    3.2 JSON Parse error: Unrecognized token '<' Password bug
    Beta Firmware
    8
    58
    3.7k
    • xenon2008undefined
      xenon2008
      hmmm thats an idea, i really had an password in my DWC!
      i will try this as soon as i'm at home at the printer!
      Thanks alot!
        xenon2008
        Good Evening,
        sorry for the late Reply, but i must work every Day so long..
        i now have commented out the Passwort in den config.g and rebooted my Duet 2 Wifi.
        Currently i run a testprint, and have a look, but until yet it looks good. I hope it stays that way!
        But if so, what i or we can do, so that i can use a Password Protection without any Errors?
          Did your password contain any special characters? Can you test a simple password?
          xenon2008undefined 1 Reply Last reply Reply Quote 0
            xenon2008 @Phaedrux
            @Phaedrux
            No it is only a lowercase Word, nothing special
              xenon2008
              Good Morning!
              Since i have uncommented the Password Line in the config.g it seems to work?
              How can i report this as a Bug?
                @xenon2008 Consider it reported. Thanks.
                @chrishamm will be glad you were able to replicate it.
                • chrishammundefined
                  chrishamm administrators
                  I'm sorry but I'm having trouble reproducing this issue. It's all working as expected on Windows (Firefox), Linux (Chromium), and OS X (Safari). Can you confirm that you are using RRF 3.2 and DuetWiFiServer 1.25?
                  Duet software engineer
                    xenon2008 @chrishamm
                    @chrishamm
                    Yes i can Confirm:
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-01-05
                    Tested with Google Chrome in Windows 10 x64 & on a Android Phone.
                    • fcwiltundefined
                      fcwilt
                      I'm running 3.2 on a Duet 3 Mini 5
                      I didn't have M551 so I added it and rebooted.
                      DWC came up, asked for PW, entered PW - no issues.
                      I removed M551 and rebooted.
                      DWC came up - no issues.
                      Using most recent Chrome.
                        @xenon2008 can you provide the actual config.g that provokes the error? Maybe there's a special character or something in there.
                          xenon2008
                          Sure, should i PM this?
                            if you're concerned about sharing the password, sure. You can zip it up and email it to jason@duet3d.com
                              xenon2008
                              Hi, i am again!
                              Is it possible that its a PrusaSlicer issue?
                              I send the GCODE direct from PrusaSlicer to the Duet, and then i get this error if i click on "Jobs".
                              I also tried to give a simple Name like Test.gcode to Upload to the DWC, with no other caracters...
                                xenon2008
                                Hi i am again,
                                It really looks like the Error comes from PrusaSlicer....
                                I have now updated to the latest Version from PrusaSlicer (2.3.0) but it is the same.
                                If i upload the Gcode direct from the Slicer i get the Error on the Webinterface.
                                BUT if i see this right, i get this error only then when the Passwort for the DWC is active, without i get no error until yet.
                                So we have now to find out, if this is a PrusaSlicer or a DWC behavior.
                                Each time i upload a Gcode, also i have a dissconnect and a reconnect on the DWC, but without a Passwort dialog, even when the Password protection is enabled:
                                Hope this helps a little bit.
                                Kind Regards from Austria
                                EDIT:
                                maybe this also would be helpful:
                                https://forum.duet3d.com/topic/20992/prusaslicer-dwc-disconnect-on-upload-test/6
                                  xenon2008
                                  Hello together!
                                  Is there any Update?
                                  I made also a Thread on Github on the PrusaSlicer Page.
                                  Link to the Thread:
                                  https://github.com/prusa3d/PrusaSlicer/issues/5877
                                  Kind Regards
                                  xenon2008 created this issue in prusa3d/PrusaSlicer
                                  open JSON Error when Uploading Gcode to Duet 2 Wifi #5877
                                    I have just tested this. I find that if I upload from PrusaSlicer 2.3.0 and I have DWC open to the printer on the same PC, It reports "JSON.parse: unexpected character at line 1 column 1 of the JSON data", disconnects briefly, and reconnects immediately.
                                    I will look into the reason for the disconnection.
                                      This is fixed in DWC 3.2.1RC2.
                                        xenon2008 @dc42
                                        @dc42 thank you!
