    Rotary delta calibration not implemented?
    LPC
    436
    • Orang_
      Orang_ last edited by
      Hi, I have a Rotary delta. When I try to calibrate, the printer behaves strangely, goes down to measure and immediately jerks to the side. Maybe I should attach a video but I don't know how(
        You can attach a short MP4 video to a post, or you can upload a video to dropbox, or google drive, or youtube, or vimeo, or something like that.
        Can you please also give us some more information about your setup? What duet board, firmware version, include your config.g, homedelta.g, bed.g.
        Have you gone over your printer mechanics?
        Have you seen these?
        https://duet3d.dozuki.com/Wiki/Configuring_RepRapFirmware_for_a_Rotary_Delta
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        Orang_ 1 Reply Last reply Reply Quote 0
        • Orang_
          ; bed.g
          ; called to perform automatic delta calibration via G32
          ; generated by RepRapFirmware Configuration Tool v3.2.1 on Mon Jan 11 2021 22:12:55 GMT+0200 (Восточная Европа, стандартное время)
          G28
          G30 P0 X0.00 Y80.00 Z-99999 H33.385
          G30 P1 X69.28 Y-40.00 Z-99999 H33.385
          G30 P2 X-69.28 Y-40.00 Z-99999 H33.385
          G30 P3 X0.00 Y40.00 Z-99999 H33.385
          G30 P4 X34.64 Y-20.00 Z-99999 H33.385
          G30 P5 X-34.64 Y-20.00 Z-99999 H33.385
          G30 P6 X0 Y0 Z-99999 S6
          • Orang_
            Orang_ @Phaedrux last edited by
            G90                                            ; send absolute coordinates...
            M83                                            ; ...but relative extruder moves
            M550 P"Orang_"                                 ; set printer name
            ;M669 K10 Uxx    Lxx  Rrr    Aaa: bb Hxx
            M669 K10 U170 L319 R55.94 A-45:52 B135 H439.2 X-60,Y60,Z180
            M666 X-1.2 Y-0.7 Z1.4
            M569 P0 S1                                     ; physical drive 0 goes forwards using default driver timings |D3 stealthChop2
            M569 P1 S1                                     ; physical drive 1 goes forwards using default driver timings
            M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
            M569 P3 S0                                     ; physical drive 3 goes forwards using default driver timings
            M584 X0 Y1 Z2 E3                               ; set drive mapping
            M350 X64 Y64 Z64 E64                           ; configure microstepping with interpolation
            M92 X1761.5 Y1761.5 Z1761.5 E1488.59              ; set steps per mm
            M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z500.00 E1000.00       ; set accelerations (mm/s^2)
            M906 X700 Y700 Z700 E600                       ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                        ; Set idle timeout
            M208 Z-2:270                                  ; set minimum Z
            M574 X2 S1 P"!xstopmax"                            ; configure active-high endstop for low end on X via pin xstop
            M574 Y2 S1 P"!ystopmax"                            ; configure active-high endstop for low end on Y via pin ystop
            M574 Z2 S1 P"!zstopmax"                            ; configure active-high endstop for low end on Z via pin zstop
            M558 P5 C"^zstop" H5 F120 T2000 X0 Y0 Z1
            M557 R80 S20                                   ; define mesh grid
            G31 X0 Y0 Z33.385 P25
            M563 P0 D0 H1 F0                               ; define tool 0
            G10 P0 X0 Y0 Z                               ; set tool 0 axis offsets
            G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
            M563 P2 S"2rr" D0 H1 F0                     ; define tool 2
            G10 P2 X0 Y0 Z-23.3                                ; set tool 2 axis offsets
            G10 P2 R0 S0
            M563 P5 S"TEST" D0 H1 F0                     ; define tool 2
            G10 P2 X0 Y0 Z-29.3                                ; set tool 2 axis offsets
            G10 P2 R0 S0
            T2
            M575 P1 B57600 S0
            Phaedrux 2 Replies Last reply Reply Quote 0
            • Orang_
              RepRapFirmware 3.2-RC2 Port for LPC
              Have you gone over your printer mechanics? - Yes
              " - yes
                Moved to the LPC port forum since that may be relevant.
                Can you also send M98 P"config.g" and post the results?
                Also your homedelta.g?
                • Orang_
                  ; homedelta.g
                  G91                        ; relative positioning
                  G1 H1 X265 Y265 Z265 F1800 ; move all towers to the high end stopping at the endstops (first pass)
                  G1 H2 X-5 Y-5 Z-5 F1800    ; go down a few mm
                  G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
                  ;G1 Z-5 F1000               ; move down a few mm so that the nozzle can be centred
                  G90                        ; absolute positioning
                  • Orang_
                    M98 P "config.g"
                    Warning: Macro file "config.g" not found
                      Phaedrux Moderator @Orang_ last edited by
                      @Orang_ said in Rotary delta calibration not implemented?:
                      M98 P "config.g"
                      Was there a space between the P and " when you sent the command?
                      • Orang_
                        @Phaedrux
                        M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is disabled
                        TELNET is disabled
                          Thanks. I'm afraid that's the extent of my delta knowledge and I know even less about the LPC port.
                          A video may help and the results of M122 never hurt.
                          Is RC2 the latest for the LPC port, or can you update to 3.2 final?
