    FITTING TWO MECHADUINO CONTROLLERS
    Accessories and Add-ons
    134
    • mendelevium
      mendelevium last edited by
      Has anybody managed to power Mechaduino fitted Motors through a Duet 2 wifi board?
      • Veti
        Veti last edited by
        it looks like you can connect it like any other external stepper
        see
        https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers
        you wont be able to use any special functionality.
        you can use the step,dir inputs for drop-in compatibility with stepper motors / step stick
        why exactly do you want to use this?
        • mendelevium
          I have managed to run the X and Y Motors fitted with mechaduino in a Ramps board by removing the X and Y axis motor drivers altogether and just run 3 cables in the VIN/STEP/DIR pins. Since the duets have the Drivers on board I wonder if there is any expansion board. I have noted the link for connecting an external stepper... Can this be used to do just this?
          The mechanduino is good for avoiding missed steps.
          Veti 1 Reply Last reply Reply Quote 0
          • Veti
            Veti @mendelevium last edited by
            @mendelevium said in FITTING TWO MECHADUINO CONTROLLERS:
            generally if your printer is missing steps, its best to fix the underlying issue.
            if your printer is working well, missing steps is not a problem.
            the documentation i linked describes how to connect external stepper motors.
            but you would loose all the advanced features of the tmc drivers on the duet.
            • mendelevium
              Thanks, will have a look. If I can miss just the X and Y control features it would be worth sacrificing...
                Mechaduino controllers have been used with Duets before. AFAIR the main issue was that they need quite a long direction hold time configured in the M569 command.
                mendelevium 1 Reply Last reply Reply Quote 0
                • mendelevium
                  I am not sure I am understanding what you mean by that statement "FAIR the main issue was that they need quite a long direction hold time configured in the M569 " We intend to produce and sell a high end 3D printer and wish to use the duet 3d being such a masterpiece in design.
                  I have managed to obtain very good results with the mechaduinos on a Ramps but I wish to get the features of the Duet board and sacrifice the duet`s x and y axis controls over the X and Y closed loop positioning features. I must admit spent weeks tweaking them. If you can guide me accordingly I appreciate it.
                  • mendelevium
                    mendelevium @dc42 last edited by
                    • jay_s_uk
                      jay_s_uk last edited by
                      @mendelevium
                      ARAIR = As far as I remember
                      Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
                      • mendelevium
                        mendelevium @jay_s_uk last edited by
                        @jay_s_uk
                        yep that was understood..:-) the explanation which followed.....
                        • jay_s_uk
                          The T value in M569
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing
                          I.e. the nanoseconds required for each command to be accepted
                          • mendelevium
                            I have two Brand new Duets still in the box and as soon as I have the machine ready I will give it a try, however I am looking at an uphill struggle. My forte is mechanical Engineering and I would need to scratch deep to find what I need to do, however this site has a goldmine of information and I will try to manage.....
