    IMPORTANT ISSUE with bed temp controller
    Firmware developers
    fire risk
    8
    86
    4.4k
    • jrocklandundefined
      jrockland
      Since last update the firmware does NOT always shut down hot ends or beds when they are in FAULT and keep them active :
      Woke up this morning to a 220c bed.. not only cost me couples hours of printing but also a 300$ heating bed. Got lucky it didnt catch in fire.
      Since the last update it happen couples of time where the hot ends would go over their temp but I was always around to monitor them. They go in FAULT mode but keep heating up.
      Please review the firmware asap, it is a major fire issue !
      Thank !
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        for the bed its a good idea to add a thermal fuse.
        like
        https://de.aliexpress.com/item/32885492280.html
        what kind of setup are you running?
        an ssr? because normal beds do not reach that temperature.
        maybe the ssr failed.
        jrocklandundefined 1 Reply Last reply Reply Quote 1
        • engikeneerundefined
          engikeneer @jrockland
          @jrockland maybe also post your config, hardware and firmware versions so the Duet guys have something to go on?
          i3 clone with a bunch of mods
          jrocklandundefined 1 Reply Last reply Reply Quote 0
            jrockland @Veti
            @Veti It is a commercial bed, reach 220c easy.. You are 100% right I will add an external safety switch in case.
            I was just really lucky because if it had been one of my hot end it would had catch in fire, and I'm not sure their is thermal fuse for that..
            mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
            • mrehorstdmdundefined
              mrehorstdmd @jrockland
              @jrockland Get a fully spe'd and certified TCO from a reliable source like DigiKey. They only cost about $1.
                jrockland @engikeneer
                @engikeneer Duet3d 6HC, latest firmware 3.2 stable.
                config doesn't matter as it went into fault but kept running. not the first time since the firmware update.
                Vetiundefined 1 Reply Last reply Reply Quote 0
                  jrockland @mrehorstdmd
                  @mrehorstdmd TCO ? like those thermal fuse ? sound like a really good idea, and if they are small enough I could also stick one on top of my heat block. I will look into it.
                  • Vetiundefined
                    Veti @jrockland
                    @jrockland said in IMPORTANT ISSUE with bed temp controller:
                    some cooperation from your side would be appreciated.
                      jrockland @Veti
                      @Veti m307 h1 r0.310 c706.9 d6.34 s1.00. I don't know why you want that.
                      I have to re type it by hand so I wont do the whole config file.
                      • Vetiundefined
                        Veti @jrockland
                        we mean the whole config.g. you can copy and past the entire file. no need to retype
                          jrockland @Veti
                          @Veti my machines are commercial grade, there is no "copy paste" options.
                          Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • Vetiundefined
                            Veti @jrockland
                            how do you expect anyone to analyse this problem if you provide no information?
                            i could state that for every other user this is working fine and must be a problem in your setup.
                            Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
                              jrockland
                              *** For developers:
                              -heat bed is ran by relays (First thing I checked was if a relay had "stick")
                              -firmware went into "fault" after it couldn't heat fast enough (happen often)
                              -instead of shutting down it kept feeding the relays.
                              -Did a M999 and everything went back to "normal".
                              Board: Duet6HC
                              Pin out: IO3.OUT
                              firmware 3.2 stable
                              never had this issue before last update.
                              • fcwiltundefined
                                fcwilt @jrockland
                                The printer uses a Duet board but you don't have access via browser to the Duet Web Control?
                                That seems odd.
                                  jrockland @fcwilt
                                  @fcwilt not from my computer. I need the geek squad to get on their computer for that.
                                  also lot of information is confidential so I can only quick fix manually from the firmware user page and can't copy paste anything.
                                  • Luke'sLaboratoryundefined
                                    Luke'sLaboratory @Veti
                                    @jrockland
                                    However - some explanation on why the config.g is useful here - it helps diagnose some other issues from weird or overriding settings.
                                    Have you ran a new PID tune with the update to 3.2? The heater tuning uses feedforward algorithms to improve performance and may be one of the reasons for not heating fast enough.
                                    Luke
                                    http://lukeslab.online
                                      engikeneer
                                      @jrockland you can see everyone is very interested with the amount of people replying!
                                      First thing the developers will need to know to investigate will be some steps to recreate the issue. Eg. Your config file now, and your config file & firmware version from when it worked (3.1.1?).
                                      There are many commands in your config that could impact this (e.g. M143, which IO port you're using etc).
                                        jrockland @Luke'sLaboratory
                                        @Luke-sLaboratory Yes, I ran a pid tuning on everything since the new format seem to work much better and did improved stability.
                                        I gave more info in a response (not sure how to edit my post) about m307, how the bed is connected and which port it use. not sure if anything else is relevant.
                                          @engikeneer M143 is at 150.
                                          latest firmware used was 3.1.1 stable.
                                          it also happen on my other machines at least once, on hot ends. I disregarded as I was around and was busy so I just forced reset and get it going again.
                                            Luke'sLaboratory @jrockland
                                            @jrockland
                                            I know that sometimes the relay/SSR used can have unintended behaviors if not properly accounted for, they can "latch" on if too warm or if not properly configured. If you're able to provide part #'s for the relays and some pictures of wiring, etc, That could help evaluate the issue.
                                            Luke
