Cancel print
When I press the Cancel print button, I kind of expect the print to be cancelled, heaters to be switched off and the printer reset to Home.
That last point doesn't happen. I need to switch pages, and find the Home All button.
Is there a way for me to modify the functionality of the button? Or is it baked in?
Put the codes you want the printer to do in the sys/stop.g file.
Actually it's the cancel.g file that gets run when a print is cancelled. If it isn't found then the motors and heaters are turned off but the head is not moved.
And if you don't turn off heaters in the cancel.g file, but you do have a cancel.g file (with g28, for eg) the heaters don't turn off. I like this feature very much, as I manually set Z height and so having the heaters remain on saves time when restarting a print to adjust z height.
