    leveling 3 independent Z motors and with 4 finger srews ?
    389
    • joekoundefined
      joeko
      hallo,
      i use an corexy printer with 3 independed motor for automatic bed leveling. the bed is on a frame with 4 srews at the corner. is it possible to level the 4 finger srews to level the bed on the frame and the frame with bed level with the 3 motors ?
        Yes, you could. Though I think you'd eventually be fighting against yourself.
        For the 3 lead screw leveling you could follow this: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#main
        And for the manual adjustment of the bed screws you can use the manual bed leveling assistant: https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
        joekoundefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt
          My current printer project has gone through many iterations.
          The bed of 6mm tool plate is mounted in a frame of 20x20 extrusion and has 3 thumbscrews that were used early on to do manual bed leveling.
          In a recent iteration I installed three Z steppers to enable auto bed leveling.
          I chose to leave the bed assembly as it was complete with thumbscrews. I used a mm scale to adjust them to get the bed plate "level" with the bed frame as best I could.
          I now rely on the auto bed level feature.
          • joekoundefined
            joeko @Phaedrux
            @Phaedrux said in leveling 3 independent Z motors and with 4 finger srews ?:
            my setup with the 3 independet z motors works well. my bed is 300x300 mm with thumbscrews at every corner. in the config i have M671 for leadsrews position. when i now want the manual bed assistant at the same time i have to set the position for the thumbscrews but in the M671 i wrote the position from the leadsrews. is both at the same time / settings not possible ?
              You are correct you can't configure for both at the same time, but you can configure it for one, and then reconfigure it right before you use it with the other. Create a macro with the settings you want for each.
              • joekoundefined
                joeko
                ah, ok that is possible.
                am i right when i set the M671 settings for thumbscrews in the macro and the makro change the config file ?
                if so than i change the config and restart the duet ?
                  No. Config.g is just a macro file itself. The only difference is that it gets run at startup.
                  If you change M671 in a macro, it will stay active until the printer is rebooted and then executes config.g again, or you change it yourself with another M671 command.
                  You could use bed.g for this which gets called by G32.
                  At the start you could home the printer, pre heat if you want, then set the M671 for the lead screws and do that adjustment, and then change to the M671 for the thumb screws and do that part.
                  But, I say again, when you do both ways of leveling, you're going to be undoing the first pass. The lead screws will be tilting the plane of the bed, and then using the thumbscrews will be doing it again, but differently and possibly changing what you did with the lead screws.
                  I would fix the bed thumb screws in place and let the 3 lead screw leveling with the probe do the work.
                  joekoundefined 1 Reply Last reply Reply Quote 1
                    jay_s_uk
                    This is what I run as a manual macro for levelling the bed using 4 screws.
                    m671 x15:250:15:250 y25:25:260:260 P0.5
                    G30 P0 X15 Y25 Z-99999 ; probe near an adjusting screw
                    G30 P1 X240 Y25 Z-99999 ; probe near an adjusting screw
                    G30 P2 X15 Y255 Z-99999 ; probe near an adjusting screw
                    G30 P3 X240 Y255 Z-99999 S4 ; probe near an adjusting screw
                    G28 Z
                    Works well.
                    I would suggest you copy your current M671 and put it in your bed.g file at the beginning.
                    • joekoundefined
                      joeko @Phaedrux
                      yes you are right of course. later after level the bed on the frame with the 4 srews i will only use the 3 z motors. now i am only looking for a way to setup the printer
                      • joekoundefined
                        joeko @jay_s_uk
                        @jay_s_uk said in leveling 3 independent Z motors and with 4 finger srews ?:
                        G28 Z
                        Works well.
                        ah, ok.
                        this is your macro and you call it for leveling.
                        on this way i can create a 2. macro and use motors or finger srews....
