    Duet 3 mini 5+ need help with wiring and config
    Firmware installation
    1082
    • Alucardi
      Alucardi last edited by
      I am trying to set up my card but i have no clue on how to wire in my bl touch. Also i have no clue how to set it up in the configurator. Do i need to setup "input Pin", "Modulation pin" and "PWM Control Channel (bl touch only)"?
      Also having issues figuring out how to setup 2 z motors using the config. I cannot assign a Endstop pin to E0 which is my 2nd z motor.
      When it comes to the fans do i need to connect the ground?
      I am adding my config if anyone wants to take a look.
      config.json
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+3+Mini+5++Guide+Part+1:+Wiring/87?lang=en
        Here's a wiring guide that includes a section on BLtouch.
        The config portion is coming soon, but here's the relevant portion of config for the BLTouch.
        M950 S0 C"io3.out" ; create servo pin 0 for BLTouch
        M558 P9 C"^io3.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        You cannot setup dual z motors in the config tool, you mave to do it manually by editing the config,g and modifying the M584 command to map both drivers to your Z axis.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
        To add a second endstop for the zaxis you'll also have to modify the M574 command in config.g to include both endstop pins.
        There's an example here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
        I'm not sure I understand you fan question, but hopefully the wiring guide will clear up the fan wiring. But if it's a 2 wire fan you have + and - no ground.
        Example config for an Ender3
        ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
        ; generated by RepRapFirmware Configuration Tool v3.2.0 on Wed Jan 06 2021 00:34:52 GMT-0600 (Central Standard Time)
        M550 P"E3D3M5+"                                    ; set printer name
        M918 P1 E4 F2000000                                ; configure direct-connect display
        M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
        M569 P0.0 S0                                       ; physical drive 0.0 goes backwards
        M569 P0.1 S0                                       ; physical drive 0.1 goes backwards
        M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
        M569 P0.3 S0                                       ; physical drive 0.3 goes backwards
        M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
        M92 X80.00 Y80.00 Z1600.00 E93.00                  ; set steps per mm
        M566 X900.00 Y900.00 Z60.00 E300.00                ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z600.00 E3600.00            ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z200.00 E2500.00              ; set accelerations (mm/s^2)
        M906 X600 Y600 Z600 E900 I30                       ; set motor currents (mA) and motor idle factor in per cent
        M208 X235 Y235 Z260 S0                             ; set axis maxima
        M574 X1 S1 P"io5.in"                               ; configure active-high endstop for low end on X via pin io5.in
        M574 Y1 S1 P"io6.in"                               ; configure active-high endstop for low end on Y via pin io6.in
        M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
        G31 P500 X-44 Y-17 Z2                              ; set Z probe trigger value, offset and trigger height
        M557 X5:190 Y5:215 S10                             ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T98801 B4185        ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
        M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
        M308 S1 P"temp1" Y"thermistor" T98801 B4185        ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
        M143 H1 S240                                       ; set temperature limit for heater 1 to 240C
        M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
        M106 P0 C"PartCool" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
        M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
        M106 P1 C"HotEnd" S1 H1:0 T45                      ; set fan 1 name and value. Thermostatic control is turned on
        M950 F2 C"out5" Q500                               ; create fan 2 on pin out5 and set its frequency
        M106 P2 C"CaseFan" S1 H1:0 T45                     ; set fan 2 name and value. Thermostatic control is turned on
        M950 F3 C"out6" Q500                               ; create fan 3 on pin out6 and set its frequency
        M106 P3 C"LEDs" S1 H-1                             ; set fan 3 name and value. Thermostatic control is turned off
        M563 P0 S"HotEnd" D0 H1 F0                         ; define tool 0
        ; Custom settings
        M574 Z2 S1 P"io2.in"                               ; configure active-high endstop for high end on Z
        M204 P600 T2000						                              ; Set accelerations (mm/s^2) for print and travel moves
        M912 P0 S-13						                                 ; CPU temperature calibration
        M572 D0 S0.35						                                ; Pressure Advance
        M207 S6.5 R0.0 F4800 T4800 Z0.0 	                  ; Retraction
        M280 P0 S160					  	                               ; Clear any alarms
        M402								                                       ; retract pin just in case
        M575 P1 S1 B57600                                  ; enable support for PanelDue
        M501                                               ; load saved parameters from non-volatile memory
        M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
        T0                                                 ; select first tool
        Alucardi 1 Reply Last reply Reply Quote 1
        • Alucardi
          Is till don't get it. He is using just 1 connector but say that i need to connect to io3 and io1.
            Sorry for the confusion. The io1 has been corrected to io3.
            It should be io3.in and io3.out
            In takes the trigger signal and out controls the servo pin.
            Alucardi 1 Reply Last reply Reply Quote 0
            • Alucardi
              Alucardi @Phaedrux last edited by
              @Phaedrux Why cant i pick io3.in on drive z in config? i can only pick io1/io2 but i cant pick them for the bl touch.