                          • Orang_
                            @Phaedrux https://drive.google.com/file/d/1xEPkmPwHct_ov90Fp8C5e6YM0wNrkLN9/view?usp=sharing
                            • Orang_
                              @Phaedrux said in Rotary delta calibration not implemented?:
                              yes, i can
                                From your video is seems like it's triggering the probe, but then skipping steps on one arm when it tries to return to the dive height causing it to lurch.
                                Are you sure there's no slipping grub screw or something like that?
                                jay_s_uk Orang_ 2 Replies Last reply Reply Quote 0
                                • Orang_
                                  Orang_ @Orang_ last edited by
                                  @Orang_
                                  	M122
                                  RepRapFirmware for LPC176x based Boards (biquskr_1.3) version 3.2-beta4.1_1 running on LPC176x at 100Mhz
                                  Used output buffers: 3 of 16 (11 max)
                                  Static ram: 5044
                                  Dynamic Memory (RTOS Heap 5): 2056 free, 1992 never used
                                  Never used RAM 80, free system stack 6 words
                                  Tasks: NETWORK(blocked,196) HEAT(blocked,242) MAIN(running,353) IDLE(ready,20)
                                  Owned mutexes: WiFi(NETWORK)
                                  Last reset 00:55:21 ago, cause: [software]
                                  Last software reset at 2021-01-11 22:25, reason: User, GCodes spinning, available RAM 256, slot 1
                                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00428000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                  Error status: 0x00
                                  Supply voltage: under voltage events: 0
                                  Driver 0: position 43414, no-driver-detected
                                  Driver 1: position 43808, no-driver-detected
                                  Driver 2: position 41828, no-driver-detected
                                  Driver 3: position 0, no-driver-detected
                                  Driver 4: position 0
                                  Driver 5: position 0
                                  Driver 6: position 0
                                  Date/time: 2021-01-11 23:20:45
                                  Slowest loop: 95.26ms; fastest: 0.12ms
                                  Step timer: target 2615712365 count 3321023289 delta -705310924 late 0
                                  USBSerial connected 0
                                  ADC not ready 2 ADC error threshold 10 ADC Init 1
                                  Ints: 0; Calls 0; fast: 4294967295uS; slow 0uS adj 0 bad 0 big delta 0
                                  PWM Channels
                                  Delta -1446546330 Start -1 End -1
                                  === Storage ===
                                  Free file entries: 4
                                  SD card 0 detected
                                  SD card longest read time 5.7ms, write time 5.3ms, max retries 0
                                  FreeDm 100 (min 97), maxWait 1181857ms, bed compensation in use: none, comp offset 0.000
                                  === DDARing ===
                                  Scheduled moves 91, completed moves 91, hiccups 39525, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                                  Bed heaters = 0, chamberHeaters = -1
                                  Heater 1 is on, I-accum = 0.0
                                  Segments left: 0
                                  Movement lock held by null
                                  HTTP is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Trigger is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Code queue is empty.
                                  === Network ===
                                  Slowest loop: 322.64ms; fastest: 0.00ms
                                  Responder states: HTTP(2) HTTP(0)
                                  HTTP sessions: 1 of 2
                                  - WiFi -
                                  Network state is active
                                  WiFi firmware version 1.25B0-01L-D
                                  WiFi MAC address e0:3f:49:23:39:c4
                                  WiFi Vcc 2.93, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 35560
                                  WiFi IP address 192.168.1.97
                                  WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Clock register 00181001
                                  Socket states: 0 0
                                  • jay_s_uk
                                    jay_s_uk @Phaedrux last edited by
                                    There should be no differences between the LPC port and the normal version in terms of kinematics etc that I'm aware of. There are some other restrictions but that's mainly due to memory.
                                    Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
                                    • jay_s_uk
                                      jay_s_uk last edited by
                                      You can upgrade to 3.2 final from here https://github.com/gloomyandy/RepRapFirmware/releases/tag/v3.2_1
                                      • Orang_
                                        it happens only with delta calibration and mesh compensation, with normal use it is not observed
                                        • Orang_
                                          RepRapFirmware 3.2 does not solve the problem(((
                                            Phaedrux Moderator @Orang_ last edited by Phaedrux
                                            M350 X64 Y64 Z64 E64 ; configure microstepping with interpolation M92 X1761.5 Y1761.5 Z1761.5 E1488.59 ; set steps per mm
                                            Pardon my ignorance on the LPC port, but perhaps you can try using x16 microstepping to get a baseline?
                                            I notice in your M122 there are a lot of hiccups which can mean skipped steps, so reducing the microstepping could help
                                            hiccups 39525
                                            • Orang_
                                              hiccups 39525
                                              The printer behaves the same way only with delta calibration and mesh compensation, no problems with printing and moving, I do not think the problem is microstepping but I can try
                                              jay_s_uk Phaedrux 2 Replies Last reply Reply Quote 0
                                              • jay_s_uk
                                                jay_s_uk @Orang_ last edited by
                                                @Orang_ yea, I really wouldn't run anything higher than x16 on an LPC
                                                  Yes, and it's the quick movements to raise Z after probing that it's skipping, and those moves would be generating the most step pulses. The hiccups are indicating an issue caused by too high microstepping values.
                                                  If this isn't the problem I'll be surprised.
                                                  • Orang_
                                                    M350 X16 Y16 Z16 E16
                                                    M92 X440.375 Y440.375 Z440.375 E440.375
                                                    How to reduce the speed of movement during calibration
                                                      Are you still getting hiccups in M122 after a fresh reboot and running G32?
                                                      You can add some commands to bed.g to lower the acceleration, jerk, and max speed before the probing and then return it to normal again at the end.
