Duet2 WiFi Firmware on Raise 3d E2 ?
I am currently having the problem that the Gcode is being sent from the control board to the motionboard. This causes errors and the printer pauses printing, a stutter.
do you mean octoprint by control board to motionboard?
No, I connected Octoprint directly to the Motionboard. As a result, I have no way of controlling it directly at the printer.
since you are running stock configuration now, i suggest you take that up with raise 3d.
Do you think the error has been fixed with an original duet wifi + deux5 + display? The rest of the hardware would have to take part, since it is now based on a duet motionboard
I ordered a duetwifi. I'm curious how it goes
The duet wifi came today. I have a question about this, can I connect a second x axis instead of the second z axis?
Sure, board doesn't know what you're connecting, and firmware only cares about the config.
The two headers for the driver labeled Z are in series, and doesn't require any special configuration other than assigning driver 2 to x instead of z. To actually use two drivers you can follow the independent z axis instructions, just assign the drivers to x instead of z.
Alternatively you can also wire two motors in series or parallel to any of the other outputs with custom wiring as needed.
@Proschi78 did you ever get any reply from raise3d about the pinout/schematic of the board?
@jay_s_uk No, unfortunately not
@Proschi78 disappointing
@jay_s_uk said in Duet2 WiFi Firmware on Raise 3d E2 ?:
disappointing
yes it upsets me. but what should i do
@Proschi78 said in Duet2 WiFi Firmware on Raise 3d E2 ?:
Is likely very resource demanding to anything other than asking; maybe EFF has some tips?
Did you link them to this thread to rule out any lost in translation issues? I'd think they might care about the publicity of violating the license if they understood the issue.
they have released the source code. if they changed the pinout its in there.
i think that satisfies the license. -
@Veti said in Duet2 WiFi Firmware on Raise 3d E2 ?:
That's not how I read it
3.3. The Licensee may modify the Documentation or any portion thereof provided that upon modification of the Documentation, the Licensee shall make the modified Documentation available
Documentation include schematic etc (edit 3.4 sub-section d goes on to say the native cad files are preferred as well)
edit: added link to license and refrence to 3.4 d
I thank you, I will write again tomorrow
I have now written to her several times, but received no answer
well people do tend to take some days off between christmas and new years.
But they have answered enough questions from other users. I think it is simply ignored
Wish you all a healthy and better year 2021
Now I have installed the original Duet firmware.
The problem now is that the extruder thermistors at 250c are idling. If I then let it heat up to 300c, the temperature display goes backwards
What could that be?
