    Duet 5 mini Feedback
    31
    1.4k
    • Vetiundefined
      Veti
      I am in the process of setting up the mini 5+.
      Some feedback so far as its important.
      The wiring Diagram for the IO 0-4 Ports is in the wrong order.
      https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Wiring
      In the configurator i can only select out3-5 for fan.
      But the mini 5 has out6 as well.
      For BLtouch i can select io7.out. But there is no io7.
      • A Former User?
        A Former User @Veti
        @Veti said in Duet 5 mini Feedback:
        technically there are x7 outputs from io0 to io6 so i wouldn't say the wiring diagram is wrong at all, i would say its more a you cant get your head around the way the ports are numbered more than anything else.
        1 Reply Last reply Reply Quote -1
        • Vetiundefined
          Veti
          io7 is a problem in the configurator not the wiring diagram.
          • A Former User?
            A Former User @Veti
            BUT YOU SAID: The wiring Diagram for the IO 0-4 Ports is in the wrong order.
            So YOU need to make your mind up what is wrong one minute you wrote it was the wiring diagram now you are saying its the config tool, do you expect people to be mind readers?
            And the ports io0 to io6 are all CORRECT
            1 Reply Last reply Reply Quote -2
            • A Former User?
              A Former User
              Also I would advise using the config tool only as as method of obtaining a basic layout of the structure and then examining the wiring diagram AND the duet g.code page which will allow you to fully configure the board in the way you want
              And generate a good config.g
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti
                with order i mean the 3.3v is actually the 5v in and out are also swapped.
                • A Former User?
                  A Former User @Veti
                  @Veti
                  You didnt say that originally so again do you expect people to be mind readers ?
                  • Vetiundefined
                    Veti
                    sorry if it wasnt clear what i mean in the wrong order
                    • Vetiundefined
                      Veti @A Former User
                      @CaLviNx said in Duet 5 mini Feedback:
                      my config.g is already set up.
                      its just a bug that i noticed in the configurator that for bltouch you can select a port that does not exist.
                      • A Former User?
                        A Former User
                        I'm told my mini 5 is sitting in "customs" in larnaca so until i actually get my hands on it i cant comment as to whether 3.3 & 5v are swapped or not, i await someone from the duet team to provide an explanation
                        (EDIT) looking at the diagram between the mini5 and the duet 3 they both show the order for each plug as being:
                        3.3v
                        ioX.in
                        GND
                        ioX.out
                        5V EXT
                        So it would be somewhat strange for them to change things
                        zaptaundefined 1 Reply Last reply Reply Quote 0
                        • Vetiundefined
                          Veti
                          img upload in the forum isnt working for some reason
                          https://ibb.co/Vwz1Cnk
                          as you can see the io0 lowest pin close to the 26 pin header is 5v in the diagram its 3.3v
                          my endstops did not work at first because i wired them according to the diagram.
                          but the in and out are swapped.
                          • A Former User?
                            A Former User @Veti
                            @Veti
                            i wouldnt trust a screen print, now a multi-meter showing me what is actually being output to what pin i would
                            • Vetiundefined
                              Veti @A Former User
                              i already confirmed it with my endstops.
                              • A Former User?
                                A Former User
                                Then we wait for some info from the Duet team as to what has happened and if there are any changes between the 0.4 and 0.5 boards, as i see from your picture your board is an 0.4
                                @T3P3Tony
                                • Vetiundefined
                                  Veti
                                  the page i linked says Revision 0.4 and 0.5 above the picture
                                  change is 0.5 are here https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_Revision_0_Num_5
                                  • A Former User?
                                    A Former User @Veti
                                    @Veti
                                    yes but if you print the picture off it only shows as being 0.5
                                    • A Former User?
                                      A Former User
                                        I confirm, the pinout of IO0 thru IO5 in the wiring diagram is wrong. The pin labels on the underside of the board are correct.
                                        • T3P3Tonyundefined
                                          T3P3Tony administrators
                                          Apologies. I have fixed the diagram in the documentation.
                                          Thanks @Veti for reporting the issue.
                                          www.duet3d.com
                                          • Vetiundefined
                                            Veti
                                            @chrishamm
                                            Changes for the duet configurator for duet mini 5.
                                            PWM Control Channel (BLTouch only)
                                            according to https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview#Section_IO_port_pin_capabilities
                                            it should be io1-io3 out
                                            certainly not io7.out as that does not exist
                                            z probe input pin
                                            i would assume that it could also be io1-io3. io6 works as well. so maybe io0-6
                                            Fan mapping. maybe rename vfd to out6/vfd to specify the 4th fan header.
                                            chrishammundefined Vetiundefined 2 Replies Last reply Reply Quote 0
