    Software reset code 0x4050 help
    599
    • codfish124undefined
      codfish124
      hello I have been having a problem where my printer stops mid print this is my M122 log
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-95BLL-N6PSS-6J1F6-3SN6J-KJURJ
      Used output buffers: 1 of 20 (8 max)
      Static ram: 28476
      Dynamic ram: 96212 of which 0 recycled
      Exception stack ram used: 284
      Never used ram: 6100
      Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3484)
      Owned mutexes:
      Last reset 00:07:12 ago, cause: software
      Last software reset at 2020-12-25 23:19, reason: Watchdog timeout, spinning module Platform, available RAM 5544 bytes (slot 3)
      Software reset code 0x4050 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x1441f014 BFAR 0xe000ed38 SP 0x2001ff24 Task 0x5754454e
      Stack: 6e8d6a6e 0041735a 21000027 6e97f15d 2000dccc 6e8fe298 00000004 2000bf18 00000001 6e8faea7 2000a4d0 a5a5a5a5 a5a5a5a5 a5a5a5a5 00437567 00000105 2001abe8 00000001 ffffffe1 00000001 20006458 10000000 00000105
      Error status: 0
      Free file entries: 10
      MCU temperature: min 42.5, current 42.6, max 45.1
      Supply voltage: min 24.2, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0
      Date/time: 2020-12-25 23:26:57
      Slowest loop: 3.31ms; fastest: 0.07ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.12ms; fastest: 0.01ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 2c:3a:e8:0a:f3:e3
        WiFi Vcc 3.40, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 15912
        WiFi IP address 192.168.1.23
        WiFi signal strength -44dBm, reconnections 0, sleep mode modem
        === Expansion ===
        Please upgrade your firmware to 2.05.1.
          codfish124
          Thank you I upgraded firmware and that amplified the problem. I hade to lower some motor and speed values
          • Vetiundefined
            Veti
            post your config.g
              codfish124
              started again here is my config file.
              config.g
                codfish124
                and the error now
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Used output buffers: 1 of 24 (7 max)
                Static ram: 25712
                Dynamic ram: 93176 of which 0 recycled
                Exception stack ram used: 432
                Never used ram: 11752
                Tasks: NETWORK(ready,676) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:24:44 ago, cause: software
                Last software reset at 2020-12-26 18:52, reason: Heat task stuck, spinning module FilamentSensors, available RAM 11524 bytes (slot 3)
                Software reset code 0x40ad HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20004aa4 Task 0x4e49414d
                Stack: 0044d941 00445546 6100f000 00000000 4047f333 00000000 00000000 46c906f7 41800000 3e178897 3e1cd04f 3ce0de39 3e3a332b 3e638e2f 3e924928 3a4585a5 3984bb2c c0a00000 00000000 60000010 00000001 20002b88 0044d941
                Error status: 0
                Free file entries: 9
                SD card longest block write time: 9.3ms, max retries 0
                MCU temperature: min 41.8, current 43.8, max 44.3
                Supply voltage: min 24.0, current 24.2, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 3: standstill, SG min/max 0/270
                Date/time: 2020-12-26 19:17:30
                Slowest loop: 104.65ms; fastest: 0.06ms
                Hiccups: 6742410, FreeDm: 85, MinFreeDm: 85, MaxWait: 96745ms
                === DDARing ===
                Scheduled moves: 5148, completed moves: 5108, StepErrors: 0, LaErrors: 0, Underruns: 0, 3
                Heater 0 is on, I-accum = 0.0
                Heater 1 is on, I-accum = 0.5
                Segments left: 1
                file is doing "G1 X468.353 Y379.929 E81.05218" in state(s) 0
                === Network ===
                Slowest loop: 243.53ms; fastest: 0.00ms
                • WiFi -
                  WiFi firmware version 1.23
                  WiFi flash size 4194304, free heap 24904
                  WiFi signal strength -41dBm, reconnections 0, sleep mode modem
                • Vetiundefined
                  Veti
                  if you configure external drivers, you need to define the timing.
                    codfish124
                    it there im slopy with code
                    M569 P5 S1
                    M569 P6 S1
                    M569 P7 S0
                    M569 P8 S0
                    M569 P5 T3
                    M569 P6 T3
                    M569 P7 T5
                    M569 P8 T5
                    not sure how to get them in one line
                    maybe its M569 P6 T3 S1 ?
                    Vetiundefined 1 Reply Last reply Reply Quote 0
                      codfish124
                      config.g
                      made some changed updated every thing I could find still same problem this just happened been printing fine then all of a sudden this
                      • Vetiundefined
                        Veti @codfish124
                        @codfish124 said in Software reset code 0x4050 help:
                        M569 P6 T3 S1 ?
                        you have to look up the t parameters in your stepper driver documentation
                        https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers#Section_Configuring_the_Enable_polarity_and_step_timing
                        the t parameter takes 4 arguments.
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
                          dc42 administrators @codfish124
                          This is the problem:
                          M350 X256 Y256 Z128 I0 ; Configure microstepping without interpolation
                          You have set microstepping very high, which has led to an extremely high interrupt rate and a correspondingly large number of move hiccups:.
                          There is rarely any reason to set microstepping higher than x16 with interpolation enabled, except for some types of extruder with low steps/mm.
                          • Vetiundefined
                            Veti @dc42
                            @dc42 said in Software reset code 0x4050 help:
                            isnt the microstepping being ignored for external drivers?
                              dc42 administrators @Veti
                              @Veti said in Software reset code 0x4050 help:
                              Good point! However, the problem is still excessive microstepping, although in the external driver configuration rather than the M350 command. This is evident by the very high number of hiccups, and the very high Y steps/mm in the M92 command. I suggest reducing both X and Y microstepping to bring the X and Y steps/mm down to about 100 to 200.
                                codfish124
                                tried to get my Steppes per mm down this is a ball screw drivin unit so I'm down to 16 micro stepping and under 500
                                  codfish124
                                  seem to be working now thanks for the help
