    DWC endstop status missing...
    Duet Web Control
    621
    • Chrissundefined
      Chriss
      Hi *,
      I can remember that the DWC displayed the endstop status in older releases. And the docu tells me the same. https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Testing_endstop_switches_using_the_web_interface
      I can not find that at my new mini 5+ any more:
      Board: Duet 3 Mini 5+ (Mini5plus)
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.2-beta3.2+1 (2020-11-15)
      Duet WiFi Server Version: 1.25beta0
      Does the docu do not match the software any more? Or is the feature in the DWC removed my accident?
      Cheers, Chriss
      • PCRundefined
        PCR
        @chrishamm was removed in dwc 3.2
        type M119 to see it
        jay_s_ukundefined Chrissundefined 2 Replies Last reply Reply Quote 0
          jay_s_uk @PCR
          @Chriss
          I raised it here https://forum.duet3d.com/topic/18839/dwc-beta-3-2-1-endstop-status
          The summary was use the object model.
          • Chrissundefined
            Chriss @PCR
            @PCR said in DWC endstop status missing...:
            I'm very sorry that @chrishamm was removed. 🙂
            Well, my conclusion is now that the feature has passed away and the documentation is outdated.
            Cheers, Chriss
            • Vetiundefined
              Veti
              you should update to rc2. there were some bugs in the early beta releases.
              Chrissundefined 1 Reply Last reply Reply Quote 0
              • Chrissundefined
                Chriss @Veti
                @Veti I upgraded... the endstop info is still missing in the DWC. 😉
                Vetiundefined 1 Reply Last reply Reply Quote 0
                • Vetiundefined
                  Veti @Chriss
                  @Chriss yes this was a just a note on the firmware version you were running. not related to the endstop status
                  • Chrissundefined
                    Chriss @Veti
                    @Veti
                    I know... and you were right.... the stock firmware needed a update anyway. 😉
                    It is clear that I can get the info from M119, it was just a bit confusing that a very handy feature has gone away.
                    • JuJuDeltaundefined
                      JuJuDelta
                      I would like to see endstop status returned to DWC.
                      I have multiple steppers on a common rail moving in a co-ordinated fashion in convoy, nose to tail. Magnet & reed-switch on each end.
                      So a table of ALL endstops status was a great aid to debugging.
                      Thanks.
                      T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
