    Error: Heater 1 fault: heater monitor 0 was triggered
    • Ducati87undefined
      Ducati87
      Hello guys, I'm having this problem each time a launch a print or do a G28:
      Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2 (2021-01-05)
      Duet WiFi Server Version: 1.25
      I already did a PID tuning, saved with M500 but without results.
      Any suggestions?
      Thank you.
        jay_s_uk
        Can you post an example gcode, the complete config.g and your homing files
        • Ducati87undefined
          Ducati87
          Start gcode:
          T0;
          G90 ; use absolute coordinates
          M83  ; extruder relative mode
          M190 S[first_layer_bed_temperature] ; wait for bed temp
          M109 S[first_layer_temperature] ; wait for extruder temp
          G28; homing
          G32; home all without mesh bed level
          G29 S1; mesh bed load
          G1 X5 Y15 Z0.2 F5000.0 ; go outside print area
          G92 E0.0
          G1 X60.0 E9.0 F1000.0 ; intro line
          G1 X100.0 E20 F1000.0 ; intro line
          G92 E0.0
          home.g
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:18 GMT+0200 (Ora legale dell’Europa centrale)
          ;M400
          ;M913 X50 Y50
          ;M915 X F0 H400 S3 R0
          ;M915 Y F0 H400 S2 R0
          ;G91               		; relative positioning
          ;G1 H2 Z5 F7200          ; lift Z relative to current position
          ;G1 H1 X5 F5000
          ;G1 H1 X-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
          ;G1 H1 X10
          M98 P"homex.g"
          ;G1 H1 Y5 F5000
          ;G1 H1 Y-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
          ;M913 X100 Y100			     ; X motors to 100% current
          ;G90
          ;G1 X120 Y170 F7000           ; go to first bed probe point and home Z
          ;G90                ; absolute positioning
          ;G1 X110 Y210 F7000           ; go to first bed probe point and home Z
          ;G4 P750             ; pause
          ;G91
          M98 P"homey.g"
          ;BLTouch Z
          ;G30
          ;G90
          ;G1 Z10 F500
          M98 P"homez.g"
          homex.g:
          ; homex.g
          ; called to home the X axis
          M400
          M913 X50
          M400
          M201 X200
          G1 H1 X-305 F5000 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X10 F7200       ; go back a few mm
          G1 H1 X-305 F3000  ; move slowly to X axis endstop once more (second pass)
          G1 H2 X15 F7200   ; lower Z again
          M400
          M913 X100
          M400
          homey.g:
          ; homey.g
          ; called to home the Y axis
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:19 GMT+0200 (Ora legale dell’Europa centrale)
          M913 Y50
          M201 Y100
          G1 H1 Y-305 F5000 		; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 Y10
          ;G1 H1 Y-100 F5000        ; home Y axis
          M913 Y100
          homez.g
          ; homez.g
          ; called to home the Z axis
          G1 X130 Y170 F7000           ; go to first bed probe point and home Z
          G4 P750             ; pause
          G91
          ;BLTouch Z
          G30
          G90
          ;G1 Z10 F500
          example of gcode:
          ; generated by PrusaSlicer 2.3.0+win64 on 2021-01-14 at 08:25:31 UTC
          ; external perimeters extrusion width = 0.40mm
          ; perimeters extrusion width = 0.40mm
          ; infill extrusion width = 0.40mm
          ; solid infill extrusion width = 0.40mm
          ; top infill extrusion width = 0.40mm
          ; first layer extrusion width = 0.36mm
          M107
          ;TYPE:Custom
          T0;
          M190 S80 ; wait for bed temp
          M109 S210 ; wait for extruder temp
          G28; homing
          G92 E0.0
          G92 E0.0
          G21 ; set units to millimeters
          M82 ; use absolute distances for extrusion
          G92 E0
          ; Filament gcode
          M572 D0 S0.7
          ;LAYER_CHANGE
          ;Z:0.3
          ;HEIGHT:0.3
          G1 E-7.00000 F3600.000
          G92 E0
          G1 Z0.400 F9000.000
          G1 X117.168 Y117.338
          G1 Z0.300
          G1 E7.00000 F3600.000
          M204 S3000
          ;TYPE:Skirt
          ;WIDTH:0.36
          G1 F1500.000
          • Ducati87undefined
            Ducati87
            ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 20:14:09 GMT+0100 (Ora standard dell’Europa centrale)
            M550 P"Hypercube Evolution"                        ; set printer name
            M669 K1                                            ; select CoreXY mode
            M569 P0 S1                                         ; physical drive 0 goes forwards
            M569 P1 S1                                         ; physical drive 1 goes forwards
            M569 P2 S0                                         ; physical drive 2 goes forwards
            M569 P3 S1                                         ; physical drive 3 goes forwards
            M569 P4 S0                                         ; physical drive 4 goes forwards
            M584 X0 Y1 Z2:4 E3                                 ; set drive mapping
            M350 X16 Y16 Z16 E32 I1                            ; configure microstepping with interpolation
            M92 X161.07 Y159.36 Z800 E830.00         					; set steps per mm
            M566 X600.00 Y600.00 Z50.00 E18000.00                ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z1200.00 E10000.00            ; set maximum speeds (mm/min)
            M201 X5000.00 Y5000.00 Z120.00 E8000.00              ; set accelerations (mm/s^2)
            M906 X1200 Y1200 Z1500:Z1500 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
            ;M208 X0 Y0 Z0 S1                                   ; set axis minima
            M208 X0:300 Y-35:300 Z285 S0                     ; set axis maxima
            M574 X1 S3                                         ; configure sensorless endstop for low end on X
            M574 Y1 S3                                         ; configure sensorless endstop for low end on Y
            M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
            M307 H3 A-1 C-1 D-1                                ; disable heater on PWM channel for BLTouch
            M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H3 F250 T9000 A2 B1              ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X22 Y-37 Z4.2                             ; set Z probe trigger value, offset and trigger height
            M557 X0:280 Y25:230 S40:40                         ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin bedtemp
            M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
            M308 S1 P"spi.cs2" Y"rtd-max31865"                 ; configure sensor 1 as thermocouple via CS pin spi.cs2
            M143 H1 S290                                       ; set temperature limit for heater 1 to 290C
            M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
            M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
            M106 P2 S0 H-1                                 ; set fan 2 value. Thermostatic control is turned off
            M563 P0 S"hotend 0" D0 H1 F0:2                     ; define tool 0
            ; Custom settings
            M404 N1.75 D0.4								        ; Nozzle and filament diameter for monitor
            M200 D1.75 									        ; set all extruder filament diameters to 1.75mm
            M671 X40:280 Y145:145 S10							; Define positions of Z leadscrews or bed levelling screws
            M376 H10											; Set bed compensation taper
            M575 P1 S1 B57600                                  ; enable support for PanelDue
            M501                                               ; load saved parameters from non-volatile memory
            T0                                                 ; select first tool
            ;M572 D0 S0.3
              What temp do you have set in the slicer? The error indicates that you've hit the temp limit you've set in config.g of 290c.
              @Ducati87 said in Error: Heater 1 fault: heater monitor 0 was triggered:
