Duet2 WiFi Firmware on Raise 3d E2 ?
@Veti but unfortunately he no longer plays the original firmware on the board via the printer
not sure what you mean
@Veti https://support.raise3d.com/E2/how-to-update-the-motion-controller-firmware-20-1143.html
The printer does not do the firmware update because the board is flashed to 3.0
yes but the firmware updated to 3.0. that is what you wanted to do in the first place.
a lcd screen is not necessary for the operation of a duet. -
@Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
a lcd screen is not necessary for the operation of a duet.in my case it does
the WiFi module sits on the display controller -
@Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
in my case it does
the WiFi module sits on the display controllerwell you might want to change the eol and line settings in yat so that you can see the actual status of the wifi module.
i can only connect the motion board via usb.
the display controller is also operated via this interface -
they can easily just route the spi lines to the display.
that is why the full M122 output is relevant.
you probably did not update the wifi firmware when you updated to the rrf3 firmware. -
you probably did not update the wifi firmware when you updated to the rrf3 firmware.I cannot update the WiFi firmware.
because the wifi module is on a different board.
and I have no access to it via the pc -
the wifi firmware is not updated via the pc.
see
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmwarebut the M122 output is important
@jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
iap4e.bin
did you rename it to Duet2combinesIAP.bin like the error message says?
Duet2CombinedIAP is not the same as iap4e.bin! Renaming it will not work. You can get Duet2CombinedIAP.bin from one of the RRF 3.x releases.
@dc42 can I go back from V3.0 to V2.02 that easily?
@Proschi78 that'll be why the downgrade didn't work then.
use the IAP file dc42 linked to and the firmware from my google drive -
@jay_s_uk ok i will try today at noon
Hello everyone here who helped me. I was able to successfully install a version that was before 2.02. Then the printer could be updated via the Raise software. The whole thing was worth it for me, because now I have the possibility to control it via octoprint for whatever reason. thank you again
Do you think an original duet2 Wifi would work with the hardware components?
not with the display, but you only did a third of the firmware update of rrf3. it might be that you could update the board to 3.1.1
Yes that may be, but then I have no chance to use the display and control board. I am currently having the problem that the Gcode is being sent from the control board to the motionboard. This causes errors and the printer pauses printing, a stutter.
or if you want to invest some time and since you already have an octoprint server, run klipper with mainsail os.