                Can you show a screenshot of what you mean?
                • Alucardi
                  @Phaedrux nwm i figured it out. You set to sue bltouch further ahead in the config.
                    0cda00ea-3d80-4f88-bf81-fa734347214c-image.png Screen Shot 2021-01-05 at 11.40.08 PM.png
                    cd537727-7d20-4fd2-8f73-4aea1292d7b0-image.png Screen Shot 2021-01-06 at 12.02.24 AM.png
                    • Alucardi
                      @Phaedrux i got everything wired up and the pin extend and retract but it does not light blue and it does not report a value. What could be wrong?
                      • Veti
                        Veti last edited by
                        you will not see the bltouch value change, it triggers for a fraction of a second.
                        test it with g30 and triggering it by hand so you can power off if it does not stop.
                        • Alucardi
                          Alucardi @Veti last edited by
                          @Veti i tried and the value on the webui will just show 0. I have tried while homing to and it will not report a value, so bed will continue even if the pin is triggered by me. Pretty sure it should light blue when active also.
                          I used these steps tio manually test also
                          "To test the setup with the nozzle maybe a 100mm up from the bed you can check if the trigger signal is reaching the Duet by attempting to extend the pin by using the following command:
                          M280 P0 S10
                          If all is well the web interface should report a value of ”0” or "N/A" in the Z probe column when the pin is extended. You can then lightly touch the extended probe pin to check that the value in the Z probe Column changes to “1000”
                          You can retract the pin again with
                          M280 P0 S90"
                            How exactly do you have it wired? And what does the M558 M950 commands look like in your config.g? Does it match what I showed above?
                            Are you wired to IO3 like this?
                            • Alucardi
                              @Phaedrux it is just like in the picture, i made sure i have connection all the way to the probe using a multimeter so no broken wire.
                              i have not amde any changes to M950 or M558, It is just as the config did them.
                              M558 P9 C"^io3.in" H350 F350 T4800  B1                   ; set Z probe type to bltouch and the dive height + speeds + heater off while probing
                                Phaedrux Moderator @Alucardi last edited by
                                @Alucardi said in Duet 3 mini 5+ need help with wiring and config:
                                H350
                                Change that to H5. 350mm dive height is possibly problematic. But maybe not your problem here.
                                So just to recap. You're wired up to io_3 just like in the photo. Your config looks ok for io_3. And your deploy and retract macros look correct.
                                When you power on does the BLTouch do a self test?
                                Does sending M401 and M402 deploy and retract the pin?
                                Does sending G30 deploy the pin?
                                Does touching the pin after doing the G30 stop movement?
                                • Alucardi
                                  @Phaedrux
                                  When you power on does the BLTouch do a self test? Yes
                                  Does sending M401 and M402 deploy and retract the pin? Yes
                                  Does sending G30 deploy the pin? Yes it deploys during homing.
                                  Does touching the pin after doing the G30 stop movement? It reacts to me pushing it but wont stop bed going up.
                                    Then I suspect a bad connection on the white wire to io_3.in. That's the trigger signal wire. Retest continuity. Recrimp it. Make sure it's in the shell properly. Make sure it's on the right pin.
                                    As an additional check, please send M98 P"config.g" and report any errors. Also send M558 P9 and see if it reports back what you'd expect.
                                    Also post your homeall.g
                                    • Alucardi
                                      @Phaedrux said in Duet 3 mini 5+ need help with wiring and config:
                                      M558 P9
                                      Gives me error
                                      M558 P9
                                      Error: M558: Missing Z probe pin name(s)
                                      • Alucardi
                                        Homeall will be cleaned up and call for separate axels instead but i did it like this when i was trying to config sensorless homeing.
                                        M400							; finishes all current moves and and thus clears the buffer
                                        M913 X50 Y50 					; drop motor current to 33%
                                        M569 P0.0 D3 V60   		 		; reduce V to ensure stealthChop is enabled
                                        M569 P0.1 D3 V60   		 		; reduce V to ensure stealthChop is enabled
                                        M915 P0.0 S1 R0 F0 H400		; sensitivity X, don’t take action, don’t filter
                                        M915 P0.1 S1 R0 F0 H400		; sensitivity Y, don’t take action, don’t filter
                                        G91								; relative positioning
                                        G1 H1 Z10 F5000	    	   		; lift Z relative to current position
                                        G1 H1 X5
                                        G4 P300
                                        G1 H1 X20 F3000
                                        G1 H1 X-400 F3000		   		; move to X
                                        G1 H1 Y-5
                                        G4 P200
                                        G1 H1 Y-20 F3000
                                        G1 H1 Y400 F3000 				; move to Y
                                        M913 X100 Y100 					; return current to 100%
                                        G90                   	  		; absolute positioning
                                        G1 X167.5 Y167.5 F5000
                                        G30 	  			    		; home Z by probing the bed
                                        M402 							; retract probe
                                        G1 Z5 F5000
                                        M569 P0.0 D2  	    			; restore default for motor
                                        M569 P0.1 D2					; restore default for motor
                                          Ok how bout just M558
                                          • Alucardi
                                            @Phaedrux M558
                                            Error: M558: Z probe 0 not found
                                              Try again after a reboot, and post your entire config.g please.
