    DuetLapse3
    Third-party software
    20
    296
    30.1k
    • stuartofmtundefined
      stuartofmt @fractalengineer
      @fractalengineer
      Thanks. As a plugin ? hmmm . I'll have to see what that means / entails. Let me put that as a priority 2 for right now.
      Priority 1 is getting SSB working and tidying up some of the logic / behavior surrounding pauses. I did not test that aspect much and its somewhat ambiguous - so stay tuned ...
        jay_s_uk @stuartofmt
        @stuartofmt
        192.168.1.31 Determine API Version
        192.168.1.31 Testing: rr_model at address 192.168.1.31
        192.168.1.31 http://192.168.1.31/rr_model?key=boards
        192.168.1.31
        192.168.1.31 Testing: /machine/system at address 192.168.1.31
        192.168.1.31 http://192.168.1.31/machine/status
        192.168.1.31
        192.168.1.31 API model is: SBC   Version is: 3
        192.168.1.31 Status is :idle
        192.168.1.31 Layer is :0
        192.168.1.31 ***Testing V0***
        405
        Method Not Allowed
        192.168.1.31 gCode command return code = 405
        192.168.1.31 Method Not Allowed
        192.168.1.31 Send Gcode result: 405
        192.168.1.31 ***Testing V1***
        200
        OK
        192.168.1.31 Send Gcode result: 0
        192.168.1.31 ***Testing V2***
        404
        Not Found
        192.168.1.31 gCode command return code = 404
        192.168.1.31 Not Found
        192.168.1.31 Send Gcode result: 404
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
          stuartofmt @jay_s_uk
          @jay_s_uk
          OK! Looks like V1 worked!! So you should have got a message on DWC saying "Test of SBC"
          Did you see that ?
            jay_s_uk
            @stuartofmt
            No, nothing displayed on DWC
              @jay_s_uk
              Ok - I'm going to have to get some help. The code I have seen elsewhere (including Danal's) does not work (or I've done something stupid). The one that reports success - does not seem to send the gcode .... go figure .....
              So - this should work for SBC -- but not for using the pause capability (that's the only thing that sends gcodes). Appreciate it if you could test before I update github
              Hmm - wont let me upload the file to here. I'll update on github - if you would not mind downloading from there.
                stuartofmt
                Ok it looks like we are getting close ( thanks to an "anonymous" tip in another thread 🙂 )
                Can you try this please. V3 is the latest (and hopefully correct) form.
                [SBCTEST.py]
                  stuartofmt
                  In order to better handle pause situations - I need to access Duet to get a previously unused set of parameters. I'll post a new test script tomorrow. If successful - then SBC should be fully supported. Stay tuned and thanks for the help.
                  • PCRundefined
                    PCR
                    @stuartofmt i will have acces to my SBC printer tomorrow
                      stuartofmt
                      If all y'all could try this on SBC please
                      [SBCTEST.py]
                      In particular verify that a message appears in DWC "Test of SBC"
                        @stuartofmt
                        Good news
                        localhost Testing: rr_model at address localhost
                        localhost http://localhost/rr_model?key=boards
                        localhost
                        localhost Testing: /machine/system at address localhost
                        localhost http://localhost/machine/status
                        localhost
                        localhost API model is: SBC   Version is: 3
                        localhost Status is :idle
                        localhost Send Gcode result: None
                        localhost Layer: None
                        localhost Get Position X and Y: 160 130
                        bad news, no popup
                          @jay_s_uk
                          Yikes on the lack of gcode being sent ... Unfortunately the API endpoint reports success - when clearly that is not the case ...
                          This one last bit is turning out to be frustrating .... 😞
                          The code for sending the gcode (thanks for the reference) is very simple. It works perfectly for rr_model (just uses a http get) but does not seem to want to play for /machine/gcode (which according to the doc requires a post).
                          I've added a second slightly different syntax. I found two slightly different versions (one in DuetUI and the second in Danals DuetAPI). They are nearly identical, one has the url as .../machine/code and the other as /machine/code/ ...
                          If you would not mind running it .....
                          SBCTEST.py
                            @stuartofmt
                            no popup there either
                            localhost Determine API Version
                            localhost
                            localhost
                            localhost URL was: http://localhost/machine/code
                            localhost URL was: http://localhost/machine/code/
                              @jay_s_uk
                              I'll go back to the DWC threads and see if there are some ideas I can try.
                              The good news is I've made the baseline code considerable more robust and have improved the handling of pauses (if used). But none of the pause improvements matter without the ability to send gcodes 🙂
                              • PCRundefined
                                PCR
                                @stuartofmt
                                https://github.com/Kriechi/Cura-DuetRRFPlugin/blob/master/DuetRRFOutputDevice.py
                                Maybe this is helpful
                                • PCRundefined
                                  PCR
                                  @stuartofmt only for history
                                  pi@duet3:~ $ ./1610998509032-sbctest.py -duet 192.168.140.126
                                  192.168.140.126 Determine API Version
                                  192.168.140.126 Testing: rr_model at address 192.168.140.126
                                  192.168.140.126 http://192.168.140.126/rr_model?key=boards
                                  192.168.140.126
                                  192.168.140.126 Testing: /machine/system at address 192.168.140.126
                                  192.168.140.126 http://192.168.140.126/machine/status
                                  192.168.140.126
                                  192.168.140.126 API model is: SBC   Version is: 3
                                  192.168.140.126 Status is :processing
                                  192.168.140.126 URL was: http://192.168.140.126/machine/code
                                  192.168.140.126 Send Gcode result: None
                                  192.168.140.126 Layer: 3
                                  192.168.140.126 Get Position X and Y: 96.787 119.675
                                  192.168.140.126 URL was: http://192.168.140.126/machine/code/
                                  no DWC message either
                                  • PCRundefined
                                    PCR
                                    @stuartofmt I changed this line
                                    logger.info('Send Gcode result: '+str(sendDuetGcode2(apiModel, 'M117 Test of SBC')))
                                    to
                                    logger.info('Send Gcode result: '+str(sendDuetGcode2(apiModel, 'M117 "Test of SBC"')))
                                    aand
                                    stuartofmtundefined 1 Reply Last reply Reply Quote 1
                                      stuartofmt @PCR
                                      @PCR said in DuetLapse3:
                                      aand
                                      ![a02d93f9-98a1-4404-bb9a-c67b729cac68-grafik.png](/assets/uploads/files/1611049373109-a02d93f9-98a1-4404-bb9a-c67b729cac68-grafik.png)
                                      Brilliant!.
                                      Last night (in my slumbers) I wonderer if the data=command in the push code needed to be encoded because of the spaces in M117 etc. In the various example code it seems only single gcodes have been passed and likely why those examples worked. Dueui was a bit different but that was javascript and I'm even more unfamiliar with that than I am with Python .....
                                      DuetLapse3 in its current form only needs to send single gcodes. So - as it stands we have a fully working DuetLapse3. The choice of M117 ... for testing turned out to be both good and bad.
                                      What I will do today is try and crack the encoding needs so that it does not break in the future. I've set up a simple webserver and can debug the incoming and see what happens. I have not yet updated the github but either way will do so later today
                                      @jay_s_uk and @PCR
                                      Thanks for being the remote testers.
                                        stuartofmt
                                        Version 3.0.4 released in github. All functionality should now work with SBC.
                                        The issues with SBC gcode appear to be due to differences in the way DWS was handling the test case.
                                          stuartofmt
                                          Version 3.1.1 released on github. This is pretty significant - the details are documented but here us a summary.
                                          ###Version 3.1.0###
                                          [1] Added support for Windows
                                          [2] Added automatic detection of operating system (Linux or Windows)
                                          [3] Added integrated http listener for basic browser based control
                                          [4] Changed file naming convention to make filenames unique if multiple instances of DuetLapse3 are running.
                                          An Integrated http listener is available for basic control of DuetLapse3 (not the attached printer).
                                          The http listener is activated by specifying a port number using the -port option.
                                          In conjunction with the -host option it provides the following functionality from a browser (or curl or other method of performing a http get).
                                          http://<ip-address><port>/?command=<valid command>
                                          *Valid commands are:
                                          start - Starts DuetLapse3 recording if the -stopcmd option was used or after a stop command
                                          standby - Stops (but does not terminate) DuetLapse3 recording and discards any images capture. Waits for a start command.
                                          status - returns brief information about the running state of DuetLapse3
                                          pause - causes DuetLapse3 to temporarily stop capturing images
                                          continue - causes DuetLapse3 to resume capturing images
                                          snapshot - causes DuetLapse3 to make an interim video and then continue
                                          restart - causes DuetLapse3 to stop capturing images, create a video and then restart with a new capture set
                                          terminate - causes DuetLapse3 to stop capturing images, create a video and then terminate the program. This is the same as CTRL+C or SIGINT.
                                          Note that depending on your system - it may take several minutes for the http listener to completely shutdown following a terminate request.*
                                          Note that the http listener will stop responding if DuetLapse3 is run from a command console that is then closed. This will happen even if started in background. To avoid this - use nohup (linux).
                                          Windows does not have an (easy) equivalent to nohup so you would need to leave the command console open. An alternative if you are on Win10 is to use Windows Subsystem for Linux (WSL) and run DuetLapse as a linux application inside WSL.
                                          If running in nohup mode CTRL+C cannot be used so you need to send the terminate command (?command=terminate) from the http listener
                                          Made an accommodation (in 3.1.1) for ffmpeg < 4.2 by using a simpler syntax if -extratime is not used.
                                            stuartofmt
                                            @fractalengineer
                                            Take a look at the post above. It does not provide a plugin but the http listener makes it easier to control remotely. It looks like the plugins require javascript and frankly - that's not something I want to get into.
                                            Someone else (with the skills) could create a simple plugin that calls appropriate urls and provide control that way.
                                            I will create a helper script that proved a separate http listener to remotely start DuetLapse3 - but that's a few days away.
                                            fractalengineerundefined 1 Reply Last reply Reply Quote 0
