Duet 2 Maestro and FYSETC Mini12864
After creating my third Maestro Mini12864 wiring loom I thought it might be time to create a Pinout for others to reuse...
This is for the Mini12864 in Version 1.2 without RGB - tested with RC1 of Version 3.2
Could you just add which of the two chipsets that display uses? ST7920 or ST7565 iirc.
(and awesome, nice and clear I'm sure that'll be helpful to some and I'll be linking to it if I see questions about it!)
@bearer said in Duet 2 Maestro and FYSETC Mini12864:
The Mini12864 uses the ST7565. Displays with the ST7920 such as the reprep discount one are natively supported without the need of a dedicated wiring loom.
Configuration needed:
; Enable LCD M918 P2 E-4
