    Smarteffector problems with 3.11 ( update from 2.04)
    1.3k
    • fragleundefined
      fragle
      I will try the suggestions today, but i do not thing, that it is an hardware problem, because the system is running on fw 2.04 without any problems.
      • fragleundefined
        fragle
        small update
        if i use G32, than i am getting
        Calibrated 8 factors using 16 points, (mean, deviation) before (-0.004, 0.067) after (-0.000, 0.053)
        Repeating calibration because deviation is too high (0.053mm)
        too many auto calibration attempts
          jay_s_uk @fragle
          @fragle so change the S value to 0.06 (or even slightly higher)
          Currently, any value above 0.05 (originally 0.02) will cause it to fail.
          Its due to the sloppy eyes they use on the rods on the predator.
          • fragleundefined
            fragle
            G32 is now successful after the second run
            I have set the sensitivtiy to 10 for the smart effector, but i am wondering, why the display of the Z probe switches to "1000" around every third contact to the print plate.
            The other 2 hits, there was no "1000" release on the display ( even tough the nozzle hits the plate and withdraw correct.
              jay_s_uk @fragle
              @fragle DWC generally doesn't catch up enough to fully display every probe. If it works, don't worth about it.
              • fragleundefined
                fragle
                I have crosschecked the predator with my old 2.04 settings, everything is working fine.
                Back to 3.1.1
                Now i can run G32 and G29 without error.
                I i try to print something i use as start script
                G28
                G32
                During the G32 from the gcode i am getting always an
                Error: Z Probe already triggered at atrt of probing mode
                I have reset the sensififity to 131:131 ( default setting)
                i ve tried some configs starting from here https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe to some hints in the forum, but nothing worked.
                  dc42 administrators @fragle
                  @fragle said in Smarteffector problems with 3.11 ( update from 2.04):
                  There are a few possible reasons for this:
                  1. The Smart Effector is triggering when it shouldn't. If this is happening, you will see the green LED on the effector flashing. But if you are sure that it works under RRF 2.05.1, that can't be the problem.
                  2. Vibration or deceleration after the positioning move is causing the effector to trigger. If it's vibration, reducing the sensitivity will help. If it's deceleration after the positioning move, increase the M558 R parameter.
                  3. The effector output wire is picking up interference from an adjacent stepper motor wire. If that is the cause, and you are using probe type 5 in M558, increasing the G50 P parameter may help.
                  Are you using exactly the same parameter values (except for the ones where the command format has changed) in 3.1.1 as in 2.04, in your M558, M201, M203, M566, M906 and M569 commands in config.g?
                  • fragleundefined
                    fragle
                    small update:
                    I ve upgraded to firmware 3.2 an now i can print, but i have to adjust the Printhead at printing with 0,2mm babysteps.
                    If i try to calibrate the Z Probe as described here https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe i am getting -0,01 . Nothing change if i will change the z value to 0,2
                      Phaedrux Moderator @fragle
                      i am getting -0,01
                      It should be slightly negative because it's pressing into the bed. Why do you want to use 0.2?
                      • fragleundefined
                        fragle
                        if i use -0.01my print noozle is to close to the print bed, it is so close, that it would scratch the surface
                        Carloundefined 1 Reply Last reply Reply Quote 0
                        • Carloundefined
                          Carlo @fragle
                          @fragle
                          If you G1 Z0.1 does it hit the bed before you calibrate G32?
                          You need to set your height currently H430.00 can't be correct also take out ;M501
                          don't want config_override at this point as it isn't helping.
                          Heat the bed to 60c nozzle 130c then home G28
                          don't calibrate just lower the nozzle to a piece of paper on the bed or .1 feeler gauge
                          that's your height minus off what's above zero/0.1 from M665 H parameter then reboot and G1 Z0.1 should be 0.1 above the bed then set your probe trigger height to -0.1 reboot and calibrate
