on pin duex.fan4 and set its frequency
M950 F2 C"duex.fan5" Q500 ; create fan 2 on pin duex.fan5 and set its frequency
M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
M950 F3 C"duex.fan6" Q500 ; create fan 3 on pin duex.fan6 and set its frequency
M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on;----------------------------------------------------- Tools ---------------------------------------------------------------
M563 P0 S"Tool 1 links" D0 H1 F0 ; define tool 0
M563 P1 S"Tool 2 rechts" D1 H2 X3 F2 ; define tool 1
G10 P1 U0 Y0.05 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
Any Idea?
Can you include your tool change files and a sample sliced gcode file?
Here is the gode:
Würfel ohne Toolchange Script.gcodetfree0:
M83 ; relative Extruderbewegung
G1 E-1.4 F3600 ; 2mm einfahren
M106 S0 ; Schalten Sie den Drucklüfter aus P0
G91 ; relative Achsbewegung
;G1 Z3 F500; bis 3mm
G90 ; absolute Achsbewegung
G1 Y-25 F12000 ; Y uf -25mm fahren
G1 X-88 Y-25 F12000 ; Parken Sie den X-Wagen bei -88 mmtfree1:
M106 S0 ; Schalten Sie unseren Drucklüfter aus P2
G1 U371 F12000 ; Parken Sie den U-Wagen bei + 371 mmtpost0:
M106 R2 ; Stellen Sie die Geschwindigkeit des Drucklüfters wieder her Lüfter P0
M116 P0 ; Warten Sie, bis die Heizungen des Werkzeugs 0 die Betriebstemperatur erreicht haben
;G1 E2 F3600 ; 2mm extrudieren
G92 E0 ; zero the extruded distance
G1 E15 F1000 ; prime the new extruder
G1 F200 E15
G92 E0
G1 F5000 E-1G1 F20000 X-75
G1 F20000 X-48
G1 F20000 X-75
G1 F20000 X-48
G1 F20000 X-75
G1 F20000 X-48tpost1:
M106 R2 ; Stellen Sie die Geschwindigkeit des Drucklüfters wieder her Lüfter P2
M116 P1 ; Warten Sie, bis die Heizungen des Werkzeugs 1 die Betriebstemperatur erreicht haben
G1 F200 E15
G92 E0
G1 F5000 E-1G1 F20000 X357
G1 F20000 X328
G1 F20000 X357
G1 F20000 X328
G1 F20000 X357
G1 F20000 X328
@gringo said in IDEX Toolchange Fan Control:
If the respective Tool is active, the Fan do not switch on.So what I think is happening is that you are turning the fan off and then asking it to resume to the last set speed, which was off, so it's staying off.
Does that make sense?
Rnnn Restore fan speed to the value it has when the print was paused (R1) or the last time the fan speed was set and no P parameter was provided (R2).
At least that's my reading of what R2 does.
I think so too.
But if I want the Fans off for the first 2Layers. How do I Adjust that?
Can't you add a gcode process in s3d for that layer?
I have now set a fan speed for Layers 1, 2 and 3 of 1%, 50% and 100% in S3D.
I let Tool 1 heat up first, so it works now.
