SOLVED Upgradet to RRF3 with some trouble
I‘m building a new printer.... xyz homing is working so I tried true bed leveling... I tried with 3 and 4 points... but everytime I got this error:
„warning: 3/4-point-bed compensation is deprecated and will be removed in a future firmware release. Please use G29 mesh bed compensation instead“
I was confused because it worked fine in my old printer with the same configuration...
So i tried to update to 3.2...
I get the same error and additional to that after the 4. point the printhead moves in the middle of bed for homing bed... during homing duet loose connection and nozzle crashes into bed
Anyone an idea?
Board is Duet 3 6HC + RP4
Printer: HevORT; bed.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 26 2020 16:14:58 GMT+0200 (Mitteleuropäische Sommerzeit)
G92 S2 ; clear bed high mapG28 ; home
M913 Z50 ; drop motor currents to 50%G30 P0 X60 Y40 Z-99999 ; probe near a leadscrew
G30 P1 X60 Y370 Z-99999 ; probe near a leadscrew
G30 P2 X365 Y370 Z-99999 ; probe near a leadscrew
G30 P3 X365 Y40 Z-99999 S4 ; probe near a leadscrew and calibrate 3 motors
M913 Z100 ; motor currents back to 100%
G28ZM915 X Y Z R1 F0 S8 ; Disable stall for prevent false detect
Config
; executed by the firmware on start-up; General preferences
M550 P"RatRig VCORE Pro" ; set printer name
; M551 P"RatRig" ; PasswortschutzM667 S1 ; select CoreXY mode
M669 K1 ;switch to CoreXY mode; Drives
M569 P0.0 S1 ; physical drive 0.0 goes backwards
M569 P0.1 S1 ; physical drive 0.1 goes backwards
M569 P0.2 S1 ; physical drive 0.2 goes backwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwardsM584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E831.29 ; set steps per mm; Slow
M566 X400.00 Y400.00 Z100.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) JERK
M201 X1500.00 Y1500.00 Z180.00 E10000.00 ; set accelerations (mm/s^2)M203 X2400.00 Y2400.00 Z500.00 E3000.00 ; set maximum speeds (mm/min)
M906 X1500 Y1500 Z1500 E1000 I15 ; set motor currents (mA) and motor idle factor in percent
M208 X415 Y415 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure sensorless endstop for low end on X
M574 Y1 S1 P"io1.in" ; configure sensorless endstop for low end on Y
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z leadscrew positions
M671 x-8.298:217.911:444.12 Y2.021:430,231:2,021 S50; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"io7.in" H5 F180 T3000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 x37.449 Y26.253 Z1.15 ; set Z probe trigger value, offset and trigger height wenn +wert, dann von z abziehen
M557 X40:360 Y40:360 S80 ; define mesh grid; Heaters
;M308 S0 P"temp1" Y"thermistor" A"Heizbett" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
;M950 H0 C"out1" T0 ; create bed heater output on out0 and map it to sensor 0
;M143 H0 S110 ; set temperature limit for heater 0 to 120C
;M307 H0 A255.6 C558.3 D1.8 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit and PID settings
;M140 H0 ; map heated bed to heater 0;M308 S1 P"temp0" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
;M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
;M143 H1 S265 ; set temperature limit for heater 1 to 245C
;M307 H1 A384.5 C364.6 D3.3 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit and PID settings; Fan Hotend
;M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Fan Bauteilkühlung
;M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
;M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off; Tools
M563 P0 S"Hotend" D0 H1 ; define tool 0
;M572 D0 S0.08 ; Pressure Advance Factor
;M593 F42.19 ; Dynamic Advance FrequenzT0
; Custom settings are not defined; Miscellaneous
@ErwinH78 said in Upgradet to RRF3 with some trouble:
That should be G29 S2
G28Z
Missing space.
Are you trying to do independen lead screw leveling?
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
Can you verify you're in 3.2 with M115?
Can you post the results of M98 P"config.g"?
hi... first of all thx for your time....
--- ok i change
G28Z
Missing space.
OK. changed
yes during that the error occurs.
Yes it is
10.1.2021, 08:16:01 M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-01-05Can you post the results of M98 P"config.g"?
here it is
10.1.2021, 08:17:07 M98 P"config.g"
Specify 1, 2, 3 or 4 X and Y coordinates in M671 -
so i found an another misstake in the config.
in M671 there was also a , intead of .
so i tried it 5 times no. no error. seams it´s all fine now....
thanks for your quick support -
Yes that would do it. Glad you figured it out.
