    who can i mail this 6hc to to get it fixed
    Firmware installation
    firmware
    584
    • bamundefined
      bam
      id like to either send this to someone or do some kind of zoom meeting to get this fixed. rpi wont connect, diag led constant on, doesnt seem to boot.
      have tried using bossa (cant connect) bossa port doesnt show up when i plug it into the comp. have tried this with the pi build and on windows. windows doesnt even recognize that its a functional usb device. have tried many different micro usb cables for connection. tried to put files on a sd card just so that i could use it standalone mode. no dice. maybe that has to be burned on.
      • A Former User?
        A Former User
        couple of things;
        - if you're confident its not a usb cable/port/computer issue then odds are something needs replacing
        - if its still under warranty you might want to see if that covers the failure
        - if all else fails, see https://forum.duet3d.com/topic/13875/community-repairs
          When and where was the Duet 3 purchased?
          Certainly if it's defective we will replace it under warranty, but first we should check to see if we can get it working.
          What do you have on the SD card when trying to run in standalone mode?
          Have you tried clearing the Duet 3 firmware and seeing if it will flash with Bossa as described here?
          https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_To_update_via_USB_using_a_Windows_host
          bamundefined 2 Replies Last reply Reply Quote 0
          • bamundefined
            bam @Phaedrux
            @Phaedrux the mb has been reflashed with bossa. Not sure if it worked yet because I cannot get the DWC to connect to it. Or it to the DWC. the paneldue won’t connect to it either. I’m going to do a fresh install of duetpi tomorrow afternoon and go from there. Btw, The diag led on the 6hc constantly flashes. Not fast really, just a consistent constant flash.
            • bamundefined
              bam @Phaedrux
              @Phaedrux the main board was purchased through matterhackers mid nov. 2020 the panel due and 3eb from printed solid. Same time frame.
              • A Former User?
                A Former User @bam
                @bam said in who can i mail this 6hc to to get it fixed:
                given you have been able to flash it, the same computer and cable would be likely to still work (but I'd still try a different computer/cable after erasing)
                if the paneldue isn't connecting in standalone mode (with it enabled in config.g) to send M997 as an attempt at reflashing the board with firmware from sd card you've got nothing to loose by trying to erase the board and seeing if that allows you to flash with bossa again.
                ref https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_To_update_via_USB_using_a_Windows_host for instructions on using the erase jumper if you haven't tried that already.
                the bootloader in the cpu is in read only memory so you can't really break the bootloader (flashing diag led indicate running firmware normally, so it will not show up in bossa)
                  If you've flashed it once already then try and connect to it via YAT terminal software to see if it will respond to commands. If so, then try getting it running in standalone mode before adding the Pi into the mix.
                  https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
                  You'll need a fresh SD card that you can put the folder structure on and a config.g in the /sys folder. The DWC files in the /www folder etc. Put that in the Duet and try and boot it. It should get an IP address from your router you can connect to.
                  • bamundefined
                    bam
                    getting YAT online now
                    m122 b1
                    Error: M122: Response timeout: CAN addr 1, req type 6024, RID=0<LF>Error: M122: Response timeout: CAN addr 1, req type 6024, RID=1<LF>Error: M122: Response timeout: CAN addr 1, req type 6024, RID=2<LF>ok<LF>
                    m115
                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-12-24<LF>ok<LF>
                      That's a good sign. Now if you get an SD card in the Duet you should be able to get to the web interface.
                      • bamundefined
                        bam
                        So ive gotten the mainboard on 3.3.1, the panel due on 1.24 and the pi now talks to the mainboard. {paneldue just says connecting}. may have to send a paneldue interface code or something, not sure yet. right now im trying to figure out how to get the 3hc on the right firmware
                          PanelDue needs M575 P1 B57600 S1 in config.g
                          • bamundefined
                            bam
                            awesome! last thing and then i can start wiring, how do i find out what the address is for the 3hc?
                            • bamundefined
                              bam
                              or what firmware is on it? doesnt seem to have an sd card slot or micro usb. im using regular old phone cord to connect it to the 6hc
                                https://duet3d.dozuki.com/Wiki/CAN_connection
                                Once you set an address you can use M122 B# to get info for it
                                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M122_Diagnose
                                bamundefined 1 Reply Last reply Reply Quote 0
                                • bamundefined
                                  bam
                                  this is what i got when i ran m997 b1
                                  12/31/2020, 10:26:56 PM m997 b1
                                  Error: M997: Response timeout: CAN addr 1, req type 6024, RID=0
                                  12/31/2020, 10:26:56 PM Connection to Duet established
                                  12/31/2020, 10:26:55 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                                  • bamundefined
                                    bam @Phaedrux
                                    This post is deleted!
