Duet 5 mini Feedback
@Veti Thanks for the notes, fixed in the new configtool version 3.2.0.
@chrishamm could you push 3.2.0 to github please
@jay_s_uk said in Duet 5 mini Feedback:
you can find 3.2.0 Here
@Veti said in Duet 5 mini Feedback:
z probe input pin
i would assume that it could also be io1-io3. io6 works as well. so maybe io0-6zprobe in is now temp0-2 and io3. that is wrong
@CaLviNx its for modifying it for the LPC/STM32 Project. So @jay_s_uk need the source Files
Everything is connected and the printer is running fine now.
So the printer has the duet mini 5+
BLV metal kit.
Blind joints
SFU1204 Ball screws with metal mounting
BMG Wind direct drive extruder
X and Y 2A motors to push the TMC2209Just some more cable management to do.
Why are the belts twisted?
@CaLviNx said in Duet 5 mini Feedback:
I'm told my mini 5 is sitting in "customs" in larnaca so until i actually get my hands on it i cant comment as to whether 3.3 & 5v are swapped or not,
No need to wait, since it's open source hardware, you can check the design files on github.
"Open Hardware. All the hardware designs are licensed under the CERN OHL 1.2. The design files are released on GitHub." https://www.duet3d.com/
so that the smooth side of the belt runs across the idlers.
its part of the blv cube design. -
@zapta said in Duet 5 mini Feedback:
I'm lost what has this got to do with Cypriot customs trying to screw me?
And if as has been proven the diagram was wrong what's to say the design files on git hub can't also be wrong
The boards are manufactured from the design files so should match.
