    Extruder issues with 3.2-beta 3.2 - Duet 3 MB6HC
    1.5k
    • MikeGeppertundefined
      MikeGeppert @Phaedrux
      @Phaedrux Great Thanks!
      Same issue. "U" works, "E" not so much...
      Mike Geppert
        Hmm.. no, there should be a few messages if everything is good and some errors if it's not. I think something is amiss with your config.
        Can you try a basic config generated by the config tool?
        MikeGeppertundefined 2 Replies Last reply Reply Quote 0
          @Phaedrux Sure - give me like 30 min or so.
          Mike Geppert
            MikeGeppert @MikeGeppert
            @MikeGeppert said in Extruder issues with 3.2-beta 3.2 - Duet 3 MB6HC:
            @Phaedrux said in Extruder issues with 3.2-beta 3.2 - Duet 3 MB6HC:
            M98 P"config.g"
            1/5/2021, 10:44:40 PM M98 P"config.g"
            Kind of unexciting? Its got a green background I think that is a good thing?
            The lights blink like I expect when I run the command. What should give an output?
            Mike Geppert
              If everything executes cleanly you should get something like
              M98 PCONFIG.G
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 893C.
              Well, actually, looking at your config it looks like you may not have any of the network commands and your heaters may not be overpowered.
              MikeGeppertundefined 1 Reply Last reply Reply Quote 0
                And for good measure can you post the results of M122 as well when configured as E?
                We could also start sending the basic axis setup commands by themselves to see what the firmware thinks is configured and see if it meets expectation.
                M201, M203, M566, M584, etc etc
                But I think we may get good results from a clean config.
                  Ok so a generated Config file seems to work.
                  Hmmm - I will start modifying it slowly to see what broke it.
                  Mike Geppert
                    M98 PCONFIG.G
                    FTP is disabled
                    TELNET is disabled
                    With the generated config file it also does not print anything to the console.
                    Mike Geppert
                      1/5/2021, 11:17:48 PM M122
                      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                      Board ID: 08DJM-956BA-NA3TJ-6JKDJ-3S86P-1T9LT
                      Used output buffers: 1 of 40 (10 max)
                      Static ram: 149788
                      Dynamic ram: 62828 of which 36 recycled
                      Never used RAM 146180, free system stack 192 words
                      Tasks: Linux(ready,102) HEAT(blocked,297) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1179) IDLE(ready,19)
                      Owned mutexes: HTTP(MAIN)
                      Last reset 00:00:49 ago, cause: software
                      Last software reset at 2021-01-05 23:16, reason: User, none spinning, available RAM 146252, slot 2
                      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      Aux1 errors 0,0,0
                      MCU temperature: min 33.9, current 34.3, max 34.4
                      Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                      Driver 0: position 0, standstill, reads 13340, writes 20 timeouts 0, SG min/max 0/0
                      Driver 1: position 0, standstill, reads 13341, writes 20 timeouts 0, SG min/max 0/0
                      Driver 2: position 0, standstill, reads 13341, writes 20 timeouts 0, SG min/max 0/0
                      Driver 3: position 0, standstill, reads 13342, writes 19 timeouts 0, SG min/max 0/0
                      Driver 4: position 0, standstill, reads 13341, writes 20 timeouts 0, SG min/max 0/41
                      Driver 5: position 0, standstill, reads 13350, writes 11 timeouts 0, SG min/max 0/0
                      Date/time: 2021-01-05 23:17:48
                      Slowest loop: 0.44ms; fastest: 0.05ms
                      === Storage ===
                      Free file entries: 10
                      DMs created 125, maxWait 18449ms, bed compensation in use: none, comp offset 0.000
                      === MainDDARing ===
                      Scheduled moves 1, completed moves 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                      === AuxDDARing ===
                      Heater 1 is on, I-accum = 0.0
                      Segments left: 0
                      Movement lock held by null
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Aux2 is idle in state(s) 0
                      Code queue is empty.
                      === CAN ===
                      Messages queued 188, send timeouts 433, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
                      === SBC interface ===
                      State: 4, failed transfers: 0
                      Last transfer: 1ms ago
                      RX/TX seq numbers: 1696/1696
                      SPI underruns 0, overruns 0
                      Number of disconnects: 0, IAP RAM available 0x2c8a8
                      Buffer RX/TX: 0/0-0
                      === Duet Control Server ===
                      Duet Control Server v3.2.0
                      Code buffer space: 4096
                      Configured SPI speed: 8000000 Hz
                      Full transfers per second: 35.40
                      Maximum length of RX/TX data transfers: 4788/860
                      Mike Geppert
                        Phaedrux Moderator @MikeGeppert
                        That may be normal. In SBC mode there aren't any network commands present to echo back, and your heaters may not be over powered so no warning.
                        Can you post the generated config?
                          M906 X{20000.8} M906 Y{20000.8} M906 Z{20000.8} ;M906 E{10000.9} M906 U{1000*0.9}
                          If you're trying to get percentages with this, just use M913 instead. I set my current to the rated max with M906 and then use M913 to set it to a percentage of that.
                          MikeGeppertundefined 3 Replies Last reply Reply Quote 0
                            I found the culprit:
                            M906 E900 ; Works
                            and
                            M906 E{1000*0.9} ; Gives the issue.
                            Interesting that these seem to work:
                            M906 X{20000.8}
                            M906 Y{2000
                            0.8}
                            M906 Z{2000*0.8}
                            Mike Geppert
                              One more note:
                              M906 U{1000*0.9} ; Works
                              Mike Geppert
                                MikeGeppert
                                Thanks so much for the help!
                                The original Config file now works with the one change:
                                M906 X{20000.8}
                                M906 Y{2000
                                0.8}
                                M906 Z{20000.8}
                                ; M906 E{1000
                                0.9} ; This seems to not work
                                M906 E900
                                ;M906 U{1000*0.9}
                                Mike Geppert
                                  My homing macros try and set stealthchop and sensorless homing. To do that I have to cut the current to 30% using the M913 command. So if I cut to 80% at first in the config file, do I then cut to 80% * 30%? Then set back to 80% when done?
                                  Mike Geppert
                                    This is exactly why I leave M906 as the full rated current and then adjust with M913. That way I know that M913 80 is 80% of rated. And 30% is 30% of rated. It's just more direct. No percentage of a percentage.
                                      Mathematically I want the 80%*30%. My intention was that once Variables get implemented I would make a MAX_MOTOR_LDO that has the 2000mA value. And another variable that would have the percentage MAX_RUN_PERCENT to be like 80%. Then set the M906 to the multiplication of the two. Then I can use percentages of that MAX_RUN_VALUE.
                                      Mike Geppert
                                        Seems needless when M913 already exists, but it would work either way.