                                              • Alucardi
                                                Alucardi @Phaedrux last edited by Alucardi
                                                @Phaedrux
                                                now it worked. M558 P9 still give same error though
                                                "m558
                                                Z Probe 0: type 9, input pin io3.in, output pin nil, dive height 350.0mm, probe speed 350mm/min, travel speed 4800mm/min, recovery time 0.00 sec, heaters suspended, max taps 1, max diff 0.03"
                                                M550 P"Hevo"                                             ; set printer name
                                                M669 K1                                                  ; select CoreXY mode
                                                M552 S1                                                  ; enable network
                                                M569 P0.0 S1 D2 	                        	         ; physical drive 0.0 goes forwards
                                                M569 P0.1 S1 D2                      		             ; physical drive 0.1 goes forwards
                                                M569 P0.2 S1 D2                                          ; physical drive 0.2 goes forwards
                                                M569 P0.3 S1 D2                                          ; physical drive 0.3 goes forwards
                                                M569 P0.4 S1 D2                                          ; physical drive 0.4 goes forwards
                                                M584 X0.0 Y0.1 Z0.2:0.3 E0.4                             ; set drive mapping
                                                M350 E16 I0	                                             ; configure microstepping without interpolation
                                                M350 X16 Y16 Z8 I1                                       ; configure microstepping with interpolation
                                                M92 X160.00 Y160.00 Z1600.00 E407.00                     ; set steps per mm
                                                M566 X380.00 Y380.00 Z20.00 E4000.00                     ; set maximum instantaneous speed changes (mm/min)
                                                M203 X12000.00 Y12000.00 Z500.00 E4000.00                ; set maximum speeds (mm/min)
                                                M201 X1200.00 Y1200.00 Z300.00 E5000.00                  ; set accelerations (mm/s^2)
                                                M906 X900 Y900 Z1200 E450 I30           	             ; set motor currents (mA) and motor idle factor in per cent
                                                M208 X0 Y0 Z-0.5 S1                                      ; set axis minima
                                                M208 X330 Y343 Z450 S0                                   ; set axis maxima
                                                M671 X-45:380 Y170:170 S1								 ; leadscrew positions
                                                M574 X1 S3                                               ; configure sensorless endstop for high end on X
                                                M574 Y2 S3                                               ; configure sensorless endstop for high end on Y
                                                G31 P500 X25 Y-20 Z0.85                                  ; set Z probe trigger value, offset and trigger height
                                                M557 X25:310 Y25:310 P6                                  ; define mesh grid + Probe points
                                                M308 S0 P"temp0" Y"thermistor" T100000 B4138             ; configure sensor 0 as thermistor on pin temp0
                                                M307 H0 B0 S0.70                                         ; disable bang-bang mode for the bed heater and set PWM limit
                                                M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1
                                                M143 H1 S350                                             ; set temperature limit for heater 1 to 350C
                                                M950 F0 C"out5" Q50                                      ; create fan 0 on pin out5 and set its frequency
                                                M106 P0 C"Hotend fan " S0 H1 T50                         ; set fan 0 name and value. Thermostatic control is turned on
                                                M950 F1 C"out6" Q1000                                    ; create fan 1 on pin out6 and set its frequency
                                                M106 P1 C"Blower" S0 H-1                                 ; set fan 1 name and value. Thermostatic control is turned off
                                                M563 P0 D0 H1 F0 										 ; define tool 0
                                                M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"       ; set voltage thresholds and actions to run on power loss
                                                  Forget the M558 P9
                                                  Please fix the dive height M558 H5
                                                  Other than that it's down to the white trigger signal wire on io_3.in
                                                  Alucardi 2 Replies Last reply Reply Quote 0
                                                  • Alucardi
                                                    @Phaedrux guess it decided to break it self then during me changing the card. I have continuity all the way to under the connector on the blTouch it self down to the end of the connector going into the card.
                                                    I will however before i order a new one make a short harness and try it on the bench.
                                                    • Alucardi
                                                      @Phaedrux it is working now. When i wired this up ages ago i connected ground further up so i only had to use one wire in the connector. I now reran one ground more. In the end i had 3 ground wires. that is why i had continuity on white.
                                                      Only reason i figured it out was cause i had the stick from the multimeter on the ground at the mother board and hit the white wire by mistake.
