    Stop Firmware Retract and Pressure Advance from Fighting
    Firmware wishlist
    862
    • oliofundefined
      oliof
      Pressure Advance modifies extruder behavior on every segmented move. Firmware retract modifies extruder behavior on some moves. When both do this on the same move, the extruder tries to tie itself into a knot trying to comply with the wishes of both retraction and pressure advance.
      Would it be possible to collapse the effects of Firmware Retract and Pressure Advance to avoid this fighting?
      • gloomyandyundefined
        gloomyandy
        I'm a little confused. Isn't firmware retract only triggered by G10/G11 as generated by the slicer? It may be worth posting an example of the gcode that causes the problem you are seeing and a description/video of what happens.
        oliofundefined 1 Reply Last reply Reply Quote 1
        • dragonnundefined
          dragonn
          I use both of them and don't see a problem.
          • oliofundefined
            oliof @gloomyandy
            @gloomyandy It does not matter that it's only triggered by G10/G11, it always coincides with DA action.
            I will try to post a video when I have the time to go back and investigate this. Currently I solved the problem by disabling PA again.
            @dragonn that's great for you.
            • dragonnundefined
              dragonn
              Based what are you say, that how it should work.
              PA is for compensating pressure build up in the hotend in different speeds.
              When PA would not do its move on retraction you would need different retraction length on different printing speeds. And I can confirm that effect exist on bowden and that is really important when having a full metal hotend where you can not just make the retraction longer at some point.
              I was having that issue that without PA when printing 3dbenchy the retraction worked perfectly fine up to the moment when the model cross-section goes small and the slicer slows down, then I would get clog up. With PA that is fine and I don't have to increase my retraction length so it clogs up because of full metal hotend.
              • oliofundefined
                oliof
                @dragonn I don't have issues with clogging or my all metal hotend's retraction settings. While what you write is an interesting observation, it does not add to my issue here.
                dragonnundefined 1 Reply Last reply Reply Quote -1
                • dragonnundefined
                  dragonn @oliof
                  @oliof said in Stop Firmware Retract and Pressure Advance from Fighting:
                  Ok but what exactly is the issue? Doing PA when doing retraction, what does it cause for you? Because like I describe in my opinion that by itself isn't an issue and shouldn't cause any problems.
                  • oliofundefined
                    oliof
                    I already said I will provide a more detailed explanation when I have the time. Please stop pestering me about it now.
                      Pressure advance is not applied to extruder-only moves, including both firmware and slicer-commanded retractions/reprimes.
                      botundefined oliofundefined 2 Replies Last reply Reply Quote 1
                      • botundefined
                        bot @dc42
                        @dc42 said in Stop Firmware Retract and Pressure Advance from Fighting:
                        Perhaps the use of "wipe while retract" could cause the behaviour being described by the OP? It will retract some amount of the retract distance while backtracking along the X/Y path for some distance. Then, it will retract the remaining retraction amount (if any) in a normal retraction move.
                        Disabling this slicer feature might provide the more intended firmware/PA behaviour.
                        *not actually a robot
                        dragonnundefined 1 Reply Last reply Reply Quote 0
                        • dragonnundefined
                          dragonn @bot
                          @bot can you even use wipe while retract when doing firmware retract? I think not
                          botundefined 1 Reply Last reply Reply Quote 0
                          • botundefined
                            bot @dragonn
                            @dragonn nice catch, I missed that part somehow.
                            • oliofundefined
                              oliof @dc42
                              @dc42 what's with firmware retract with z hop? Either way, they seem to be applied directly after another which seems to lead to very noisy extruder back-and-forth.
                                dc42 administrators @oliof
                                When G10 is executed, retraction happens first, then Z hop. G11 undoes the Z hop, then undoes the retraction.
