Underextrusion
Hey guys, im having another issue with my duet 2 ethernet board. I got now most of it working and printing works to one point, the extrusion. I use Cura for slicing, and set for the start a flow of 100%, but the prints look crappy. So i rechecked my steps/mm in my config.g and it looks fine. If i print with a flow multiplier of around 250% my prints look like a print, with a solid body. But why is it like this? Can anybody help me?
Config.g:
https://hastebin.com/umoceyitup.sql
Start/End Gcode:
https://hastebin.com/etiyuqiyir.properties
which extruder are you using?
check that you set the filament diameter to 1.75, the default in cura is 2.85.
its in the machine settings
@PCR bmg direct drive
SOLUTION
@Veti yep it was that, thank you!
