    Once again Z min endstop, BLtouch G29 and G32 correct using
    • buttonundefined
      button
      Hi!
      In my printer I have Zmin endstop (I want to keep it, but will write about that later) and BLtouch.
      I would like to know how should looks correct procedure for making bed mesh compensation and true bed leveling.
      How I'm doing that (every time I remove glass and put it back again):
      I'm heating the bed.
      Sending G32 command to adjuts 4 Z motors. My bed.g looks like that:
      G1 Z5 F1500
      G1 X152 Y185 F6000
      G30
      G30 P0 X1 Y5 Z-99999
      G30 P1 X1 Y280 Z-99999
      G30 P2 X304 Y280 Z-99999
      G30 P3 X304 Y5 Z-99999 S4
      G1 X0 Y-10 Z5 F6000
      after that i have macro for G30 before G29 (would be great to have macro that is running when starting G29 - eg. heat nozzle, do G30 etc):
      G29 S2
      G1 Z5 F1500
      G1 X152 Y185 F6000
      G30
      G1 Z5 F1500
      G1 X0 Y-4 F6000
      now I'm doing G29 and after that i have everything done.
      When I'm starting print my start g-code looks like that:
      G10 P0 S0 R0 ; set extruder temperature to 0
      M140 S[first_layer_bed_temperature] ; heat bed
      G28 ; home all axes
      M190 S[first_layer_bed_temperature] ; wait for bed temp
      G29 S2 ; clear bed compensation
      G10 P0 S150 ; nagrzej dysze do 150
      G32 ; Bed leveling
      G29 S1 ; load leveling map
      Is this procedure correct in your opinion?
      I want to keep Zmin endstop because:
      printhead is outside bed area
      in my other 2 printers with Marlin firmware it works great (Zendstop and BLtouch)
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
        Yes you can have endstop and probe both defined. The endstop is used with a G1 H1 Z movement to trigger the endstop. The probe is used with G29 and G30. Just be aware that you should be setting your Z0 position with the probe before and after the auto leveling and the same for the mesh creation or loading and before the print.
        You haven't posted your homeall so I can't say if there are any issues with what you have, but there could be.
        In your bed.g I would add another G30 at the end to re-establish the z0 position after the tilt correction has been done since it may have changed.
        Like so:
        G1 Z5 F1500
        G1 X152 Y185 F6000
        G30
        G1 X152 Y185 F6000
        G30
        G1 X0 Y-10 Z5 F6000
        If you did that, based on your current sequence of gcodes you should not have any issues.
        buttonundefined 1 Reply Last reply Reply Quote 1
        • buttonundefined
          button @Phaedrux
          @Phaedrux
          G91                   ; relative positioning
          G1 H2 Z5 F2400        ; lift Z relative to current position
          G1 H1 X-304 Y320 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y-5 F6000   ; go back a few mm
          G1 H1 X-304 Y320 F300  ; move slowly to X and Y axis endstops once more (second pass)
          G1 H2 Y-320 F4800
          G1 H1 Z-300 F600      ; move Z down stopping at the endstop
          G1 H2 Z3 F2400
          G1 H1 Z-300 F180
          G90                   ; absolute positioning
          G1 Z5 F1200				; lift Z
          This is my homeall.g
          Thank you for sugestion with another G30 at end of G32
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @button
            @button said in Once again Z min endstop, BLtouch G29 and G32 correct using:
            because the G32 adjust the tilt. therefore the Homing point height might change.
            • Stephen6309undefined
              Stephen6309 @button
              @button Where you have you G29 S1, you could change to this:
              G29 S1
              if result > 1
              G29 S0
              As long as heightmap.csv exists, it will always load the height map. When heightmap.csv is deleted, you get a new one made.
              buttonundefined 1 Reply Last reply Reply Quote 0
              • buttonundefined
                button @Stephen6309
                Before today playing with printer reading from G32 were:
                I'm finalizing screwing and tensioning everything back and I'll post what readings I have now.
                2 gantrys where completely not tensioned...
                EDIT
                After mechanical corrections:
                How should it looks? Is this reading is ok?
                BTW:
                What's doing F parameter in M671 command?
                  Phaedrux Moderator @button
                  https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
                  It's a fudge factor. So if it's always a little over or under on it't correction on the first pass you can adjust the F parameter to make it have more or less effect.
                  The readings don't mean a lot to me looking at them. The real question is whether it's having the right effect on your bed tilt.
